Rear Differential Howl
Discussion in '3rd Gen. Tacomas (2016-2023)' started by ConantTaco, Jun 9, 2021.
  1. Nov 24, 2022 at 5:44 AM
    #61
    zoo truck
    zoo truck Well-Known Member
    2020 quicksand sr5 tacoma
    None
    If i pull the front air dam from my truck, ill get a slight howl at 40-45 mph. I assume its wind noise thats happening with it removed. I had reinstalled it, and its no longer there.
    mquibble likes this.
  2. Jun 25, 2024 at 10:24 PM
    #62
    Anton338
    Anton338 Ill-Known Member
    Anton
    New Jersey
    2018 TRD Off-Road DCSB
    Mostly electrical shit that nobody cares about.
    Two years since my last comment. 83k miles. What howl?
    ERod27 and mquibble like this.
  3. Jun 26, 2024 at 6:11 AM
    #63
    bgavin
    bgavin Well-Known Member
    Orangevale, CA
    2023 Tacoma Access Cab, V6, 4WD, A/T, OTT Medium/Spicy
    CURT Mfg front receiver, anti-theft cages around cats
    When I was a Toyota tech in the last century, this was a common problem with passenger vehicles.
    There was a lube shop up the street that was changing out leaking driveshaft oil seals at the pinion shaft.
    The rack monkey was using an impact wrench to seat the pinion shaft nut, and over crushing the crush spacer that sets pinion depth.
    This ruined the correct pinion to ring gear spacing and trashed the differential.
    At that time I was rebuilding so many differentials that we stocked rebuilt spares for rapid swaps.
    I'd swap out the differential unit, get the customer out the door, then rebuild their core for the next swap.
  4. Sep 8, 2025 at 12:41 PM
    #64
    Dooba78311
    Dooba78311 New Member
    2021 SR5 double cab 2WD
    Mine Sounds like I’m driving over a cattle guard or a rumble grate between 47 and 55 mph. 47 mph is its loudest point. I just changed the rear differential fluid and it seems to be quieter at lower speeds, but it seems a bit louder at speed
