Rear differential fluid
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Frankenstein09, Mar 4, 2019.
  1. Mar 5, 2019 at 7:46 PM
    #101
    Frankenstein09
    Frankenstein09 [OP] Well-Known Member
    Russ
    NE Ohio
    06 TRD 4.0 SB
    Freshly stock
    Going to snatch up one of the wife's shampoo bottles with the pump and add some hose to the nozzel.
    jburner, 2WD and Pork Chopper like this.
  2. Mar 5, 2019 at 8:17 PM
    #102
    Muddinfun
    Muddinfun Well-Known Member
    I think that's going to take a loooooooong time.
  3. Mar 6, 2019 at 4:17 AM
    #103
    Larzzzz
    Larzzzz Grande' Ricardo
    Larry
    MA
    '06 dclb 350+ kmiles
    Aux back up lights, Bed lights, Re-located trailer plug, Good dooby, a.k.a. jumper cable mod, Heated seats, back up camera,
    That's understating it. I use one of those cheapo pumps for the tcase and front diff and it still takes a while. Drop the spare, and the rear diff is easy to fill.
  4. Mar 6, 2019 at 6:01 AM
    #104
    ejl923
    ejl923 Well-Known Member
    Eric
    Western Mass
    15 DCSB TRD Off Road
    My experience OP. First, find a coupon code for advance auto, buy online and pickup. I bought 6 qts of m1 and did front, rear, and tcase, fluid cost $50. Choose what you want I also bought washers, dealer or Amazon. Pump not needed for rear, but a short piece of hose attached to the tapered nozzle helps. Dont lose the hose! Others have already chimed in on procedure.
    For future notes, i did use a pump on the tcase, took forever for one qt-ish. Front diff i ran a hose down the engine bay and poured in a funnel. My only note on synthetic/conventional. I use synthetic in almost everything. I have noticed anything bad, and truthfully havent noticed anything better, use whichever. I use synthetic for temp ratings, but you'll be fine either way.
    Frankenstein09[OP] likes this.
  5. Mar 6, 2019 at 8:10 AM
    #105
    EdinCincinnati
    EdinCincinnati Well-Known Member
    Ed
    Ohio
    2014 4x4 TRD OR
    EatSleepTacos likes this.
  6. Mar 6, 2019 at 8:17 AM
    #106
    4wdExplorer
    4wdExplorer Well-Known Member
    Orange County, CA
    I like this but not enough capacity. I would like it to hold 4 quarts. Rear diff holds 3 quarts, so you will have to open the fluild pump 2 times which would be annoying and causing potential spillage/mess. Also would like to use this for the transmission to, 1.2L is just not enough.
  7. Mar 6, 2019 at 8:34 AM
    #107
    Lester Lugnut
    Lester Lugnut Well-Known Member
    N of Mex-S of Canada-E of LA-W of NC
    '15 Tacoma PreRunner V6 SR5 Auto
    Easiest way to refill the rear differential is from up above; not down below. Same for transmission fluid. Different size hose for transmission than differential.
    A length of 7/8" ID heater hose with a plastic hose barb splicer(Home depot/Lowes) secured by a hose clamp. This end goes into the fill hole on differential. A piece of string/rope/whatever can be used to secure it in place - wrapping string/rope around hose - then tie to any spot near-by. Keeps hose connected to fill hole.
    A funnel is inserted into the hose top-side. Pull back just a hair on the funnel to create a vent. Have all bottles of gear oil ready to go. Pour gear oil into funnel. Done in a blink.
  8. Mar 7, 2019 at 10:32 PM
    #108
    Frankenstein09
    Russ
    NE Ohio
    06 TRD 4.0 SB
    Freshly stock
    Ok so I ordered the gasket set someone posted on Amazon. Front rear and tcase. Do they all take the same fluid. Or is the transfer different?
    Pork Chopper likes this.
  9. Mar 7, 2019 at 10:49 PM
    #109
    michael roberts
    michael roberts Well-Known Member
    san diego
    07,4x4, white, AC.
    powder coated hood support.
    Only the manual transmission fluid is different.
  10. Mar 7, 2019 at 11:49 PM
    #110
    eon_blue
    Azusa, CA
    Rear diff, front diff, t-case and manual trans all call for 75w90 gear oil. Difference is that the manual trans takes the GL4 variety and the diffs and tcase take GL5.
  11. Mar 16, 2019 at 10:15 AM
    #111
    esotaco
    esotaco Well-Known Member
    Ed
    Fairfax, VA
    '13 Silver 4.0L AT SR5 4X4
    Just did my rear differential ('13 4.0L extended cab 4WD AT) at 48,000 miles for the first time and noticed that I drained less than 3 quarts (~2.9) and was able to add about 3.3 quarts. Anyone else notice this apparent volume discrepancy between the specified volume of 3.12 quarts and what I drained and refilled? I even had the truck on a slight downward angle to the rear due to the slope of my driveway and the height of the ramps I used. Thanks.
    BillsSR5 and Frankenstein09[OP] like this.
  12. Mar 16, 2019 at 1:48 PM
    #112
    Frankenstein09
    Russ
    NE Ohio
    06 TRD 4.0 SB
    Freshly stock
    Looking at fluids at Walmart yesterday. None said anything about any additive. What should I be looking for?
  13. Mar 16, 2019 at 1:49 PM
    #113
    Frankenstein09
    Russ
    NE Ohio
    06 TRD 4.0 SB
    Freshly stock
    Walmart by me didn't have the pump either.
  14. Mar 16, 2019 at 2:25 PM
    #114
    la0d0g
    running for the hills
    For crawling not hauling
    I'd go to an actual automotive store.
  15. Mar 16, 2019 at 3:49 PM
    #115
    Frankenstein09
    Russ
    NE Ohio
    06 TRD 4.0 SB
    Freshly stock
    Honestly I was there in search of some power steering fluid. That's a whole nother thread. Had a stiff spot in my steering. The whole ATF PSF thing is even more confusing. Just ordered the gear oil pump off Walmart.com for $5... Store pickup at the same store that didn't have one on the shelf??? Says they have them in stock.
  16. Mar 16, 2019 at 3:55 PM
    #116
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    Spray the u joint on the steering shaft with some PB blaster. Right where the shaft enters into the steering rack. I'd bet you a beer that fixes the stiff spot.
  17. Mar 16, 2019 at 4:19 PM
    #117
    AR15xAR10
    2013 TRD Sport 4x4 V6 ACLBFTMFW
    Or replace it, like we did.
    What an absolutely miserable process
    EatSleepTacos[QUOTED] likes this.
  18. Mar 16, 2019 at 4:25 PM
    #118
    Frankenstein09
    Russ
    NE Ohio
    06 TRD 4.0 SB
    Freshly stock
    Randy, you nailed it. I took it to the carwash and got the underbody washed and then loaded up the joint with pb and it's cleared up. Going to grease it tomorrow. Was also a bit shy of the cold low level on the ps fluid. After reading a lot of nonsense I decided to just buy valvaline atf for Dex and said f it we will see.
  19. Mar 16, 2019 at 4:26 PM
    #119
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    The pb is a bit of a band aid and only prolongs the life a bit, but it’s a good trouble shooting tool. The intermediate shaft should eventually be replaced but at least now you know what it is!
    AR15xAR10[QUOTED] likes this.
  20. Mar 16, 2019 at 4:28 PM
    #120
    Frankenstein09
    Russ
    NE Ohio
    06 TRD 4.0 SB
    Freshly stock
    Oh is that what it is? It's going bad? Just assumed it was gunked up from the salt.
