Rear differential fluid
Discussion in '1st Gen. Tacomas (1995-2004)' started by STEVEO13016, Aug 6, 2017.
  1. Aug 6, 2017 at 7:31 AM
    STEVEO13016
    STEVEO13016 [OP] Well-Known Member
    STEVEO
    2000 Tacoma Prerunner V6 2WD
    5100 Billy's set at 0" with 881 coils
    anyone have suggestions on what brand diff fluid to use?
    gmr102 likes this.
  2. Aug 6, 2017 at 8:32 AM
    austinsdad99
    austinsdad99 Well-Known Member
    1999 prerunner 3.4
    When I changed mine I just got the valvoline 85-90. Its for limited slip and everything. Seems to be doing just fine.
    lucky13don likes this.
  3. Aug 6, 2017 at 8:41 AM
    ThunderOne
    ThunderOne Well-Known Member
    Mitchell
    Nashville
    1ST GEN OR GTFO
    Toyota NERD
    It doesn't matter. Just get the correct rating and weight. I hate these threads
  4. Aug 6, 2017 at 9:33 AM
    mechanicjon
    mechanicjon They call me "Jonny Stubs"
    Jon
    Scottsdale Arizona
    04 Taco SC 4dr SR5 TRD Prerunner
    Supercharged, AEM FIC/6, Meth Inj, ION Alloy's, Radio & Phone steering Wheel controls,Fabtech AAL, Billie's wrapped with 880's , Tundra big brake conversion, bully bars and Pioneer DDin Stereo/dvd with exterrnal usb ports. 290K and going strong.
    I'm running Mobil One synthetic
    jjsul likes this.
  5. Aug 6, 2017 at 10:08 AM
    jammer
    jammer 2003 Toyota PreRunner 3.4L
    Ben
    Bentonville, AR
    2003 Lunar Mist Tacoma PreRunner 3.4l
    OME Coils/Bilstein 5100's front / 5125's rear 105 Amp Denso Alternator
    +1
    jjsul likes this.
  6. Aug 6, 2017 at 10:51 AM
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    Fwiw I got redline.
    Time for a new avatar man. I like your sig pic tho. Stupid photobriber. Did tcbob get photobucket to work on here? I thought I read that somewhere, but your avatar is still missing.
    Area51Runner likes this.
  7. Aug 6, 2017 at 11:21 AM
    ThunderOne
    Mitchell
    Nashville
    1ST GEN OR GTFO
    Toyota NERD
    Look closer at my avatar lol
    Yes tcbob gave a huge finger to PB and fixed everything.
    tcBob, Dalandser[QUOTED] and Key-Rei like this.
  8. Aug 6, 2017 at 11:34 AM
    Area51Runner
    Area51Runner Well-Known Member
    Northern California, Bay Area
    02 3.4 DC TRD PreRunner 4WD SWAP
    Agreed.
  9. Aug 6, 2017 at 11:40 AM
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    Rofl right on :thumbsup:
    IronPeak likes this.
  10. Aug 6, 2017 at 1:19 PM
    Indy
    Indy Master of all I survey.
    But but but, if I don't by exactly the right (whatever) my truck might blow up! Or something.
    Go to the store, go to the oil section, pick any that has the right weight rating. Done. 99.99999999999999999999999% of the difference between the brands is marketing.
    I used to work with a guy that did bottling. The only thing they changed between name and store brand was the color of the bottle.
    My father was the lead driver for flying J fuel. Flying J fuel, idenical to Loves, identical to about a dozen others. They all got in the same line, filled from the same tanks. The only difference was whichever refinery was the cheapest that day because thats where they all filled up from. Usually that was either Denver or Salt lake. No magic involved, no special ingredients. Just x thousand gallons and back on the road. Half the time the 'good' and the 'bad' brands come from exactly the same truck, same load. All the "burns cleaner" statements are meaningless marketing.
    ToxicTwin likes this.
  11. Aug 6, 2017 at 1:36 PM
    ToxicTwin
    ToxicTwin Money Talks...It Says Goodbye
    Robert
    Glendale AZ
    2009 TRD OR
    ^^^Definitely this^^^
    I too drive trucks and deliver freight to the "Racks" on a weekly basis. Every "brand name" fuel truck all lined up in the same line to pull from the same tanks....it's just marketing hype.
  12. Aug 6, 2017 at 1:43 PM
    KenLyns
    KenLyns 8.75" Third Member
    Belly of the Beast
    4x4 TRD Off-Road Full-Auto
    EIA diagram on typical gasoline distribution:
    There are, however, brand-specific additives and detergents added when the gasoline is transferred to the tanker truck (last step).
  13. Aug 6, 2017 at 1:50 PM
    NM Lance
    NM Lance Well-Known Member
    We are supposed to use straight SAE 90W for hypoid differentials... I have no idea where to buy this. I went to the dealership to see if they had some for sale and the salesman said they use bulk 80W-90, for all Toyota differentials, unless otherwise specified. WTH???
    The repair manual says you can use 80W-90 if the temperature is below 0 deg F. This is all I have ever used because it is all I can ever find, and I am not real comfortable doing it especially when the ambient temp is 100+ in the summer where I live. Having said all this, I have over 250,000 miles on my rear diff without any issues.
    To sum it up:
    I have absolutely no answer to your question, but I am here in case someone else has some sound advice.
  14. Aug 6, 2017 at 3:09 PM
    KenLyns
    Belly of the Beast
    ^Toyota specifies the minimum in the owner's manual, with the assumption that straight SAE 90 is the least costly and easiest to mfr. 80W90 is considered better than straight 90 because it flows better (like straight 80) when cold, and still behaves like straight 90 at operating temp. Generally any oil with the first number lower than 90 and the second number equal to- or higher than 90 would work. 75W90 (common synthetic grade) would work, as would 75W140.
  15. Aug 6, 2017 at 4:24 PM
    ThunderOne
    Mitchell
    Nashville
    1ST GEN OR GTFO
    Toyota NERD
    Even 80w-90 is hard to find around me, at least. I usually just put 75-90 in everything.
    NM Lance[QUOTED] likes this.
  16. Aug 6, 2017 at 5:06 PM
    01GreenTacoma
    01GreenTacoma Well-Known Member
    I changed mine with 80w90 yesterday.
  17. Aug 6, 2017 at 7:15 PM
    NM Lance
    It is tough to get 80W90 in my area too. I can find barrels of SAE 90 at Tractor Supply, but it specifically states "not for use in hypoid differentials" or something like that. So I guess that option is out. I use 75W-90 in my transmission, xfer case and front diff, but I have always been curious where to find SAE 90 for our application. If the dealership doesn't even use SAE 90, maybe 80W-90 is okay. Maybe I am just fixating too much on what the manual says.
  18. Aug 6, 2017 at 9:27 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    2002 XtraCab TRD 4x4 SCv6 AutoTrans With Lots of Mods ADS COs w/Compression Adjusters Camburg Uniball UCAs Whiteline Lower Control Arm Bushings Kartek 7" Limit Straps Plastics Guy Front Bumpstops Total Chaos Sprindle Gussets Custom Alcan Springs +800 lbs +3" ADS 10" Stroke Triple Bypass w/Resi Rear Shocks Custom Rear Shock Relocate All-Pro U-bolt Flip w/Timbren Bumpstops 4.88 Nitro Gears ARB Front Locker ARB Twin Compressor Black 17x8 Konig Countersteer Type X 285/70r17 Falken A/T3w Gunmetal 16x8 SCS Ray10s 255/85r16 Maxxis Bighorns Limited Edition (Relentless) Elite Front Bumper Smittybilt X2O 10K Winch Diode Dynamics SS3 Sport Selective Yellow Fog Lights in the Bumper Diode Dynamics SS3 Pro 4,000 Kelvin SAE Driving Lights with Clear Lenses on the Bumper Morimoto D2S Projectors XB35 Ballasts + 4300K Bulbs Badland Sliders FrankenFab Tire Carrier Swingout bumper w/kitchen BudBuilt Front & Bellypan Skids BAMF Rear Diff Skid Dometic CFX 55im Fridge/Freezer Alpha II Hardshell RTT Badland Custom Bed Rack Denso 210-0461 105 amp alternator Dual Northstar 24F AGM batteries BlueSea 7622 ML-ACR Battery controller Peak DBI Dual Battery Voltage Monitor Haltech IC-7 Display with Mako Dash Insert Haltech Elite 2500 Standalone ECU Magnuson MP62 Supercharger w/URD 2.2" Pulley Denso 650cc Fuel Injectors Aeromotive Stealth 340 Fuel Pump TransGo A340F Reprogramming Shift Kit Doug Thorley Headers 2.5" Magnaflow Hi-Flow CAT Magnaflow 18" Muffler w/Vibrant Resonator 13WL Brake Calipers Braided Steel Brake Lines Kenwood TM-71A Dual Band Ham Radio Larson 70CM/2M Antenna Midland MTX275 GMRS Radio w/Roof Mount Antenna Uniden 520xl CB radio 3' Firestik Adjustable tip antenna Pioneer DEH-P9400BH HU Alpine Amps & Type R components (F) and coaxials (R) Wet Okole Seat Covers Weathertech Digital Liners Deck Plate Mod 1" Diff Drop Carrier Bearing Drop
    redline 75w140
  19. Aug 6, 2017 at 9:43 PM
    mechanicjon
    Jon
    Scottsdale Arizona
    ROTFLMAO :rofl::rofl::rofl::rofl::rofl: GO TCBOB!!
