Rear differential gear oil quantity, buy 3 or 4 qts?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by spitdog, May 24, 2020.
  1. May 24, 2020 at 8:25 AM
    spitdog
    spitdog [OP] Well-Known Member
    2015 Access Cab V6 4x4 SR5 MGM
    I know the specs call for a little over 3 qts. Will it actually take that or is 3 enough?
    2015 4.0 4x4
  2. May 24, 2020 at 10:42 AM
    tamer
    tamer hamerworx.com
    NorCal
    2015 TRD OR AC, MGM, 4x4, 6spd MT
    If you add up all the quantities of the diffs and transfer case it just about adds up to a whole number. I'd just plan to do them all at the same time.
    whatstcp likes this.
  3. May 24, 2020 at 10:54 AM
    pdaddy
    pdaddy WeLl-KnOwN mEmBeR
    Preston
    Central AL
    ‘13 DCSB Converted Prerunner 4wd
    Buy 4 quarts. By the time you’re toward the bottom of the bottle, you won’t be able to squeeze or pump the rest of the oil into the diff. Then once you’re all done, combine all the remaining oil you couldn’t squeeze out of the bottles and you’ll only have to buy 3 new quarts next time you do:thumbsup:
  4. May 24, 2020 at 11:16 AM
    spitdog
    Thanks, makes sense, that’s what I’ll do.
    pdaddy[QUOTED] likes this.
