Rear differential green gear oil WTF??
Discussion in '2nd Gen. Tacomas (2005-2015)' started by BlueT, May 28, 2010.
  1. May 28, 2010 at 4:07 PM
    BlueT
    BlueT [OP] Well-Known Member
    NorthEast
    07 Dbl Cab LB with LSD
    So my last change was done by dealer when they were doing suspension TSB in last winter and it was free. So I took a look at rear diff and oil is green like the antifreeze. Thats not synthethic oil is it? Any ideas? If it is synthethic I am not going to touch it since it is super clean.
    BTW my LSD preload is around 150 lb/foot of torque ( it takes around 150 lb/foot torque on the wheel to slip clutches.)
  2. May 28, 2010 at 4:24 PM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    Sometimes it'll turn green if you get water in the oil.....
    Have you been offroading at all? If yes.... are your diff breathers extended?
  3. May 28, 2010 at 4:27 PM
    mwild
    mwild I CANT SPELL SO DONT BITCH
    Vernon, NJ
    03 2500 Dodge Ram
    Cat-Back, weather techs, ipod and sisuis Old 04 Taco: 5100s At all 4 corners set at 2.5", Toyotec AAL, Gibson cat-back, Deck plate mod, 20% Tint on fronts, 10" Kicker Comp sub, Sirius radio, Bud Built Skid, Pro Comp 8069 Wheels
    Im not sure but i think the synthetic oil the toyota uses is green. If it was wet i would be milky and possibly green but very milky.
  4. May 28, 2010 at 6:23 PM
    BlueT
    NorthEast
    Ah its gone anyway but I doubt was synthethic, so I have Delvac in with GM additive. I can not hear chatter as used to be when synthethic was added. I mean so far this worked better then Mobil 1 + CRC or Amsoil additive. And I know my LSD is working. So maybe it will work. I will give good run over next 3 days and see what happens.
