Rear differential help needed!
Discussion in 'General Tacoma Talk' started by Nazareth7, Aug 29, 2025.
  1. Aug 29, 2025 at 1:35 PM
    Nazareth7
    Nazareth7 [OP] Well-Known Member
    2007 Tacoma 2x4
    How often do you guys change the fluid of the rear gear ⚙️ . And when you changing do you have to open the cover and clean the gears. or can I just drain and refill it ?. Thanks
  2. Aug 29, 2025 at 6:07 PM
    Homeline
    Homeline Well-Known Member
    2013 Access Cab 5-Lugger
    2" Leveling Kit, TRD skid plate, 16" Jeep wheels, Katzkin leather seats w/heaters, jump seat delete
    Not sure what Toyota recommends, but I do mine every 100k, which is about every 4 years. I use Redline syn 75w80 (5lug w/MT). Last change was at 200k, and fluid still looked, felt & smelled fine, with minimal sludge on the plug.
    No need to remove cover unless less fluid looks/feels suspect or pieces of metal come out.
    wilcam47 likes this.
  3. Aug 30, 2025 at 8:40 AM
    AvalonTaco
    AvalonTaco Falken Sales Rep.
    Joe
    Cabin in the woods
    2019 Super White DCSB OR
    Working on a lien delete for my title…..
    Per Toyota, every 30k, or for severe use, every 15k. As far as what we actually do, that’s all over the place.
    It’s relatively easy, easier than an oil change IMO. I plan on doing mine every 30k.
  4. Aug 30, 2025 at 8:52 AM
    ZColorado
    ZColorado Well-Known Member
    Near Boulder Colorado
    13 DCSB OR 6MT
    35's,Kings, NWF, 488, Harrop, SPC, Archive, Method, RCI, C4
    drain and fill with the closest weight to spec. Toyota spec weight is not common, but sits very close to what is common on the shelf.
    Ricardo13x likes this.
  5. Aug 30, 2025 at 9:32 AM
    fxntime
    fxntime Well-Known Member
    2015 Tacoma off road TRD and 2014 FJC
    Loosen fill plug first before you remove the drain plug and drain the fluid.
    ZColorado and AvalonTaco like this.
  6. Aug 30, 2025 at 12:55 PM
    RichochetRabbit
    RichochetRabbit Bing Bing Bing
    Hardest part for me on the rear differential and transfer case was scraping my useless butt under the truck on my back then rolling over just enough to manage the plugs/wrenches.
    The rear differential and transfer case plugs need a 24 MM socket ... get a 6-point instead of a 12-point to avoid stripping. I bought Valvoline squeeze bags for differential fluid to just push new fluid in.
    Assuming 4WD ... I used for 1-liter transfer case fluid the Toyota-brand (best price I think I saw was $100/liter) instead of "other". For the transfer case fluid use a manual fluid pump and the last final bit of expensive transfer case fluid may need a turkey baster to get in ... no joke about the turkey baster. For the front differential you can buy Lexus parts 90341-18060 and 90341-24016 as replacements that have hex heads instead of 10mm holes that can strip.
  7. Aug 30, 2025 at 12:59 PM
    andrewtheadventurer
    andrewtheadventurer Well-Known Member
    Andrew
    Somewhere probably
    Off-road Tenthouse
    an empty wallet
    Towing every 15k, normal 30k for me. Cheap and easy. I also flush trans every 50k because i tow
  8. Aug 30, 2025 at 1:08 PM
    AvalonTaco
    Joe
    Cabin in the woods
    A 15/16 socket works as well. Seemingly identical to a 24mm.
  9. Aug 30, 2025 at 1:20 PM
    545 Well-Known Member
    2015 Access Cab
    No cover to remove, these are third members diffs, not like traditional American diffs with rear covers
    60k miles or so change it out
  10. Aug 30, 2025 at 9:24 PM
    RichochetRabbit
    I had neither 15/16 nor 24 mm ... I had larger and smaller but needed to purchase. Still ... 6-pt instead of 12 pt is advisable.
