Rear differential fluid
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Frankenstein09, Mar 4, 2019.
  1. Mar 16, 2019 at 4:28 PM
    #121
    AR15xAR10
    2013 TRD Sport 4x4 V6 ACLBFTMFW
    There was no saving either of ours lol
    EatSleepTacos[QUOTED] likes this.
  2. Mar 16, 2019 at 4:34 PM
    #122
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    Seeing how yours is an 06, it’s likely going bad. Mine was shot. I could drive down the road in a straight line, but could turn the steering wheel from 11 o clock to 1 o clock, yet remain straight.
  3. Mar 16, 2019 at 4:44 PM
    #123
    Frankenstein09
    Frankenstein09 [OP] Well-Known Member
    Russ
    NE Ohio
    06 TRD 4.0 SB
    Freshly stock
    What's the cost for that? $$$
  4. Mar 16, 2019 at 4:44 PM
    #124
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    The oem part is about $175. Can get aftermarket for about half that, but I opted for oem.
  5. Mar 16, 2019 at 6:50 PM
    #125
    ejl923
    ejl923 Well-Known Member
    Eric
    Western Mass
    15 DCSB TRD Off Road
    I think mine was identical
  6. Mar 16, 2019 at 7:36 PM
    #126
    Pork Chopper
    Pork Chopper Well-Known Member
    Dallas, TX
    07 DC 4x4
    Some of the diff fluid will be down the axles.
  7. Mar 21, 2019 at 6:58 AM
    #127
    Geraldo's Taco
    Geraldo's Taco Well-Known Member
    2015 Pre-Runner
    Are you guys using a breaker bar or impact wrench to loosed the fill plug? I can't budge mine with a 1/2" ratchet wrench.
  8. Mar 21, 2019 at 7:03 AM
    #128
    TacomaSport86
    TacomaSport86 2010 Tacoma/2016 4Runner Pro
    Use a long breaker bar and a good socket
  9. Mar 21, 2019 at 7:05 AM
    #129
    Lester Lugnut
    Lester Lugnut Well-Known Member
    N of Mex-S of Canada-E of LA-W of NC
    '15 Tacoma PreRunner V6 SR5 Auto
    If it's really stuck, back the vehicle up on to ramps; then get underneath with a long breaker. A length of pipe fit over the end of a ratchet will give you a long breaker. Once it's loose you can drive off the ramps, level the vehicle and go from there.
  10. Mar 21, 2019 at 7:13 AM
    #130
    BillsSR5
    BillsSR5 Looking out for #1
    bill
    2014 SR5
    same with mine I got 2.5 qts. out and a lot of crud metallic buildup on the drain plug magnet. did mine at 49k miles first time I bought it used was never done by the previous owner
  11. Mar 21, 2019 at 7:49 AM
    #131
    Lester Lugnut
    I encountered the same when I did my '15 Tacoma and my wife's '14 4Runner. Both owners manuals called for an amt. of gear oil that did not reach the bottom of the fill hole. First time I've ever seen this with any RWD vehicle I've done Rear Diff. service on. Interestingly, the Tacoma owners manual calls for 3.66 qts. for a "2WD except PreRunner". That amt. of gear oil(approx.) is what it took to reach the bottom of the fill hole on the Tacoma and just slightly less on the 4R.
  12. Mar 21, 2019 at 8:44 AM
    #132
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    Yep, breaker bar and a 6 sided socket. 12 point you risk rounding it off. Or I'll put my wrench/socket on it and tap it with a big hammer to crack it free.
    But an impact would suffice if you don't have any luck any other way. Maybe a little heat on it too
  13. Mar 21, 2019 at 12:54 PM
    #133
    TheDevilYouLove
    TheDevilYouLove You can’t polish a turd, but you can polish a TRD
    Marylandistan
    2010 Tacoma TRD Sport Access cab 4x4 silver streak
    Regarding the front diff: After reading horror stories about the stripped front drain plug, I sprang for a quality Snap-On 10MM hex socket and made sure to clean out the hex hole on the drain plug really well and make sure the hex socket was properly seated before getting after it with a breaker bar. It was on TIGHT but did come out without any damage. I can see where they would strip easily if you rushed it.
  14. Mar 25, 2019 at 10:19 AM
    #134
    eon_blue
    Azusa, CA
    The biggest reason most people strip them is because they don't clean them out, that's what happened to me. Felt like the socket was in there but in reality it was packed with dirt so it was barely grabbing the plug, next thing I know it went from being a hex shaped plug to a round one. Also the metal they make the plugs with is super soft. I use a small chisel now to clean it out real good before attempting to take it off.
