Rear Differential Lock Problem(?)
Discussion in '1st Gen. Tacomas (1995-2004)' started by El_Best_Hamon79, Sep 10, 2022.
  1. Sep 10, 2022 at 2:45 PM
    El_Best_Hamon79
    El_Best_Hamon79 [OP] Well-Known Member
    Abraham
    04’ Tacoma Prerunner
    Rear bed lights
    I drive an 04 Tacoma prerunner. It has a rear differential locker (I believe stock). So I clicked/pressed the read diff lock button the other day and the ABS lights turns on, but the read diff lock light on the gauge cluster blinks. I drive forward and it doesn’t engage. But when I start to turn the truck I hear the diff lock almost like a snap into gear. I and the same to turn it off. Do I need to replace the diff lock? I’m hoping not too since it’s like $800. Or do I need to maintenance it? If so how do I go about doing so? Or could it be something else?
  2. Sep 10, 2022 at 3:02 PM
    Andy01DblCabTacoma
    Andy01DblCabTacoma Well-Known Member
    Andy
    San Diego, CA
    01 Double Cab v6 4x4 TRD
    F: Kings SPC, R: 5100s+J59s. Custom armor.
    that is normal operation for the factory rear locker. You need to turn slightly to spin the wheels at different speeds so the locking collar can mesh. Just don't do it a high rate of speed or on high traction surface and you'll be fine.
    Dirty Pool likes this.
