Rear Differential Lock
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Krazie Sj, Dec 13, 2008.
  1. Dec 13, 2008 at 1:23 PM
    Krazie Sj
    Krazie Sj [OP] Resident Jackass
    Power Serge
    LV-426 (Acheron)
    07 TRD Off Road 4x4
    Borla Catback Exhaust, Snorkel, 33s on either 16's or 18's, ARB Bumper, All Pro LT w/Walker Evan Shocks front and back, All Pro expedition leaf pack, 10,000lb Superwinch, Intake Manifold Spacer, Bed Rack with ARB RTT, Rotopack and Hi Lift mounted, Husky Liner mats and an air freshener from 1995.
    So I had a question about the rear lock. If you do the mod where you can use the lock in 4Hi, are you still limited to 5-10kms/h while driving? Do they just want you driving that slow because it transforms the steering into that of an oil tanker?
    Case in point, say you were sand running and had the lock with 4Hi activated. Is it going to ruin something if you're doing say 50km/h?
    I know with 4Lo you're not supposed to exceed 30-40km/h because the engine speed is increased 2-3 fold.
  2. Dec 13, 2008 at 1:26 PM
    nvdeserted
    nvdeserted Well-Known Member
    Reno, NV
    2009 Tacoma TRD OR Access Cab
    Electric Dynolock tailgate, TrailGear Slides, , 285/75-16 Yoko Geolanders on Wheelers Type B, SAW 2.0 front and back, Camburg b/j UCA, 1.5" AAL, Ubolt flip, ARB bump.
    No. You just need to be going under 5mph to engage the locker. Once it's activated/engaged you can go as fast as you'd like... but most of the time, if you can go 15mph+ on said terrain, you probably don't need to be "locked" anyway, unless you're just using it to spin brodies or get it sideways around turns.
    And yeah, don't drive fast in 4lo.
  3. Dec 14, 2008 at 6:46 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    Are you still under warrantee?
    I've be VERY CAREFUL about the locker mod. If you ruin something - they won't cover it because you've modified the mechanical safety features.
    Like nvdeserted said - if you're going that fast, you shouldn't need the locker anyway.
  4. Dec 14, 2008 at 10:19 PM
    Krazie Sj
    Power Serge
    LV-426 (Acheron)
    07 TRD Off Road 4x4
    I'm just more worried about revving the engine, having the tires spin to a theoretical 50-80km/h and have something break on me because it's not meant to be spinning that fast. :)
  5. Dec 15, 2008 at 4:01 AM
    RCBS
    RCBS "Cause I'm mighty proud of that ragged old flag."
    Appalachia
    06 Main Runner OR
    keep it off pavement, concrete and you'll be fine.
