Rear Differential Lock? Electric Differential Lock?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by tcboss, Jan 21, 2008.
  1. Jan 21, 2008 at 9:49 PM
    tcboss
    tcboss [OP] Well-Known Member
    Wilmington, NC
    Black Mamba
    3 in. Revtek Lift, 33 in. M/T Open Country's,
    i dont know exactly how the rear differential works? this is comes standard on a TRD right?
    i have been off roading with tacomas that have them and it seems to work really well?
    i am just curious to if anyone can explain exactly how they work?
    and if you can purchase them aftermarket wise and how much?
    i think i read earlier in talk about toyota selling an ELD for (425.00 $) not sure if the are the same thing?
    thanks for any help
  2. Jan 22, 2008 at 2:53 AM
    concrete jedi
    concrete jedi Well-Known Member
    Rochester N.Y
    06 Tacoma 4 door indigo blue
    Broken and scratched tailgate, cracked rear tail light lens, coffee stain in driver seat.
    I'll give this a go... On the TRD off road your rear diff is an open diff until you "lock" it in, meaning that both wheels turn at the same time at the same torque, the ultimate in traction. LSD or Limited Slip Differential (TRD Sport Package) engages the other wheel when it determines that there is too much wheel slipage from the primary wheel, it however does not have the same torque. For everyday use LSD works pretty good, but when it gets nasty the locking diff is the one you need.
  3. Jan 22, 2008 at 2:58 AM
    ERdept
    ERdept Well-Known Member
    I got the Pre-Runner, TRD with locker. But, I didn't know that it was an open differential otherwise.
    This is the worst of the worst isn't it? Because unless the locker is engaged, it's the differential that spins the wheel WITHOUT traction, when it's in the rough, otherwise, right?
    Well, I guess it's OK for the street so far.
  4. Jan 22, 2008 at 5:30 AM
    Demoncleaner
    Demoncleaner Well-Known Member
    Upstate NY
    05 Dcab 6spd 4x4 TRD Sport w/Tow
    TRD exhaust Homemade bed mat & bed extender, front Drings, Short clutch throw, Summer: Stock 17's Winter: Blizzaks on 16' black steelies
    Open diffs are generally safer, but will have less traction. They will spin the one wheel with less traction taking off on snow or gravel. Thats where an LSD shines, and why I have it. No button to push, but it as concrete jedi exaplained its not a full locker and has limited ability to split the torque. Off road and one wheel in the air, LSD will be stuck, locker won't. Also, at speed in snowy/loose gravel conditions the back end can come around quicker and requires more finese and driver attention (Similar to why your locker has a '5mph speed limit").
    Of course you got a locker when your off-roading or need to bust up a snowy driveway (but dont use on roads), so you have a good combo.
  5. Jan 22, 2008 at 5:42 AM
    wormhole7
    wormhole7 Well-Known Member
    Lake Dallas, Tx
    TSS
    Leather, Suspension TSB, Billy 5100's up front set at .85, Eaton Posi LSD,Grillcraft Black Mesh Grills,Aires Bull Bar,Black Low Profile Narrow Toybox,Black Headlight Mod,Black Tail lights ,USA Spec,Ipod, PopnLock,Bed Mat,Bug Sheild,Vent Visors, Weathertec Liners,Radar,Nuvi 760,Dog Ramp,Convex Mirrors, Roof Rack, Tint, Borla exhaust, Borla Intake, OBX pedals, Home Link Auto Dimming Mirror with remote, 20" Factory Wheels, Factory Tube Steps
  6. Jan 22, 2008 at 7:34 AM
    mjp2
    Milton Juevo Portimous II
    NJ
    Current: '21 Bronco Badlands. Previous: '06 TRD Access Cab, v6, 6-speed
    I did a writeup in another thread awhile back:
    http://www.tacomaworld.com/forum/2nd-gen-tacomas/4653-simple-question.html#post43794
    Basically, get a limited slip if you're into street racing and a true locker for offroad. Limited slip differentials don't do much more than an open differential when you're stuck.
    Whether you opt for a selectable locker or an automatic one is a matter of preference. Personally, I'm a fan of the selectable one for its predictability.
  7. Jan 22, 2008 at 7:54 AM
    kymoonrunner1
    kymoonrunner1 New Member
    Eutawville,South Carolina
    PreRunner SR5 Mickey Thompson 265/75/16 Baha MTX M-T beadlocks w/ anodized lock
    Mickey Thompson 265/75/16 Baha MTX M-T beadlocks w/ anodized locks, Electric brake controller, boxed in rear frame and bumper brackets, 2 inch susp. lift in front
    I have a TRD with diff. lock, never need 4wd.When the chevys and fords are stuck they call me.
  8. Jan 22, 2008 at 1:03 PM
    wormhole7
    Lake Dallas, Tx
    TSS
  9. Jan 22, 2008 at 1:09 PM
    mjp2
    NJ
    Sounds like you're on track. The biggest thing is knowing your intended use. The most capable trail rigs on the planet are the last ones you want to cruise the highway in. I think you'll be thrilled with the improved performance with the LSD. :cool:
  10. Jan 22, 2008 at 3:06 PM
    piercedtiger
    piercedtiger Devout Atheist
    Jon
    Southern Tier, NY
    2015 F150 3.5EB SCEW 6.5ft
    The toyota locker uses an electric actuator rather than an air powered one like some after market ones like ARB. The ARB one requires a compressor, tank, air lines, etc. The toyota one is a box with wires and a switch that controls it. You can manually engage it with a screwdriver supposedly although I've never tried it. I found a write up on it a while back, but haven't seen it in a while. With an ARB, if you blow an air line, crack the tank, or the compressor dies you can't use the locker.
    Other mechanic lockers can use a ratcheting system to let the wheel rotate different speeds if needed (like cornering), but lock them together during normal operations.
  11. Jan 22, 2008 at 11:38 PM
    tcboss
    Wilmington, NC
    Black Mamba
    sounds like i would want a rear differiential lock or a true locker since i would want this for offroading....
    does anyone know how much these are running for? does toyota sell the rear differential lock seperate? i am deffintily liking the fact that it has a button to push.
    how much are the aftermarket lockers?
    thanks
  12. Jan 23, 2008 at 6:00 AM
    wormhole7
    Lake Dallas, Tx
    TSS
    Here is a link to an ARB
    http://www.trdparts4u.com/MC-CBFJ-JDJ.aspx
  13. Jan 23, 2008 at 3:08 PM
    concrete jedi
    Rochester N.Y
    You probably should have bought it from the beginning, with the cost and assache, you already behind the 8 ball. :(
