Rear Differential Howl
Discussion in '3rd Gen. Tacomas (2016-2023)' started by ConantTaco, Jun 9, 2021.
  1. Jan 30, 2022 at 7:39 PM
    #41
    lilallie
    lilallie Active Member
    2019 Tacoma TRD OR
    83k on my OR. Has the noise. No other problems.
    Indy183 likes this.
  2. Jan 31, 2022 at 11:52 AM
    #42
    zoo truck
    zoo truck Well-Known Member
    2020 quicksand sr5 tacoma
    None
    Little over 15k on my sr5, still no howling.....maybe not old enough yet?
    MOC221_ likes this.
  3. Jan 31, 2022 at 12:02 PM
    #43
    dan33410
    dan33410 Well-Known Member
    2020 Quicksand TRD Off Road
    I've got about 30k kms on my 2020 OR, had a bit of howl since new basically. I can only hear mine at highway speeds, around 80-90 km/h is most prominent. Above 100 and it gets quieter. With windows shut its hardly noticeable and any music you don't hear it at all. No issues so far.
  4. Jan 31, 2022 at 12:58 PM
    #44
    mquibble
    mquibble Well-Known Member
    Michael
    2021 TacomaTRD Pro
    Yea, now if he was a Marketing Expert that would change everything. As an engineer myself I run across DIY’rs with no formal education who are analytical, smart and clever. It’s not all about the degree. Experience in the trenches with someone with a good head on their shoulders oftentimes can come up with a better solution.
  5. Jan 31, 2022 at 1:05 PM
    #45
    Anton338
    Anton338 Ill-Known Member
    Anton
    New Jersey
    2018 TRD Off-Road DCSB
    Mostly electrical shit that nobody cares about.
    54k miles. No idea what you're talking about.
    Amorak likes this.
  6. Jan 31, 2022 at 6:30 PM
    #46
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    I understand and agree. In this case, it's hard to fix resonance. My Tacoma had it.
  7. Feb 1, 2022 at 7:19 AM
    #47
    Polaris425
    Polaris425 Well-Known Member
    2021 Tacoma TRD
    Mine does it... it's annoying. But only when the radio is turned off. Which is very rare.
  8. Feb 1, 2022 at 7:32 AM
    #48
    MOC221_
    MOC221_ 3 pedal metal
    Frank
    2019 DCSB Sport M/T Barcelona Red
    vF Tuned; ADM; Core SS
    I've had 2 3rd gens, both with this noise.
    The howl was louder in the 16 OR than in the '19 Sport. The lessening of the effects of resonance is probably due to mitigation efforts done by Toyota in production such as sound deadening in the cab, mods to cab mounts, changes to the leaf packs etc, that we first saw as a TSB for older trucks.
    For those who have never heard it, well that's great! It does exist though, just saying.
    hiPSI, bulalo and Smacky2020 like this.
  9. Feb 1, 2022 at 7:34 AM
    #49
    MOC221_
    Frank
    I mean it's possible, but some owners reported having the noise basically right off the lot or shortly after taking possession.
  10. Feb 1, 2022 at 7:36 AM
    #50
    schwartzki
    schwartzki Well-Known Member
    Midwest
    2020 Voodoo Tacoma TRD OR DCSB Prem/Tech/LED
    TRD Pro wheels, suspension & grill. KO2's, Front Window tint, Truxedo X15 Pro
    Mine howl's at 55-57ish mph. I am on my 3rd rear diff. 1st one at 5k, noisy, rear locker wasn't working and it would get stuck going in/coming out of 4LO. 2nd one at 15k for the same issue but less noise. 3rd one started quietly howling about 1800miles in and is still the same at 25k miles. 4wd works and diff has no metal in oil so it is what it is.
  11. Feb 1, 2022 at 12:52 PM
    #51
    Shades_Of_Red
    Shades_Of_Red Well-Known Member
    Lou
    Pittsburgh, PA
    2019 Tacoma TRD Off Road Premium Cavalry Blue
    A few.
    The Toyota tech who has a youtube channel thats been posted on here before recently did a video on the FJ Cruiser and stated that some of them had a howling issue as well. I owned a 2007 FJ for 3 years and dont remember hearing any howling with mine. I did end up with the transmission shudder he mentions after 100,000miles.
    Customer states my Toyota FJ Cruiser makes noises. Common Problems? - YouTube
  12. Feb 1, 2022 at 1:18 PM
    #52
    33yrsoftoys
    33yrsoftoys Over 40yrs now
    joel
    mid Michigan
    2021 dcsb off road 6 speed manual
    Bilstein 6112's 5th clip 1/4" spacer driver's side. Icon tubular UCA's with Delta joint, wheelers superbumps, ECGS bushing. Allpro standard leaf packs, 5160's, U bolt flip kit with wheelers super bump's, extended stainless steel brake lines, carrier bearing drop. Icon rebounds 17" with Nitto terra grappler G2's 285/70/17's.
    I've owned 6 Toyota 4x4 manual trucks starting in 1981. Every one of them had a diff howl. The e lockers seem to be a little more noticeable. I swear, if it didn't do it I'd be worried. LOL.
  13. Nov 23, 2022 at 12:46 PM
    #53
    junkyarddogg
    junkyarddogg Well-Known Member
    New Jersey
    2021 TRD Off Road
    I’m having the same issue. So there’s a chance it comes back after diff replacement? :( Mine happens around 45mph
  14. Nov 23, 2022 at 3:11 PM
    #54
    BillyE
    BillyE Well-Known Member
    Mine does not howl. However, the backlash seems higher than other vehicles I’ve owned. If backlash is too great, any gear set will howl. I wonder if they’re just adjusted loose from the factory.
  15. Nov 23, 2022 at 3:46 PM
    #55
    TacoTannerDeeznutz
    TacoTannerDeeznutz New Member
    2016 Tacoma TRD Sport
    2.5 inch lift with 33" Wildpeaks
    I was driving in the snow recently with really unaligned tires and a Check Vehicle Stability control alert popped up and won't go away. I have been driving with the icon on for the past couple of days and it works fine but the traction control light is constantly on and I'm wondering what it could be from.
  16. Nov 23, 2022 at 6:15 PM
    #56
    Rraiderr
    Rraiderr Well-Known Member
    Great White North
    2017 Tacoma TRD off road
    Working now a list
    My 17 had it, dealer did the TSB, it helped.
  17. Nov 23, 2022 at 6:26 PM
    #57
    cnstaco
    cnstaco Well-Known Member
    CO
    17 DCSB OR
    My truck makes all Kind’s of weird noises lol
  18. Nov 23, 2022 at 6:32 PM
    #58
    TacoMoose
    TacoMoose Well-Known Member
    2017 Tacoma OR
    My issue was fixed with mud tires and aftermarket exhaust
  19. Nov 23, 2022 at 6:34 PM
    #59
    Casey182
    Casey182 Well-Known Member
    Sacramento
    '20 TRD OR - '21 T4R ORP - '66 Chevy C10 SB
    Theres a million threads on this..... that being said... Bought mine at 52k and had the howl straight away. Bigger tires and exhaust fixes that though.
  20. Nov 23, 2022 at 8:36 PM
    #60
    InThePlains
    InThePlains Well-Known Member
    I had it bad, CPO 2019 6MT bought at 21k miles. I took it to the dealer they said it's normal.
    I changed the rear diff fluid at 30k, I only drained 3.1qt out, short of 1qt.
    Filled 4qt full synthetic fluid, it got substantially better.
