Rear Differential Completely Destroyed at 25,000 kilometers.
Discussion in '3rd Gen. Tacomas (2016-2023)' started by 2016LimitedTaco, Feb 20, 2017.
  1. Feb 21, 2017 at 12:48 PM
    #181
    PROseur
    PROseur Well-Known Member
    Pussy
    2012 FJC TTSE/ 2001 Taliban Poverty DCSB/ 2017 6MT PRO / 2018 2.7L SR Utility
    Now you want to apologize to @2016LimitedTaco for calling him a liar ?
    EB Group, JFick, CanadaToy and 2 others like this.
  2. Feb 21, 2017 at 12:49 PM
    #182
    GPsevinSixx
    GPsevinSixx Well-Known Member
    Ros Angerus
    2015twoAX2.4techPAWS
    6112/5160AALfnCNTSTRyokG015
    That was quick.....
  3. Feb 21, 2017 at 12:54 PM
    #183
    GPsevinSixx
    Ros Angerus
    Good they had it all ready to drop in for you. Shimming gears up is a skill that not all technicians have the ability to do. Glad you're sorted out with the Toyota dealer.
    Toyko Joe and PROseur like this.
  4. Feb 21, 2017 at 12:58 PM
    #184
    Toyko Joe
    Toyko Joe Here for the pictures
    Dude chill, I never said OP lied. I simply said that things were bothering me and I wanted more information regarding the photos. You implied I called OP a liar, your words not mine.
    Mush Mouse likes this.
  5. Feb 21, 2017 at 1:00 PM
    #185
    2016LimitedTaco
    2016LimitedTaco [OP] Well-Known Member
    Derek
    2016 Tacoma Limited
    Rear heated seats, pop-n-lock tailgate, undercover flex tonneau and bed lights
    Agreed. The second I realized it was a complete "pod" and it eliminated shimming and backlash checking I felt a million times better. I just pray to God it doesn't have the rear end humming / howl that others have because it definitely did NOT have it previous to this pod being installed.
  6. Feb 21, 2017 at 1:00 PM
    #186
    PROseur
    Pussy
    Please report back
    We are hoping the best for you
  7. Feb 21, 2017 at 1:05 PM
    #187
    GPsevinSixx
    Ros Angerus
    I wonder if you'd be able to go easy on the truck while the teeth are seating in? I'm curious if the howl is caused by gears not being properly worn in. We really should not have to do that too much nowadays though. The fluid comes out pretty filthy though when I did my change at 5k. I mean it's like gunmetal colored molasses.
  8. Feb 21, 2017 at 1:06 PM
    #188
    GPsevinSixx
    Ros Angerus
    +1
    PROseur[QUOTED] likes this.
  9. Feb 21, 2017 at 1:11 PM
    #189
    aero90
    aero90 Well-Known Member
    2016 TRD OR 4x4 M/T - Sold
    Its not due to break-in, I had mine replaced for howling and the new one was quiet for all of 10 minutes.
  10. Feb 21, 2017 at 1:13 PM
    #190
    GPsevinSixx
    Ros Angerus
    Oh man... not good. Some test drives don't even last that long.
  11. Feb 21, 2017 at 1:13 PM
    #191
    fdbyrne
    fdbyrne Well-Known Member
    Missouri
    2016 Tacoma TRD Off Road (Manual), 2004 4RUNNER V6 4x4
    Mine too and I properly broke in both of my differentials.
    GPsevinSixx and shakerhood like this.
  12. Feb 21, 2017 at 1:14 PM
    #192
    2016LimitedTaco
    Derek
    2016 Tacoma Limited
    I cannot see why you would have to but I will be going easy anyway as for now I've lost faith it can take ANYTHING as it broke from very light use.
  13. Feb 21, 2017 at 2:21 PM
    #193
    Blktre
    Blktre Well-Known Member
    Land of Oz....
    16 Super White DCLB TRDOR: The White Goat
    As messy as that technicians stall is you should be very happy you got a complete pod. Opening up the rear diff and RR the blown parts with new always invites the possibility of contaminants. A dirty stall tells me that the likelihood of contaminants getting in there is higher vs a clean work area.
    TRDSport10 and Mush Mouse like this.
  14. Feb 21, 2017 at 3:07 PM
    #194
    Woodrow F Call
    Woodrow F Call Kindling crackles and the smoke curls up...
    Colorful Colorado
    16 DCSB SR5 4X4 "ikea furniture haulers" edition.
    I put 115,000 miles on a rear that whined the whole time. Excessive backlash..... never broke though.
    Toyko Joe and Mush Mouse like this.
  15. Feb 21, 2017 at 3:15 PM
    #195
    Woodrow F Call
    Colorful Colorado
    I'm guessing a "pod" is the center section as the Toyota rear is a bit like a 9-inch Ford. In that case, the "pod" will be exposed to whatever. I don't think I could really judge the quality of the work based on the pic in the OP. That may as well just be the "tear down area" or the junk pile. You also don't really need a "clean room" to do good work.
    I'm not saying all is fine, just I think that we are jumping to conclusions based on very minimal information.
  16. Feb 21, 2017 at 3:20 PM
    #196
    GPsevinSixx
    Ros Angerus
    So true, just be glad it's not on a greasy blanket in a dirt field somewhere. The "dirty" greasy shop tables are fine, it's the dirt and other debris that will foul things up if it gets in there.
    Just make sure they keep that greasy crud out of the interiors.
    Toyko Joe likes this.
  17. Feb 21, 2017 at 3:25 PM
    #197
    fdbyrne
    Missouri
    Personally, since I've had 2 loud differentials on this truck, I'd rather have someone actually test the tolerances and set one up in-house vs. trust the same factory in Malaysia (or wherever) that made my first two.
    Drop-ins are easy but the art of doing a job right is lost on whatever factory that Toyota is buying these differentials from.
    Lakeboy, shakerhood and Joe23 like this.
  18. Feb 21, 2017 at 3:26 PM
    #198
    Joe23
    Joe23 Canuckistikian
    The Great White North
    2017 TRD Off-road DCSB
    just curious where are you in Canada?
  19. Feb 21, 2017 at 3:28 PM
    #199
    Joe23
    I've said this numerous times in the threads about the howling diff.
    Won't find the true cause until someone bites the bullet and has a differential specialist do a full assembly on theirs.
    shakerhood likes this.
  20. Feb 21, 2017 at 3:29 PM
    #200
    Woodrow F Call
    Colorful Colorado
    Well, it could be a design issue as well as many people that seem to have the whine. I don't know the real numbers though. The design that goes into a gear is actually quite complex. They look like they are just mating teeth, but it's much more than that.
    Edit: My Machinery's Handbook dedicates 188 pages to gears.
    Joe23 and Toyko Joe like this.
