Rear differential fluid replacement interval with Amsoil Severe Gear 75W-90
Discussion in '2nd Gen. Tacomas (2005-2015)' started by promethean-in-fla, Apr 22, 2019.
  1. Mar 22, 2023 at 9:37 AM
    kbecerra
    kbecerra Well-Known Member
    2006 Red Tacoma Double Cab Long Bed PreRunner
    Eibach Pro-Truck Lift (Stage 1), Deaver AAL, JBA STD UCAs
  2. Mar 22, 2023 at 9:41 AM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    If the gear oil says it’s already in it, then no. I see no need to add any more.
    I would have stuck with conventional oil myself. As some guys have had issues with synthetic oil in the LSD trucks.
    kbecerra likes this.
  3. Mar 22, 2023 at 9:56 AM
    kbecerra
    I’ll change it without adding the additive and report back the results this weekend
  4. Mar 22, 2023 at 10:21 AM
    2015WhiteOR
    2015WhiteOR Well-Known Member
    Gainesville TX
    LSD additive can always be added later if you notice chattering/skipping during turns.
    kbecerra and TnShooter like this.
  5. Mar 22, 2023 at 11:03 AM
    Hayden334
    Hayden334 Well-Known Member
    Hayden
    Cullman, Alabama
    2010 Tacoma DCSB TRD OR
    2" spacer lift, 285/70 R17's and a Softopper.
    This seems to be coming up a lot recently. I always point people to this article form ECGS https://eastcoastgearsupply.com/ft-2536-ecgs-gear-oil-recommendation.html I will be using Lucas 85w-140 going forward.
    kbecerra[QUOTED] likes this.
  6. Mar 22, 2023 at 11:32 AM
    TnShooter
    Deogee
    STOCK
    I would not recommend anything over 90 weight in the front. That’s coming from personal experiences. Others have had issues too. It’s not an issue that causes any real damage. But a front diff puking oil on the driveway is never fun. It quits eventually.
  7. Mar 22, 2023 at 1:13 PM
    kbecerra
    Thank you all for the replies. When I do the Rear Differential change this weekend and drive it around for a bit, I’ll post the results. @2015WhiteOR That was my first thought and about LSD additive from AMSOil just in case
  8. Mar 22, 2023 at 1:17 PM
    kbecerra
    Hayden334[QUOTED] and TnShooter like this.
  9. Mar 22, 2023 at 1:31 PM
    TnShooter
    Deogee
    STOCK
    You’ll be fine with that weight.
    It’s not the weight, it is the fluid type.
    Synthetic has been known to cause squeaks, chirps, and chatter.
    If you get those symptoms, you can try to add in some more additives and hope that fixes it.
    If not, going back to standard fluid usually fixes it.
    Not everyone has this problem, but some have and the fix was going back to a Non-synthetic fluid.
    Hayden334 likes this.
  10. Mar 22, 2023 at 2:07 PM
    Hayden334
    Hayden
    Cullman, Alabama
    The way I see it, as long as there is some kind of decent lubricating fluid in there it doesn't matter synthetic / dino. I was more interested in the data for temp and service life.
  11. Mar 26, 2023 at 12:52 PM
    kbecerra
    997CAB76-F0E9-4387-ACA3-D84D6BE613EA.jpg Ended up using 3quarts and AMSOIL “Slip Lock” LSD additive as a reassurance. Afterwards did a “Figure 8” with the truck 4 times to test out for any chattering and also to make sure the LSD additive gets worked in .
    I’m happy to say that there is no chattering or vibrations of any kind. I was trying my best to hear/feel even the slightest difference of any kind.
    BTW the previous gear oil that was serviced at Toyota from the previous owner came out like this!6DC8974C-046F-4293-881B-FB5FBF2055F5.jpg
    TnShooter likes this.
  12. Mar 26, 2023 at 12:58 PM
    TnShooter
    Deogee
    STOCK
    Good to hear.
    Thanks for the update.
