Rear differential Fluid at 117,000
Discussion in '1st Gen. Tacomas (1995-2004)' started by Cimpala, Jan 10, 2023.
  1. Jan 10, 2023 at 12:04 AM
    Cimpala
    Cimpala [OP] Member
    Cody
    2021 Tacoma TRD Sport
    Well, Bought this 03 Tacoma, 2WD, Single Cab, 5-Speed, 2.4L, a couple of weeks ago and have been slowly fixing up some minor things to get her road worthy.
    Took it for a spin around the neighborhood tonight after replacing the downstream O2 sensor and heard a bit of clunking.
    Decided to jack it up and check the rear drums praying that it wasn't the rear end.
    Not the brakes. :)
    Held my breath as I pulled off the diff plug and dipped my finger inside, Graphite grey color with ultra fine metal specs.
    Now my question is, is this color normal for 117,000 on the clock? I'm not well versed in rear differentials and don't have the tools or facilities to do a rebuild and or swap myself but something tells me it shouldn't be that color this early on in life. (I use that term loosely.)
    Second question is how much am I looking for a rebuild? This truck is supposed to be a beater to drive an hour to and from work 5 days a week. Would it be cheaper and more beneficial to get the rear-end flushed and filled? Then see how quick she decides to go grey again?
    Pretty definite I got swindled on this truck :), (7K) but I'm willing to stick with her if it's going to be worth it.
    (Note: Taboo maintenance procedure from what I've been taught but, I jacked up the rear and let it cruise in 1st gear to see if I could get it to repeat/recur. No noise but I can only assume that's due to the Diff having no load on it.)
  2. Jan 10, 2023 at 2:02 AM
    CTSpruceMica
    CTSpruceMica Is a hotdog a sandwich?
    Dennis
    2014 Spruce Mica
    Change the rear diff lube and call it a day. It's a super easy DIY, quicker and easier than an oil change. You were able to remove the fill plug, getting that out is usually the most difficult part of doing it.
    TS4x4, ztwatson, Cimpala[OP] and 2 others like this.
  3. Jan 10, 2023 at 7:08 AM
    Kiloyard
    Kiloyard Road Warrior
    Phoenix, AZ
    1999 3.4L SR5 4X4 405K miles
    Toytec Boss/Eibach Coils & Deaver J59's
    Yeah I like the advice here. 75W-90 gear oil for te rear differential.
    May as well do the transmission too. Redline MT-90 is what you want there.
    Cimpala[OP] and Wulf like this.
  4. Jan 10, 2023 at 7:18 AM
    Sep1911
    Sep1911 Well-Known Member
    2016 Taco
    Buy the cheapest fluid and drive around on it for a week. During this time see if you can diagnose it better. If not after a week drain and fill with better fluid. I assume you’re somewhere warm if you dropped $7k on a 2wd truck? If so fill it up with 75w140. If not 75w90 will do.
    Sfish2002, Cimpala[OP] and Wulf like this.
  5. Jan 10, 2023 at 8:02 AM
    Nessal
    Nessal Well-Known Member
    Texas/Bay Area
    2003 V6 4X4 TRD DCAB
    I believe factory change interval is every 30k with 80w90. It's in the owner's manual. Fact check me though.
    Cimpala[OP] likes this.
  6. Jan 10, 2023 at 8:13 AM
    Andy01DblCabTacoma
    Andy01DblCabTacoma Well-Known Member
    Andy
    San Diego, CA
    01 Double Cab v6 4x4 TRD
    F: Kings SPC, R: 5100s+J59s. Custom armor.
    If you think that might be the original gear oil, it's WELL overdue for a fluid change. 117k on the original oil is nuts.
    Cimpala[QUOTED][OP], JoeT4R and Wulf like this.
  7. Jan 10, 2023 at 8:19 AM
    Wulf
    Wulf no brain just damage
    rock raisin
    X2, this will give you an better idea of whether it's actively destructing. Gear oil is like $5/qt at the farm store
    Cimpala[OP] and JoeT4R like this.
  8. Jan 10, 2023 at 8:26 AM
    Sharpish
    Sharpish Well-Known Member
    Brian
    Victoria, British Columbia, Canada
    2012 Tacoma TRD OR 4x4
    If it’s grenading it will roar louder and louder. Not clunk. That’s something else.
  9. Jan 10, 2023 at 8:26 AM
    JoeT4R
    JoeT4R I don't have a Taco
    Joe
    NOVA
    '01 4R, SR5 4WD
    X3. It's also the easiest route to take in the beginning and could be a simple fix (fingers crossed)
    Cimpala[OP] and Wulf[QUOTED] like this.
  10. Jan 11, 2023 at 2:53 AM
    OLDHMECH61
    OLDHMECH61 Well-Known Member
    Andy
    Odessa FL
    99 Prerunner Std cab green
    1UZ swap, trutrac diff, tundra brakes, 3 lift, FJ rims
    Toyota diffs are pretty robust, since yours is a 5 lug suspect street duty only, and there is probably lots of people out there that dont change their diff oil, east coast gear supply recommends Lucas 85-140 diff oil, its spendy at $10 a quart but you only need 2, also buy the nifty little hand pump that thread's on to the diff oil container it makes life way easier getting that oil into diff. Also while at parts store but a cheapo grease gun with grease and while your draining the diff, lube the drive shaft it probably hasn't seen grease in quite awhile either, that should help with the clunking noise (axel wrap) enter that into search bar to learn more, drive shafts and differentials, do all the work, get none of the attention.
    Good Luck
    Andy
  11. Jan 11, 2023 at 3:38 AM
    Sfish2002
    Sfish2002 Well-Known Member
    Stanley
    2003 2wd M/T regular cab Tacoma
    Topper w/racks, bug/rock shield, hood thermal mat, bed liner, hitch
    I have the exact same truck with 165k miles. I’ve changed my rear diff fluid a few times since I owned it from new and it was never silvery but then again it sounds like you have original fluid. I’d do what several other posters said and just refill it but I’d add some Lucas gear oil additive and call it a day for another 50k miles. These are tough little trucks and unless it gets worse is likely to last another 20 years with proper maintenance. Good luck.
