Rear differential fluid
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Frankenstein09, Mar 4, 2019.
  1. Mar 4, 2019 at 9:13 AM
    Frankenstein09
    Frankenstein09 [OP] Well-Known Member
    Russ
    NE Ohio
    06 TRD 4.0 SB
    Freshly stock
    I am just over my schedule rear differential fluid change. I haven't had it done yetvbecayet the dealer said it was something like $350 to do it. Any input on doing it at home. I'm very handy and own a good set of tools. Is it something someone can do or is it something a local shop can/ should do. What should I expect to pay to do it myself vs a local shop?
    TacoCasa and BassAckwards like this.
  2. Mar 4, 2019 at 9:15 AM
    BassAckwards
    2009 Tacoma AWD Turbo 2TR-FE
    This is a piece of cake to do yourself.
    There is a drain and fill plug on the rear diff. Remove the fill plug FIRST. Then remove the drain plug, clean the magnet while you wait for the fluid to drain, then put it back in and refill it with some 75w-90 or i like Lucas 85w140. Fill it till it starts running out of the fill plug onto the ground, and you're good to go
    ruffridha9, SR-71A, TacoCasa and 3 others like this.
  3. Mar 4, 2019 at 9:15 AM
    BassAckwards
  4. Mar 4, 2019 at 9:27 AM
    Lester Lugnut
    Lester Lugnut Well-Known Member
    N of Mex-S of Canada-E of LA-W of NC
    '15 Tacoma PreRunner V6 SR5 Auto
    Depending on your diff - the system holds from 3.2 - 3.6 qts gear oil - so you'll be charged for 4 qts. I could buy about 40 qts. of gear oil with $350.00. The dealer you dealt with is nuts. If you do not feel up to doing it - take your truck to an independent repair shop.
  5. Mar 4, 2019 at 9:30 AM
    gunn_runner
    gunn_runner www.gunnphotoservices.com
    Rocky River, OH
    2013 DCLB TRD
    OME 886 & Dakars. 35" Mickey Thompson Baja Boss
    As everyone said, it's super easy. $350 to do it at a dealership is highway robbery. Just make sure to put down some rags or a tarp folded under the diff if you're doing it on your clean driveway or garage floor. No matter how careful you are, some spills out!
  6. Mar 4, 2019 at 9:36 AM
    Frankenstein09
    Russ
    NE Ohio
    06 TRD 4.0 SB
    Freshly stock
    Awesome. I think I can do it. I asked the dealer why so much and how long would it take. They said half hour of labor. Which is probably 50 bucks. The rest they told me was the cost of the fluid. They service writer said that the price of the fluid has gone up a lot. Haha.
  7. Mar 4, 2019 at 9:38 AM
    timothom
    timothom Well-Known Member
    2014 Tacoma Access cab sr5
    Kenwood DMX7705S PrecisionPower Phantom 900.4 Alpine type-r 8" Image Dyanmics CXS64.2
    You can get good synthetic fluid like Red Line for about 25 bucks a quart shipped
    xxTacocaTxx and gunn_runner like this.
  8. Mar 4, 2019 at 9:45 AM
    eon_blue
    eon_blue Okayest Member
    Azusa, CA
    That's where they make their money on small jobs like fluid changes...which is why if you brought your own fluid in they would probably double the amount of labor time it would take. Or some places just flat out won't let customers bring in their own parts or fluids (that sounds weird).
    Diffs, t-case, trans and engine oils are so easy to DIY though that there's no real reason to take it in for that...save yourself the money
    Norton and whatstcp like this.
  9. Mar 4, 2019 at 9:46 AM
    Muddinfun
    Muddinfun Well-Known Member
    Your profile lists 06 TRD. That could be a sport or an off road. One of your other posts mentions a painted rear bumper. That would indicate that you have a sport. If all that is true, you have a LSD rear axle and you need to add the LSD friction modifier additive.
  10. Mar 4, 2019 at 9:52 AM
    Lester Lugnut
    DirtTaco likes this.
  11. Mar 4, 2019 at 10:57 AM
    Frankenstein09
    Russ
    NE Ohio
    06 TRD 4.0 SB
    Freshly stock
    Wow! Great detective work. Yes I do have TRD with a painted rear bumper. No rear sliding window. No clue what LSD is tho. Man do I feel embarrassed.
  12. Mar 4, 2019 at 10:58 AM
    eon_blue
    Azusa, CA
    If you have an 06 TRD Sport then yes you have a true, mechanical LSD (limited slip differential) and need to use gear oil that has the proper LSD additive in it, or buy the additive separately and add it in yourself.
    whatstcp likes this.
  13. Mar 4, 2019 at 11:08 AM
    DirtTaco
    DirtTaco Well-Known Member
    What would happen if the additive was not added to an lsd diff and it was ran like that
  14. Mar 4, 2019 at 11:10 AM
    Armkb
    Armkb Well-Known Member
    Hudson Valley, New York
    09 TRD Sport DCLB
    Bilstein 5100, OME 885X, LR UCA, ARB/EL095R, ES LCA Rack & Sway Bar Bushings, Yellow Wire Mod, ABS Switch, TPMS Mod, Scanguage, Toyota Bed Mat, WeatherTech Floor Liners, Extang Trifecta Cover, Fumoto Drain Valve
    LSD “Limited Slip Differential”. 2005-2008 Sports came from factory with it. Off Road models have the electronic locker. 2009 later Sports use the nanny system or ABS for its version of LSD.
  15. Mar 4, 2019 at 11:11 AM
    TacomaSport86
    TacomaSport86 2010 Tacoma/2016 4Runner Pro
    Easy to do and brand of fluid doesn't matter just get the correct type-viscosity. Get the cheapest one.
  16. Mar 4, 2019 at 11:13 AM
    AR15xAR10
    08 SR5 4x4 V6 IndigoInkPearl ACLBFTMFW
    22mm socket on a breaker bar, a drain pan and 3qt of lucas 85-140w conventional. Easy.
    Synthetic is NOT recommended
    EDIT, 24mm
  17. Mar 4, 2019 at 11:13 AM
    Lester Lugnut
  18. Mar 4, 2019 at 11:15 AM
    Lester Lugnut
    The drain/fill plugs on my rear diff use 24MM - maybe others are different.
  19. Mar 4, 2019 at 11:23 AM
    DriverSound
    DriverSound Señor Member
    Oregon
    2015 DCSB OR 4x4
    Too few to list.
    What's the reason for no synthetic?
    AR15xAR10[QUOTED] likes this.
  20. Mar 4, 2019 at 11:27 AM
    AR15xAR10
    You’re correct. My mistake.
    Its the same as the axle nut on my motorcycle, just had to check since its the one i always leave out on the top of the tool box haha
    Frankenstein09[OP] likes this.
