Rear differential major damage
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Norm89, Mar 1, 2019.
  1. Feb 17, 2020 at 2:20 PM
    #381
    shane100700
    shane100700 Bed, Bath & Beyond Crawler
    Montana
    2019 DCSB, OR
    Rocket Boosters
    lol nice. Yeah, can’t use keyboard emojis in TW. They either translate funny or just don’t show up at all.
    my attempt at the same thing (iPhone) —> ‍♂️
    Edit; Cool does the same lol
  2. Feb 17, 2020 at 2:22 PM
    #382
    B4U2D0
    B4U2D0 Well-Known Member
    AIDS
    Disgusta, Ga
    20 Army Green TRD Pro
    At 33k now so if I subtract the multiple trips I made to Maryland and back this year probably between 18-20k.
    Like someone said earlier, either I need to upgrade the axel, stop driving how I drive, or trade it for something else... Leaning towards the latter.
  3. Feb 17, 2020 at 2:29 PM
    #383
    coopcooper
    coopcooper certified youtube mechanic
    alberta canada
    black on black on black 05 trd off road
    stickers and sticker accessory's
    buy a ford they have better rear ends
    whatstcp likes this.
  4. Feb 17, 2020 at 2:30 PM
    #384
    cruxofthebisquit
    cruxofthebisquit Well-Known Member
    Orange Texas
    2000 TRD
    OME and worth every penny.
    There are several 'rods' in there. It's a round hole. I would think that seems correct.
  5. Feb 17, 2020 at 2:31 PM
    #385
    Tacorific
    Tacorific Well-Known Member
    NE Iowa
    Barcelona Red 2018 SR5 I4 4X4
    Torque Pro, LED Map & Dome lights, Westin Hitch, Ride Rite Air bags with Daystar perches, Utility Package Rear Cab Panel
    You could take the ring gear to a metallurgist and see if they can identify why it failed. You may be able to convince Toyota that there was a pre-existing issue with the gear. Might be worth a shot.
    whatstcp and Slashaar like this.
  6. Feb 17, 2020 at 2:43 PM
    #386
    Slashaar
    Slashaar Trail Limo Supreme & Certified Hole Massager
    Josh
    Kansas City, MO
    2015 Tacoma TRD-Sport DC LB
    Coastal HC Front, 6112s+650lb King Coils, JD 62 Swap + 14" Fox 2.0s
    Wish I could've seen the gear oil at 30k (manufacturer's recommended flush/fill time) right before the blow out. Would've been a good insight into whether it was low, contaminated, or if there was signs of things breaking down (metal shavings/chips).
    I'd like to be a fly on the wall of the shop that took it in afterwards too to see the extent of the internal damage.
    Oh well. No idea. Most often cause of failure is lubrication, i.e. not enough fluid. If you do end up picking up another one, I'd check the fluid and make sure it's at the proper level. If not, then there's a problem all the way back to assembly/manufacturing. Could've just been a bad batch of underfilled differentials. No way to know unless you went out and checked everything they have on the lot lol
  7. Feb 17, 2020 at 3:27 PM
    #387
    Jowett
    Jowett Well-Known Member
    Brian
    North Adams, MA
    All the Toyota tech needs to do is plug the truck in and read the data. The EDR will spill the beans on what one has been doing with the truck.
  8. Feb 17, 2020 at 3:48 PM
    #388
    NYCTaco52
    NYCTaco52 Half man, half goat
    Somehow known as Stewart, but named Ben
    Ft Lauderdale, FL
    2022 Subaru Ascent
    That's what she said
    Gregw138, shane100700 and Slashaar like this.
  9. Feb 18, 2020 at 2:54 AM
    #389
    GreyBaldTaco
    GreyBaldTaco Well-Known Member
    2019 F150 5.0
    The sport does not have a true lsd that binds....
    shakerhood likes this.
  10. Feb 18, 2020 at 2:56 AM
    #390
    GreyBaldTaco
    2019 F150 5.0
    60k is the recommended flush fill time, not 30k
  11. Feb 18, 2020 at 3:06 AM
    #391
    mgmdclb
    mgmdclb Well-Known Member
    The Maritimes, Canada
    2018 MGM DCLB Sport
    I believe it’s just the brakes that mimic a LSD? Correct ?
    Slashaar and shakerhood like this.
  12. Feb 18, 2020 at 3:13 AM
    #392
    GreyBaldTaco
    2019 F150 5.0
    Yes, so how will that bind? It's an open diff.
  13. Feb 18, 2020 at 3:15 AM
    #393
    mgmdclb
    2018 MGM DCLB Sport
    Exactly, I don’t like to point fingers but this sounds like abuse. Seems odd to have 2 grenade like this.
  14. Feb 18, 2020 at 6:19 AM
    #394
    shane100700
    Montana
    2019 DCSB, OR
    Rocket Boosters
    The two in a row at relatively low mileage is the killer for me, and likely Toyota’s thinking too.
  15. Feb 18, 2020 at 9:54 AM
    #395
    B4U2D0
    AIDS
    Disgusta, Ga
    This shit blows my mind too. The only thing I can think of is I have a crazy steep driveway and always back up it. Nothing else in my mind seems to indicate that this would happen other than gunning it on occasion. Never go from reverse to drive quickly either. 95% of my driving is on pavement and I don't tow anything yet.
    I'll ask if I can get pictures of the old diff when I pick the truck up on Thursday and maybe get a copy of the computer data as well.
    Slashaar and shane100700[QUOTED] like this.
  16. Feb 18, 2020 at 10:39 AM
    #396
    shane100700
    Montana
    2019 DCSB, OR
    Rocket Boosters
    Yeah, I agree. Don’t think we are digging on you, just happens a lot where people
    join and talk about how they broke something. Far more times then not, they left some major details out.
    It’s def possible and I’m sure everyone else is looking forward to some final results. Most never come back, leading to more suspicion that it was abuse. Like the came here for sympathy or an angle to work with the dealer to get over.
    Again, very possible that’s not the case with you. You would be in the minority though.
    Slashaar and whatstcp like this.
  17. Feb 18, 2020 at 10:46 AM
    #397
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    It has the same brake actuated simulated LSD as the other models so there is nothing in there to bind up.
  18. Feb 18, 2020 at 11:02 AM
    #398
    Jowett
    Brian
    North Adams, MA
    The ELSD could engage, and, with enough force, shatter the differential spider gears/shafts as the torque attempts to feed to the wheel with traction. There are quite a few examples of 200 Series Land Cruisers blowing the inner CV joint when the ELSD activates.... seems plausible that we could be seeing this with the 8" diff on the Taco.
    Slashaar likes this.
  19. Feb 18, 2020 at 2:07 PM
    #399
    Slashaar
    Josh
    Kansas City, MO
    With brand new brake shoes? I'd imagine they'd lock up pretty good, sure not as much as a true LSD or a locker, but still. Over time constant metal fatigue could result in catastrophic endings.
    shakerhood[QUOTED] likes this.
  20. Feb 18, 2020 at 4:57 PM
    #400
    shakerhood
    Southern Ohio
    Seems like rear end failures are pretty low in general, cant recall but only seeing a few over the years, the simulated LSD set up is pretty durable.
