Rear Differential locked up while doing 55MPH
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Zappafan001, Jan 5, 2017.
  1. Jan 5, 2017 at 6:49 PM
    #61
    splitbolt
    splitbolt Voodoo Witch Doctor
    NW Arkansas
    2016 TRD OFFROAD DCSB MGM
    Casing bolts?
    Do you mean the propeller shaft bolts causing the pinion seal to become compromised?
  2. Jan 5, 2017 at 6:49 PM
    #62
    transworldmoto
    transworldmoto Well-Known Member
    Ben
    California Coast
    2016 Access Cab TRD OR 4X4
    Bingo Bango^
  3. Jan 5, 2017 at 6:49 PM
    #63
    su.b.rat
    su.b.rat broken truck
    craaazy!!!
  4. Jan 5, 2017 at 6:50 PM
    #64
    Taco Addiction
    Taco Addiction We found Jimmy
    Houston, TX
    2004 Black TRD Offroad
    Kings, SCS Wheels and other mall crawling crap
    Exactly. Diff fluid is one thing, bolts another.
  5. Jan 5, 2017 at 6:51 PM
    #65
    chuck1986
    chuck1986 Two in the Taco one in the Prius
    Tulsa, OK
    2017 TRD-OR Blue
    Lol.... um where is low diff oil a common issue?
  6. Jan 5, 2017 at 6:51 PM
    #66
    Clearwater Bill
    Billy
    Largo Florida
    New rear tires along with your new rear end may be in order.
    Because flat spot.
    landphil, shakerhood and dYL0n like this.
  7. Jan 5, 2017 at 6:51 PM
    #67
    Zappafan001
    Zappafan001 [OP] Well-Known Member
    Larry
    2016 taco trd sport
    Thanks everyone. I do appreciate it. It was 10 hours ago and I'm still reeling from it. and I agree. how the heck could the bolts come loose from the factory? What else is going to shake loose??
    I don't even want to drive this truck again at this point!
  8. Jan 5, 2017 at 6:52 PM
    #68
    smmarine
    smmarine Well-Known Member
    Melbourne FL
    2020 Kawasaki Vulcan S ABS
    It's fairly well documented on both 2nd and 3rd gens. So is low trans fluid
    busticator likes this.
  9. Jan 5, 2017 at 6:52 PM
    #69
    Zappafan001
    Larry
    2016 taco trd sport
    I'm thinking more along the lines of new truck or my $$ back and so long toyota.. :(
  10. Jan 5, 2017 at 6:52 PM
    #70
    chuck1986
    Tulsa, OK
    2017 TRD-OR Blue
    Check your lemon law state rules. You may be within the limits at this point.
    Taco Addiction, shakerhood and dYL0n like this.
  11. Jan 5, 2017 at 6:53 PM
    #71
    splitbolt
    NW Arkansas
    Amongst those of us who actually check it ourselves.
    I was low 1.25 quarts.
  12. Jan 5, 2017 at 6:54 PM
    #72
    MOC221_
    MOC221_ 3 pedal metal
    Frank
    2019 DCSB Sport M/T Barcelona Red
    vF Tuned; ADM; Core SS
    I apologize for my remarks, was convinced this was another troll thread. If you have the time and patience, could you show us what the dealership ends up putting on the paperwork as the cause?
    Frank
  13. Jan 5, 2017 at 6:57 PM
    #73
    smmarine
    Melbourne FL
    Google 2016 Tacoma low differential oil. Quite a few threads pop up
  14. Jan 5, 2017 at 6:58 PM
    #74
    smitty99
    smitty99 I also bought a 4Runner
    Scottsdale
    16 TRDORDCSB 4x4 A/T (loaded w/ JBL)
    6112s/5160s & 3-leaf AAL;ubolt flip kit;Superbumps
    Yep
  15. Jan 5, 2017 at 6:58 PM
    #75
    LuckyToy
    LuckyToy Well-Known Member
    4x4 Offroad
    I haven't heard about this. I'll go check my diff now...
  16. Jan 5, 2017 at 7:01 PM
    #76
    Zappafan001
    Larry
    2016 taco trd sport
    No worries my brother. I will if I get paperwork on it. I really have no intention of ever driving that vehicle again. The replaced the wiring harness a few months after owning it because they said the installer jammed a broken plug into a receptacle and that was shorting out and causing a brake override malfunction warning to come up on the dash. So if they can't put the wiring harness in correctly or torque the bolts on the rear diff correctly what else is wrong and will I be able to handle the next issue that I have.
  17. Jan 5, 2017 at 7:02 PM
    #77
    Zappafan001
    Larry
    2016 taco trd sport
    That is how I understand it.
  18. Jan 5, 2017 at 7:08 PM
    #78
    MOC221_
    Frank
    I can't say I blame you. I have some small issues but nothing like this. Good luck man, glad you're ok.
    Frank
  19. Jan 5, 2017 at 7:11 PM
    #79
    baron55
    baron55 Well-Known Member
    2025 Tacoma TRD Sport 4X4
    Wouldn't you have notice differential oil leaks under the truck where you park (garage/carport)? Something sounds fishy (dealer that is)
    ja1ck95 and Clearwater Bill like this.
  20. Jan 5, 2017 at 7:11 PM
    #80
    chuck1986
    Tulsa, OK
    2017 TRD-OR Blue
    I did.. one thread about it. Not many at all. And on that one thread quite a few people said thiers was full.
    Sorry but I am not seeing this as a common issue at all.
    Low trans on early 16s were...
    0210 likes this.
