Rear differential fluid
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Frankenstein09, Mar 4, 2019.
  1. Mar 5, 2019 at 2:39 PM
    #81
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    If the rear is due I bet you the front, and transfer case are also due. Might as well knock it all out and be on the same schedule.
    This has all crush washers to service all 3 things. The front diff takes 1.6 quarts and the t case 1.2. So 6 quarts total oil, crush washers, and a pump. For the front diff you need a 10mm allen key.
    https://www.amazon.com/gp/product/B017V4BAXI/ref=oh_aui_search_asin_title?ie=UTF8&psc=1
  2. Mar 5, 2019 at 2:41 PM
    #82
    la0d0g
    running for the hills
    For crawling not hauling
    I'm really going to blow some minds now. I use synthetic in my tcase :violent:
    Hold.
    The.
    Fuck.
    On.
  3. Mar 5, 2019 at 2:44 PM
    #83
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    I do too. I use the 85w140 in my diffs but the 75w90 syn mobil 1 in my t case. And redline MT90 in my transmission
    la0d0g[QUOTED] likes this.
  4. Mar 5, 2019 at 2:49 PM
    #84
    la0d0g
    I refuse to crack open my transmission. Ever :D
    Frankenstein09[OP] likes this.
  5. Mar 5, 2019 at 2:49 PM
    #85
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    Are you a manual?
  6. Mar 5, 2019 at 2:50 PM
    #86
    la0d0g
    Yep.
  7. Mar 5, 2019 at 2:51 PM
    #87
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    *gasp* It's literally as easy as the diffs, just a drain and fill. I'm disappointed Matt.
  8. Mar 5, 2019 at 2:57 PM
    #88
    la0d0g
    It's not an effort thing. I'm one of those that think it's a perfectly balanced little environment in there. :anonymous:
  9. Mar 5, 2019 at 2:57 PM
    #89
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    :annoyed::frusty:
  10. Mar 5, 2019 at 2:58 PM
    #90
    la0d0g
    Well it is :D
    EatSleepTacos[QUOTED] likes this.
  11. Mar 5, 2019 at 2:59 PM
    #91
    Pork Chopper
    Pork Chopper Well-Known Member
    Dallas, TX
    07 DC 4x4
    Transfer case is super easy and same 24mm bolts. The front diff drain plug is notorious for stripping out since it's a 10mm hex. Word of advice for the front is to clean the hex holes out very good, use a quality hex socket and make sure it goes in all the way, and definitely loosen the fill plug first.
  12. Mar 5, 2019 at 2:59 PM
    #92
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    You're ridiculous haha if someone said that about their diffs, or engine oil, what would you say??
  13. Mar 5, 2019 at 3:00 PM
    #93
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    Good advice on using a socket 10mm
  14. Mar 5, 2019 at 3:01 PM
    #94
    la0d0g
    Basically "get fucked"
  15. Mar 5, 2019 at 3:12 PM
    #95
    la0d0g
    Maybe you've changed my mind.
  16. Mar 5, 2019 at 3:14 PM
    #96
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
  17. Mar 5, 2019 at 3:18 PM
    #97
    la0d0g
  18. Mar 5, 2019 at 3:21 PM
    #98
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    Just that the NS shifts even smoother than the regular MT90 stuff. If you search TW for "redline ns" some stuff comes up.
  19. Mar 5, 2019 at 3:34 PM
    #99
    la0d0g
    Thanks!
  20. Mar 5, 2019 at 7:44 PM
    #100
    Frankenstein09
    Frankenstein09 [OP] Well-Known Member
    Russ
    NE Ohio
    06 TRD 4.0 SB
    Freshly stock
    Oh boy. I don't know that I have time for all that haha. I might just wait until the next scheduled maintenance comes around to do them
