Rear Differential Leaking
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Bolt79, Nov 25, 2011.
  1. Nov 25, 2011 at 5:59 AM
    Bolt79
    Bolt79 [OP] Well-Known Member
    White Springs, FL
    2011 Tacoma Sport 4X4
    265-70-17 Goodyear Duratracs. Pro Comp 17x8 8089's. Bilstein 5100's front and rear (front set to 1.75). 1/4 inch spacer--driver side. TSB rear leaf springs. WeatherTech floor liners. EGR in-channel vent visors. RDS tool box.
    Yesterday, I noticed that my rear differential was leaking at the drain plug. I checked it and found the that the plug was loose. I don't know how it got loose--the truck only has 9600 miles on it and I've never messed with it. It must have vibrated loose. Makes me wonder if it was torqued properly at the factory.
    Anyways, I checked the fluid level in the rear end and while it wasn't level with the bottom of the fill hole, I could still stick my pinky in the hole and touch fluid. Does anyone know if this is enough fluid in the rear differential or should I add some to replace what I lost while it was dripping?
    Thanks.
  2. Nov 25, 2011 at 6:02 AM
    SampleFool
    SampleFool Three Percenter
    Ga
    Silver
    08 off-road
    Yes thats plenty enough to keep them lubed up.
  3. Nov 25, 2011 at 6:51 AM
    AndrewFalk
    AndrewFalk Science!
    The North East
    2010 5 speed 5 lug
    It should be just fine. You can always top it off if it makes you feel better.
  4. Nov 25, 2011 at 8:33 PM
    Bolt79
    White Springs, FL
    Yea, I'll probably add a little just for peace of mind.
