Rear Differential Fluid Change
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Qwntm, Aug 18, 2016.
  1. Aug 18, 2016 at 9:14 PM
    2016_dbag
    2016_dbag Well-Known Member
    2016 POSTURD
    Did you have a stroke at the keyboard?
    jsinnard likes this.
  2. Aug 18, 2016 at 9:43 PM
    hiroslammer
    hiroslammer Well-Known Member
    Carlsbad,CA
    2016 OR 4x4
    I have a '16 OR 4WD and changed my rear diff fluid with M1 75w/90 as well at 1000 miles, it took just over 4.2 quarts. My fluid looked dirty, when I changed the front it was the same, but I would hold off on the transfer case, mine looked brand new. Also, after changing the transfer case fluid I developed a small leak, not sure if it was the thinner fluid, but I tightened one of the lower bolts on the t-case and leak disappeared.
  3. Aug 18, 2016 at 9:44 PM
    2016_dbag
    2016 POSTURD
    I drove my XJ 180,000 miles and only changed the rear diff fluid once. And the only reason I did that was because I sunk it in a river.
  4. Aug 18, 2016 at 9:50 PM
    smitty99
    smitty99 I also bought a 4Runner
    Scottsdale
    16 TRDORDCSB 4x4 A/T (loaded w/ JBL)
    6112s/5160s & 3-leaf AAL;ubolt flip kit;Superbumps
    Leave it alone and let toyota fix it. Change fluid and they find out you could be screwing yourself out of a warranty
  5. Aug 18, 2016 at 10:59 PM
    Z50king
    Z50king DCLBOR4X4FTW
    Eric
    Southern California
    2016 DCLB Off Road 4x4 Super White
    Stock and loving it
    2016_dbag[QUOTED] and jsinnard like this.
  6. Aug 19, 2016 at 12:18 AM
    Qwntm
    Qwntm [OP] Well-Known Member
    Edward
    Boise, ID
    2016 Inferno TRD Off Road DCSB
    None...yet!
    Yea, the fluid old fluid is hard to describe. It did look dirty, but not worn/old dirty, kinda like clean fluid with fine black "graphite" in it. It did have a metallic shimmer in the sun.
    The only reason I'd swap the transfer case now is to run the synthetic.
    The hammer likes this.
  7. Aug 19, 2016 at 4:02 AM
    Aussiek2000
    Aussiek2000 Well-Known Member
    2016 Offroad AC
    That's working so well for you
  8. Aug 19, 2016 at 5:54 AM
    splitbolt
    splitbolt Voodoo Witch Doctor
    NW Arkansas
    2016 TRD OFFROAD DCSB MGM
    You going to use GL4 or GL5 in the transfer case?
  9. Aug 19, 2016 at 6:36 AM
    The hammer
    The hammer Who’s the Wrench?
    '16 Tacoma SR5 4X4 DCLB TSS Pkg 17X8" BSW-Cooper DIscoverer AT3 4s P265/65/17
    Underworld Flex trifold, tinted, TRDPRO grill, TRDPRO shift knob, etc,etc
    I’ll be changing mine at 10k, wish I had done it at the 5k to get those break-in shavings out but no worries, better late than never.
    The less friction, the quieter, smother and arguably better gas (a 10th lol) mileage you'll likely to get with clean fresh oil change.
    Hope that helps
    Cheers!
    shakerhood likes this.
  10. Aug 19, 2016 at 6:46 AM
    Markc1024
    Markc1024 Well-Known Member
  11. Aug 19, 2016 at 7:26 AM
    splitbolt
    NW Arkansas
    Right on.
    I was that close to using MT90 in the transfer case. I chickened out and bought LF. Next time...
  12. Aug 19, 2016 at 10:19 AM
    Jeff Lange
    Jeff Lange Well-Known Member
    Calgary, Canada
    '86 AE86, '05 NCP13, '11 GSE21
    Factory gear oil in the differential is synthetic GL-5 75W85.
    I'm not sure if the transfer is synthetic or not, or if it is GL-4 or GL-5. I don't have the specs on the Toyota Gear Oil LF 75W.
    Jeff
    shakerhood and smitty99 like this.
  13. Aug 19, 2016 at 10:31 AM
    Qwntm
    Edward
    Boise, ID
    None...yet!
    Not sure. The information regarding the Transfer case oil is sparse. It say Toyota 75w with no GL specified. Doesn't sound too picky. Unless I can find a good reason to go GL-4 I will use Mobil 1 75w90 which is GL-5. It's $9.99 a quart at Autozone, easy to get and cheap, relatively.
  14. Aug 19, 2016 at 10:33 AM
    Qwntm
    Edward
    Boise, ID
    None...yet!
    Red Line is good stuff, run 100% red line in my Harley. Next time... :)
  15. Apr 29, 2018 at 10:27 AM
    #35
    msommer1420
    msommer1420 Well-Known Member
    Monroe, WA
    2016 TRD Sport DCSB Man. Trans
    It's the ring and pinion, I was a drivetrain mechanic for almost 20 years and we saw it all the time. Not really going to hurt anything just annoying
  16. Aug 5, 2018 at 8:10 AM
    #36
    Joisey
    Joisey Well-Known Member
    There is a "sweet spot" where the ring and pinion will operate with little to no noise. This setting is usually engraved on the head of the pinion gear as a + or - sign. Plus the standard depth setting, or minus the standard depth setting for THIS PARTICULAR set of gears to operates the most quietly. Once the pinion depth is set (usually by a shim behind the pinion gear or behind the pinion gear bearing race) the only remaining setting is backlash between the ring an pinion gear.
    It's NOT rocket science. All you need are the correct tools and an IQ above 85 or so and you can do it. THERE IS NO REASON FOR A RING AN PINION SET TO HOWL IF CORRECTLY SET. "Correctly set" includes inspecting the carrier and housing for runout.
    The factory dropped the ball for those owners saddled with a howling rear. IT IS NOT NORMAL.
  17. Aug 5, 2018 at 8:45 AM
    #37
    Grossomotto
    Grossomotto Complete 3rd Member
    39.9526° N, 75.1652° W
    2017 4WDV6LB6MT
  18. Aug 5, 2018 at 8:52 AM
    #38
    m603holden
    m603holden @Koditten Pirate Radio member #063
    Marteeen
    New England
    2017 Tacoma DCSB OR MT
    Lots of sail boat fuel
