Rear Differential locked up while doing 55MPH
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Zappafan001, Jan 5, 2017.
  1. Jan 5, 2017 at 8:21 PM
    #101
    splitbolt
    splitbolt Voodoo Witch Doctor
    NW Arkansas
    2016 TRD OFFROAD DCSB MGM
    Is yours full?
    Taco16LB likes this.
  2. Jan 5, 2017 at 8:29 PM
    #102
    chuck1986
    chuck1986 Two in the Taco one in the Prius
    Tulsa, OK
    2017 TRD-OR Blue
    Dont know. Had no reason to check before and still see no reason to mess with it now.
  3. Jan 5, 2017 at 8:35 PM
    #103
    jmaack
    jmaack Well-Known Member
    Justin
    Helena Alabama
    Skewped hood silver 4runner
    Ome, Sqeak free dakars, arms, skids, sliders.
    This.
    I doubt the assembly line puts third member in. But instead rely on a supplier who I am nearly 99.999999999% uses electronic torque tools torquing all bolts at once. Electronically. Which will kick out any and record that particular rear. For having to retorque.
    TacoFister likes this.
  4. Jan 5, 2017 at 8:36 PM
    #104
    GPsevinSixx
    GPsevinSixx Well-Known Member
    Ros Angerus
    2015twoAX2.4techPAWS
    6112/5160AALfnCNTSTRyokG015
    OP, I was on the 110 south at around 7AM. Was next to a MGM sport DCSB most of the way. Were you on around this time? I ended up passing you. I was in a white TRD OR. Couldn't do 55 constantly with LA traffic in the light rain.
    On the way home, saw another MGM sport with DCLB. Obviously not you, but these 3rd gens are bountiful now.
  5. Jan 5, 2017 at 8:43 PM
    #105
    splitbolt
    NW Arkansas
    How you approach you're own preventative maintenance is your prerogative.
    But, do you think the possibility exists, the reason low diff fluid is not a prevalent topic, is because it's just not getting checked?
    busticator likes this.
  6. Jan 5, 2017 at 8:51 PM
    #106
    chuck1986
    Tulsa, OK
    2017 TRD-OR Blue
    Preventative maintenance is done at 5/15/25/40/50k miles (take your pick on what needs to be checked). Not day one. I bet you didn't check EVERY single fluid on your brand new truck.
    I never said it couldn't be an issue. All I said was, rear diff fluid being low isnt a "common" issue. Most people cant check thier transmission fluid on their own. But it still became a prevalent topic and a known common issue.
    Not understanding your point in all this.
  7. Jan 5, 2017 at 8:52 PM
    #107
    splitbolt
    NW Arkansas
    Perhaps I missed your point.
  8. Jan 5, 2017 at 8:53 PM
    #108
    TACORIDER
    TACORIDER Just another statistic
    JAKE
    EAST TAWAKONI TEXAS
    12 TACO and some other Toyota’s
    I agree the Lawyer letter is very effective just because the headaches associated with it.
  9. Jan 5, 2017 at 8:56 PM
    #109
    Zappafan001
    Zappafan001 [OP] Well-Known Member
    Larry
    2016 taco trd sport
    I agree. I have not seen any oil leaks and I told him that when he suggested that either someone crawled under my truck and loosened the bolts in an attempt on my life or the bolts came loose today during my drive.
  10. Jan 5, 2017 at 9:02 PM
    #110
    signalbobby
    signalbobby Well-Known Member
    Robert
    Arizona
    18 Rapturd
    #turdgenproblems #lackofquality
  11. Jan 5, 2017 at 9:03 PM
    #111
    Zappafan001
    Larry
    2016 taco trd sport
    I did hear the howl about 1/2 hour earlier. Didn't know what it was. then a loud noise just before the wheels locked up
    shakerhood likes this.
  12. Jan 5, 2017 at 9:04 PM
    #112
    Zappafan001
    Larry
    2016 taco trd sport
    If you do, please share it with me!
  13. Jan 5, 2017 at 9:05 PM
    #113
    Zappafan001
    Larry
    2016 taco trd sport
    That is correct. Locked up as in the wheels stopped rotating and the rear end started to jump.
  14. Jan 5, 2017 at 9:06 PM
    #114
    TACORIDER
    JAKE
    EAST TAWAKONI TEXAS
    So bolts that hold the third member in I would assume. Have them look at some of the other nuts and look for socket marked. Pull a stud from the axle housing and see if it has loc tite. If I was going to intentionally lock up an axle on someone I hate I would unbolt the axle from the tube since it's only 4 bolts a size vs 16
  15. Jan 5, 2017 at 9:08 PM
    #115
    LuckyToy
    LuckyToy Well-Known Member
    4x4 Offroad
    I found one of a jeep dash cam video but he just slowed down to the side of the road, nothing crazy.
  16. Jan 5, 2017 at 9:10 PM
    #116
    Zappafan001
    Larry
    2016 taco trd sport
    The dealer can't admit it because if they do, they open themselves up for a lawsuit. I mean, if that is the case, then they nearly killed me today because of it. I got lucky but it could have been a fatality for sure.
  17. Jan 5, 2017 at 9:14 PM
    #117
    Zappafan001
    Larry
    2016 taco trd sport
    12,500 miles. It was at the dealer at 5 & 10k miles almost on the dot.
  18. Jan 5, 2017 at 9:17 PM
    #118
    Zappafan001
    Larry
    2016 taco trd sport
    But who would have touched them? I don't do any mechanical work on my cars. The only mod that I've made is a tonneau cover!
  19. Jan 5, 2017 at 9:17 PM
    #119
    Zappafan001
    Larry
    2016 taco trd sport
    That's interesting info. But how long would it take for the bolts to shake loose?
  20. Jan 5, 2017 at 9:18 PM
    #120
    LuckyToy
    4x4 Offroad
    Can anyone post a pic of which bolts we talking about here?
