Rear Differential Leak
Discussion in '1st Gen. Tacomas (1995-2004)' started by jasonvt, May 9, 2017.
  1. May 9, 2017 at 4:47 PM
    jasonvt
    jasonvt [OP] Well-Known Member
    Vermont
    2021 Tacoma DCSB TRD Off Road Manual
    My 2004 Tacoma started to leak from the rear differential. Looking for advice. There is oil on the bottom half of the housing and when parked, it leaked a spot on the ground.
    Dealer says I need to replace the housing, is that the entire axle? $2,100 with labor.
    More photos: https://goo.gl/photos/eKuG731vVU3RiKmd6
    Doesn't look like it's leaking from the front which I heard to check for... but what am I looking for with the pinion seal?
    Toyota did the frame replacement last year so I'd like to keep it, but don't want to do more then it needs.
  2. May 9, 2017 at 4:50 PM
    jjsul
    jjsul Well-Known Member
    James
    New Hampshire
    95.5 OME
    looks a bit gnarly.
    Maybe clean off all the rust and see what it looks like underneath?
    maybe score a clean(er?) rear housing from a pick and pull?
    Joe D likes this.
  3. May 9, 2017 at 4:53 PM
    Jerry311SD
    Jerry311SD Well-Known Member
    Jerry
    Ramona Ca SAN DIEGO
    2019 tacoma TRD Quicksand
    KDMaxx tune K&N drop in AFE catback Oil catch can Bill's 6112/5160 Dynomat whole inside of cab TRD skid plate
    wow I've never seen one rusted that bad.
    Junk yard would be your cheapest bet
  4. May 9, 2017 at 4:57 PM
    jasonvt
    Vermont
    Yes it's rusted pretty bad. I've had this truck in Vermont for it's entire life.
  5. May 9, 2017 at 5:00 PM
    Kens04Taco
    Kens04Taco Well-Known Member
    Sunland, CA
    2004 PreRunner 4x4
    kangs and thanngs
    Look on the forum or Craigslist for a complete axle with the drums. Disconnect the drive shaft, remove the bottom shock bolts unbolt the leaf springs, drop her out...pop the new one in. Bleed the brakes and go about ur way. just make sure you have the gear ratio you desire.
    FirstTimeFirstGen likes this.
  6. May 9, 2017 at 5:19 PM
    Smash8ight
    Smash8ight Well-Known Member
    04 trd
    Bone stock
    Mine busted a pin hole at the cable brace too.I attempted to patch it.....just made it worse,complete after market replacement with the addition of disk brakes will be in line next year.I refill the diff every oil change.
  7. May 9, 2017 at 5:42 PM
    Smash8ight
    04 trd
    Bone stock
    I found a link on here a week or so ago for a after market replacement.can't find it now.maybe someone can chime in....
  8. May 9, 2017 at 7:15 PM
    drr
    drr Primary Prognosticator
    Dan
    Seattle-ish
    02 4WD Tacoma
    Yeah that rust has definitely perforated the rear diff cover - those are pretty thin to begin with. As others have said, your best bet is to get a entirely new axle assembly. I'm guessing the rear drums, parking brake, etc. all look as bad, so replacing them is probably a good idea anyway.
  9. May 9, 2017 at 8:01 PM
    Your-10Ply-Bud
    Your-10Ply-Bud Should be fine, not my truck..
    Marshall
    Ontario, Canada
    2001 3RZ 4x4 5spd
    5-Stars/Satoshi 5100's/OME 881's TG AAL/Cooper AT3's
    If your third member is still okay (which it should be), you can just get a bare housing and swap the third member, axles and brakes over. It may be a bit easier and cheaper to find a bare housing than a matched-ratio complete rear end.
    I swapped mine into a new housing because it was leaking as well. Only cost me $200CAD for the rear housing from a wrecker (already pulled) and used my original third member.
    jjsul, Dalandser and Kens04Taco like this.
  10. May 10, 2017 at 5:40 AM
    Thad
    Thad Well-Known Member
    Thad
    Pittsburgh
    2004 Tacoma
    Barnes 4 wd sells a heavy duty weld on cover that will fix u right up!
