Rear Differential Fluid
Discussion in '2nd Gen. Tacomas (2005-2015)' started by GorgeRunner, Nov 20, 2019.
  1. Nov 20, 2019 at 10:57 AM
    GorgeRunner
    GorgeRunner [OP] Out There
    2005 PreRunner
    Been slowly but surely getting this truck squared away since I brought and I'm down to the last task: changing the rear diff fluid. I have the locking differential(which came in real handy on a recent drive through deep sand), what's the best fluid I can use. Should I use LSD additives(on the truck)?
  2. Nov 20, 2019 at 10:58 AM
    BassAckwards
    2009 Tacoma AWD Turbo 2TR-FE
    75w90 for stock use, no LSD additives required.
    You can also step up to an 85w140 weight Lucas if you want a little more protection
    TireFire, whatstcp and b_r_o like this.
  3. Nov 20, 2019 at 11:03 AM
    Colin The Shots
    Colin The Shots Well-Known Member
    Colin
    B.C.
    SR5
    Isn't LSD additive used on 2005 - 2008 trucks with the mechanical LSD?
    BassAckwards[QUOTED] likes this.
  4. Nov 20, 2019 at 11:06 AM
    GorgeRunner
    2005 PreRunner
    I'm not 100% sure. I just read if you have the rear diff lock button it's LSD.
  5. Nov 20, 2019 at 11:06 AM
    Beretta4x4
    Beretta4x4 What makes the green grass grow? TTC#0114
    Josh
    Temple, TX
    6-speed death mobile
    It's not an LSD. I'm 100% sure.
    fatfurious2 likes this.
  6. Nov 20, 2019 at 11:08 AM
    TacomaWilly
    TacomaWilly Well-Known Member
    You only need the LSD additive for mechanical LSD which is 2005 to 2008 models as mentioned above ^
    I used 80W90 with Posi-Trac additive and it works like a beauty. No more shudder when I put the foot down on a tight corner.
    I personally don't see a benefit of using the synthetic (75W90). It's 3x the price and the conventional lasts two years anyways.
  7. Nov 20, 2019 at 11:08 AM
    eon_blue
    eon_blue Okayest Member
    Azusa, CA
    The rear diff lock and LSD are two different things. The rear diff locker is a locking differential, the LSD is a limited slip differential. TRD ORs come with the locking diff, TRD Sports from 2005 - 2008 come with the limited slip (and require LSD additive). 2009+ Sports do not have a real LSD, just a brake feature that mimics one.
    You can use gear oil with LSD additive in the locking diff if you want...but it's not necessary. Won't hurt anything though.
  8. Nov 20, 2019 at 11:12 AM
    Colin The Shots
    Colin
    B.C.
    SR5
    Oh ok I just thought the trd offroad still had LSD in normal operation and locked differential when the locker is engaged.
    GorgeRunner[OP] and Beretta4x4 like this.
  9. Nov 20, 2019 at 11:15 AM
    GorgeRunner
    2005 PreRunner
    I love it when the cheapest option is best. Is there really an advantage to heavier oil like 85-140?
  10. Nov 20, 2019 at 11:15 AM
    eon_blue
    Azusa, CA
    I don't know if the newer TRD ORs might have the same 'pretend LSD' braking feature that the 09+ Sports have...it very well might. But because there isn't an actual limited slip in them, no LSD additive is needed. Can't have a mechanical LSD and a locker in the same diff, two completely separate devices for traction.
  11. Nov 20, 2019 at 11:19 AM
    Colin The Shots
    Colin
    B.C.
    SR5
    Ok but I was talking about the original poster looks like he drives an 05. Anyway good info. I didn't know they were completely different.
  12. Nov 20, 2019 at 11:20 AM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    Nope standard open diff without clutch packs on the elocker diff (doesnt mater the model year)
    Elocker diff doesnt care if you put LSD additive in it. I rock mobil 1 75w-90 in my rear diff (that has LSD additive in it) without issue.
  13. Nov 20, 2019 at 11:21 AM
    eon_blue
    Azusa, CA
    Oh gotcha, I thought we were talking about the other guy you quoted earlier. Yeah it does say he's an 05, but since he has a TRD OR he has a rear diff locker and therefore no LSD, so no additive required.
    Beretta4x4 likes this.
  14. Nov 20, 2019 at 11:22 AM
    TacomaWilly
    I think heavier oil is for warmer climate + heavy usage. The hotter your diff. gets, the thinner the oil becomes and the less protection it can provide.
    eon_blue likes this.
  15. Nov 20, 2019 at 11:22 AM
    GorgeRunner
    2005 PreRunner
    This is why I asked about it. Learn something every day.
  16. Nov 20, 2019 at 11:24 AM
    eon_blue
    Azusa, CA
    a lot of guys that offroad their trucks really hard will put heavier gear oil in the diffs for added protection against heat that builds up fast when you're wheeling. But if you live in a really cold climate it might not be a good idea, since that heavier oil is thicker
    Beretta4x4 and NAAC3TACO like this.
  17. Nov 20, 2019 at 11:27 AM
    GorgeRunner
    2005 PreRunner
    I drive off road a lot, but definitely not wheeling. I need to get home. 75-90w should work for my mixed terrain driving.
    If the Walmart Supertech 75-90w at $6.95/qt is good, 3 qts and a $5 pump, about $25, well worth it.
    I used to race cars and spent a lot of time in Baja. I prefer to prevent as many problems as possible instead of (off)roadside repair. Can't win if you don't finish.
  18. Nov 20, 2019 at 11:28 AM
    Beretta4x4
    Josh
    Temple, TX
    You'll be perfectly fine with that. I run 75-90 in both of my diffs and wheel semi-frequently. This is also my DD.
  19. Nov 20, 2019 at 11:34 AM
    eon_blue
    Azusa, CA
    yeah that's totally fine. Most people still run the 75w90, including myself and I do wheel pretty hard sometimes. I've thought about doing a heavier oil but only because my pinion seal has a small leak and I'm hoping it will slow it down lol.
  20. Nov 20, 2019 at 6:39 PM
    burrito782
    burrito782 Shit Throwing Ape
    08 TRD Off Road
    Not a big deal, but I'd recommend just using the nozzle on the bottle and skip the pump. Seems cleaner and less of a hassle that way. In the past I used a pump but only because I was using a 1 GAL jug w/o nozzle of gear oil that required it. In the future I'm planning on just using the 1 QT bottles w/nozzle.
