Rear Differential Lock Issues
Discussion in '3rd Gen. Tacomas (2016-2023)' started by ajmogen, Feb 17, 2017.
  1. Feb 17, 2017 at 4:44 PM
    ajmogen
    ajmogen [OP] Well-Known Member
    Aaron
    Wisconsin
    OR MT TACO T4R YARIS MT Corolla Hatchback MT
    To engage the rear locker I engage 4L, depress the clutch and press the rear lock button. It has always been finicky. I exercise the components on a regular basis, but it rarely locks immediately. I have to drive back and forth 10-20 feet to make the diff lock engage. I replaced the gear oil with Amsoil today. It didn't seem to help.
    Has anyone else noticed this issue and found resolution? Is it normal?
  2. Feb 17, 2017 at 4:53 PM
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    I have never had an issue getting mine to engage or disengage, I might have to move slightly but never 10 or 20 feet, you may wanna have the dealer take a look.
    ajmogen[OP] likes this.
  3. Feb 17, 2017 at 4:53 PM
    Brokinarrow
    Brokinarrow Well-Known Member
    Brian
    Garner, NC
    2017 Tacoma TRD Offroad
    Thangs and stuff
    thats norma. my 17 does this too and its auto. i thought it was a problem to begin with but its perfectly normal
  4. Feb 17, 2017 at 5:51 PM
    stevebaz
    stevebaz Well-Known Member
    2016 access cab, TRD offroad 4x4, Quicksand
    When your moving back and forth turn slightly so the rear axles are not rolling at the same rate. If the splines are not in alignment for the locker to engage they wont line up any better if axles are turning in the same rotation.
    ajmogen[OP], EB Group and shakerhood like this.
  5. Feb 17, 2017 at 6:04 PM
    BeaverNation
    BeaverNation Well-Known Member
    It helps to be in uneven terrain, it's easy to engage when you actually need it. Trying it just to see if it works on flat ground is where you'll have trouble.
    ajmogen[OP], Joe23 and zizzy34 like this.
  6. Feb 23, 2017 at 7:36 PM
    Mr Miagui
    Mr Miagui New Member
    Fred
    16 blue STRD 4d
    does the rear diff work on 4x4 Hi ?
  7. Feb 23, 2017 at 7:38 PM
    Bishop84
    Bishop84 Well-Known Member
    No, only 4 Lo.
    The instructions are by the door handle, and further 4x4 instructions are on the sun visor. :)
    E-Lockers are never instant and can take some fighting. Mine can engage in 2 seconds or 2 minutes.
  8. Feb 23, 2017 at 7:44 PM
    Mr Miagui
    Fred
    16 blue STRD 4d
    I previously ha a Frontier Pro-4X, and it was only in 4 lo too,
    Next to that, I had a F-150 FX4, and it was fonctionnal on 4 Hi, wich is pretty nice.
    I was wondering about de TRD PRO. thx for fast answer
