Rear differential information (ring and pinion)
Discussion in '4 Cylinder' started by elfuerte, Dec 30, 2009.
  1. Dec 30, 2009 at 2:05 PM
    elfuerte
    elfuerte [OP] Member
    09 PreRunner SR5
    K&N Magnaflow Jet Mass Air Flow Sensor
    HI, I have a question someone knows information about the rear differential. The reason is going to change the ring and pinion, and I need to know which is correct. anyone know where I can get this information. I look down ,but has no information in the differential . MY TRUCK IS 2009 ACCESS CAB 4X2 MANUAL ANYONE KNOWS HOW TO ORDER THE RING AND PINIONS FOR THIS TRUCK. WHAT SIZE IS OR THE SERIAL NUMBER.
  2. Dec 30, 2009 at 3:47 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    More info. What engine? Prerunner, or 4x4?
  3. Dec 30, 2009 at 3:54 PM
    afd23a
    afd23a Well-Known Member
    The Dynamo of Dixie
    05 Access Cab 5 Lugger
    Factory Fog Lights, Removed Secondary Air Filter, Metra Ipod Adapter, Int Wiper Stalk, Wet Okole's, URD Short Shifter, Scanguage II w/Blendmount, Fat Bob's 2.75" spacer lift, ARE topper, SP Performance Pads & Slotted Rotors, 4.10 gears
    You should have 4.10 gears assuming you're a 4cyl. You have an 8" ring which is referred to as the 8.4" Tacoma/T100 differential. More info would help about why you want to change the gears (larger tires, more power, etc).
  4. Dec 30, 2009 at 3:57 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    If he has a 5 lugger, the rear gears are different size and ratio
  5. Dec 30, 2009 at 4:08 PM
    afd23a
    The Dynamo of Dixie
    You're right, but I think he's got a Prerunner
  6. Dec 30, 2009 at 8:02 PM
    elfuerte
    09 PreRunner SR5
    Its a prerunner 4x2 manual, I want more power , I changed wheels and tires and lost power, and I want to back. Thank you.
  7. Dec 30, 2009 at 8:04 PM
    08pretaco
    08pretaco Well-Known Member
    az
    2014 Tundra 4x4 CM 5.7L SR5
    4.56 or 4.88
  8. Dec 30, 2009 at 8:11 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    You still havent mentioned what engine you have? We cant give you accurate info, if your not forth comming with what you have
  9. Dec 30, 2009 at 8:15 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Is it a loud screeching knocking type thunking noise, with a poping sound?
  10. Dec 30, 2009 at 8:17 PM
    08pretaco
    az
    ^ this is true. so the 2.7 and 4.0 have different gears? i thought they both had what like a 4.10 or something.
    oh and btw chris the guy at the alignment shop pissed me off, he said he couldnt get my caster to 2.7ish so its a 3.6 right now but he got the toe and camber how i wanted it.
    oh and also where in the service manual is the steering info, i can find things on steering not exactly on what i am looking for. when my wheels were getting aligned there was a clank when the wheel was turned which i felt in the wheel, i am guessing it has something to do with the steering joint (if thats whats covered by that black boot) that shows when you look into the wheel well.
  11. Dec 30, 2009 at 8:19 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    The 2.7 has 4:10's, and the 4.0 has 3:73's. The Alignment info is in the Specifications section of the FSM. Who did the alignment?
  12. Dec 30, 2009 at 8:19 PM
    08pretaco
    az
    Chris i think we have missed a big obvious thing here...this is posted in the 4 cylinder therefore i think he has the 2.7 HAHA
  13. Dec 30, 2009 at 8:20 PM
    08pretaco
    az
    big o did the alignment for me
  14. Dec 30, 2009 at 8:22 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    LMAO!! Good point.
    OP, Sorry about that :eek:
    Your gonna be past 3* with your spindles, and UCA's. Probably close to 3.5* or so. As long as the Camber and Toe are 0*, and the Caster isnt off by more than .5* or so from the left to the right, you should be good. The "Pop" sound leads me to think the LCA wasnt torqued enough to the spindle.
  15. Dec 30, 2009 at 8:25 PM
    08pretaco
    az
    its not a noise its a feel and i will torque it up again but i am 99% sure taylor and i torqued those bolts for the lca down good and to specs.
  16. Dec 30, 2009 at 8:26 PM
    08pretaco
    az
    to the op sorry for the slight thread jack.
    im looking to do regearing when i get new tires, id say go for the 4.56 if you see a lot of highway and 4.88 if your mostly around town :thumbsup:
  17. Dec 31, 2009 at 5:58 AM
    afd23a
    The Dynamo of Dixie
    It would help to know what size tires he put on there :rolleyes:
  18. Dec 31, 2009 at 6:26 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Yep.
  19. Dec 31, 2009 at 11:20 AM
    elfuerte
    09 PreRunner SR5
    I put 265/70 R16 my truck is 2.7 4cyl. and feel as if I had put so much weight with those tires.
  20. Dec 31, 2009 at 11:24 AM
    Dellosa89
    Dellosa89 Love peace and Taco Grease
    Brian
    Murrieta CA
    07 Prerunner TRD Off Road
    Fox 2.5 Coilovers, Camburg 1.25" UCA's, Icon RR, Icon aal,EVS foam bump stops, Borla Catback, HID Headlights and fogs, Defiant light bar, 3 hella 700 hid, Satellite Radio, Sony hu with 10'' sub, custom jetski rack, TRD seat covers, secondary air filter removed.
    go with a 4.56 ratio, 4.88 might not be highway friendly with only 31.
