Rear differential failure?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Oreo Cat, Dec 30, 2020.
  1. Dec 30, 2020 at 10:59 AM
    Oreo Cat
    Oreo Cat [OP] Worst Member
    Coeur d’Alene, Idaho
    Getting a weird click from the read end of the truck, entire drive line has been rebuilt less than a year ago and there is no play in the carrier bearing or any u joints
    I can only hear it when the truck is rolling under 15 mph
    any ideas?
  2. Dec 31, 2020 at 5:07 PM
    Oreo Cat
  3. Dec 31, 2020 at 5:08 PM
    eon_blue
    Azusa, CA
    A click can be a lot of things... Video with sound would help.
    If I were worried about the diff I'd first drain the oil and see what comes out.
  4. Dec 31, 2020 at 5:16 PM
    4wdExplorer
    4wdExplorer Well-Known Member
    Orange County, CA
    Change the diff oil and see what comes out. That would be the first step.
  5. Dec 31, 2020 at 6:46 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    Is it worse when you are turning?
    Does your truck have the mechanical lsd or locker?
  6. Dec 31, 2020 at 6:58 PM
    Oreo Cat
    E locked
    I can’t tell if it’s worse or not when turning
    Going to drain tomorrow
    TnShooter[QUOTED] likes this.
  7. Dec 31, 2020 at 8:18 PM
    TacoTuesday1
    SD CA
    clicking on cars is usually CV joints
    not sure about trucks
    front LBJ's can also knock over bumps and stopping (both slow speed) but not result in eyeball detectable play with pliers
  8. Jan 1, 2021 at 11:32 AM
    Oreo Cat
    Well no pieces came out of the rear when I drained it
  9. Jan 1, 2021 at 11:33 AM
    Oreo Cat
    Just discovered my driveline came loose that’s what it was.. that could’ve ended badly..
    jetfishn and CraigF like this.
