Rear differential? Dog tracking, etc.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Pat10mile, Aug 23, 2017.
  1. Aug 23, 2017 at 5:53 PM
    Pat10mile
    Pat10mile [OP] Member
    Pat
    W PA
    2012 Tacoma TRD doublecab
    'Evening everyone.
    Truck: Tacoma doublecab, 4x4, 90k miles. No "real" off-roading, but some pulling occasionally.
    Background:
    In May, sideswiped curb hard (with front, I thought); got wobbly steering.Few days later guy stops me in parking lot ..."Dude, your truck is going down the road sideways." (I look at it, but not obvious; but in hindsight ... dog tracking.) Into dealer for alignment. Seems better. But ... I notice that when I am driving in rain, I get this strange sensation of hydro-planning. I am suspecting my crappy new tires (that I got in Feb). THEN (early Aug): Another guy, at a highway exit, jumps out of his truck and says ... yes ... "Dude, your truck is going down the road sideways !" So, I bring it to another place, and YES, spring center pin is sheared off (he gives it back to me; it's rusty ... hmmm). But, here's where I come to the matter ... the new place says "we replaced the pin, and put on new u-bolts (they were bent?), but it's still not fixed because ..." (here it comes) ..."there is something wrong or bent in the rear differential." $2500 (new, could go used for less) to replace. (I believe it's an "e-lock differential.")
    So, 1) does that seem reasonable at all? the differential? not a bent axle perhaps? or 2) is this total BS, and it just needs more adjustment? (I still seem to feel the wobble in the steering.) Thoughts?
  2. Aug 23, 2017 at 5:57 PM
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    I would think the frame is "diamond" before a bent axle.
    Are you experiencing odd vibrations? A bent axle will cause that.
    A true frame shop can diagnose the issue better than any other shop.
  3. Aug 23, 2017 at 6:19 PM
    Pat10mile
    Pat
    W PA
    Vibrations in the steering, yes. (Alignment still off?) But general vibrations, no.
    On the bent/mis-shapen/diamond frame, could I diagnose that myself (measure from point A to B to C, etc.)? That seems possible ... (Frame shop, as you said, would be better.) Thanks for direction to investigate.
