Rear differential major damage
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Norm89, Mar 1, 2019.
  1. Mar 1, 2019 at 12:58 PM
    #81
    Itchyfeet
    Itchyfeet Well-Known Member
    The axle housing new alone is likely over a $1000
    The center section new is likely around $1500
    This is just the bare bones stuff assuming the axle splines aren't gooched. If those are boned add another couple of hundred on the fire, plus the labor to swap the backing plates, brakes, pound in new axle tube seals, bleed the brakes swap all the ABS wiring and sensors, brake cables etc.
    People don't believe this but Toyota dealers really aren't interested in digging through Connor's stash of used Toyota parts to scare up a deal. The OP would be better off sourcing a rear end on car-part that was drum to drum
  2. Mar 1, 2019 at 12:58 PM
    #82
    ColoradoTJ
    ColoradoTJ Retired cat herder Moderator
    Colorado
    3500 Duramax, Roush Mustang, Jeep Crawler
    Taking ownership...much respect.
    Not the first time, nor last that I have seen a differential puking parts. Two years ago I seen a DynaTrac ProRock 60 crack and split the housing. It was awesome.
    We got the bare housing in the jig, alignment bar in place, nickel rod out, went to town. This was the break in trail....
    As others have said, there is no way in living hell I would pay the dealership 4500.00 to replace my rear axle. Junk yards ship, just saying.
  3. Mar 1, 2019 at 12:59 PM
    #83
    dnlskier
    dnlskier Well-Known Member
    17' TRD SPORT MT
    :pccoffee::rofl::rofl::puke: . Gotta clean the key board... :yes:- found it, TW was beginning to disappoint this Friday PM
    tcjacado, Robb_D[QUOTED] and JNG like this.
  4. Mar 1, 2019 at 1:00 PM
    #84
    fiftyxp
    fiftyxp Well-Known Member
    2017 trd offroad 4x4
    damn your wife can drive
  5. Mar 1, 2019 at 1:00 PM
    #85
    OriginalMan
    OriginalMan Well-Known Member
    Oahu 808
    2017 TRD OR 4x4
    Bilstein 5100/888; 5160/AAL; SCS Ray10 Limited Gold; 285/70 Cooper STT PRO; AVS; OVTuned; Prinsu Cabrac; RCI Bedrack; TC Bed Stiffner
    Are you blaming your wife for your the mess you created? :rofl:
    bajatacoguy likes this.
  6. Mar 1, 2019 at 1:01 PM
    #86
    4x4Runner
    4x4Runner Sam’s gone, man. Moderator
    Drunken Sailor
    Not north, not south, not west, mostly east
    1WD
    nuttin fancy
  7. Mar 1, 2019 at 1:02 PM
    #87
    Wulf
    Wulf no brain just damage
    rock raisin
    OP's "wife" was trying to do some sweet burnouts and/or redline launches to impress "her" friends :luvya:
    My Name is Rahl and StayinStock like this.
  8. Mar 1, 2019 at 1:02 PM
    #88
    StayinStock
    Bob
    Missouri
    Yes I do
    Some
    Not recommended. I use to work in a Dana factory and had no idea what I was doing. Now I make ice cream. Still no clue.
    Pigpen, inesshell, austin2009 and 6 others like this.
  9. Mar 1, 2019 at 1:03 PM
    #89
    BillsSR5
    BillsSR5 Looking out for #1
    bill
    2014 SR5
    StayinStock and My Name is Rahl like this.
  10. Mar 1, 2019 at 1:05 PM
    #90
    tcjacado
    tcjacado Well-Known Member
    Robb_D and My Name is Rahl like this.
  11. Mar 1, 2019 at 1:09 PM
    #91
    motodude95
    motodude95 Well-Known Member
    Jim
    2012 MGM TRD Sport DCLB, OME 886s, 33s
    Bunch of savages in here on a friday i see
  12. Mar 1, 2019 at 1:11 PM
    #92
    boynoyce
    boynoyce .
    16SR5AC4X4V6QS
    That's class right there
    And this too
    Props @Norm89
  13. Mar 1, 2019 at 1:11 PM
    #93
    tcjacado
    Only thing I see savage at this point really is that giant extra hole in that axle.
  14. Mar 1, 2019 at 1:14 PM
    #94
    magicgus323
    magicgus323 Well-Known Member
    Gustavo
    Visalia Ca. East LA LBC
    2016 White Tacoma Sr 2.7
    TRD rims and suspension, TRD grill, stereo iPhone mirroring stormtrooper decal backflip bed cover painted bumper and mirror caps
    I got the whole rear off a 2017 with 6k miles if interested for 1k
  15. Mar 1, 2019 at 1:15 PM
    #95
    BillsSR5
    bill
    2014 SR5
  16. Mar 1, 2019 at 1:19 PM
    #96
    OnHartung'sRoad
    OnHartung'sRoad -So glad I didn't take the other...
    Somewhere in the Mojave Desert...
    2017 Tacoma OR 4x4 (formerly 2002 OR 4x4, 1995 4x4 4Runner, 1985 4x4 Toy PU) ... and RIP’s (rust in pieces) to a Bronco II 4x4 & S10 Blazer 4x4
  17. Mar 1, 2019 at 1:20 PM
    #97
    OnHartung'sRoad
    Some jerk just stole mine!!!
    magicgus323[QUOTED] likes this.
  18. Mar 1, 2019 at 1:23 PM
    #98
    4x4Runner
    Drunken Sailor
    1WD
    nuttin fancy
  19. Mar 1, 2019 at 1:31 PM
    #99
    inesshell
    inesshell blah blah blah
    All stock Superwhite 10' AC
    yeah op, that wont be covered...especially spinning wheels in reverse
  20. Mar 1, 2019 at 1:39 PM
    #100
    TartanEagle
    TartanEagle Well-Known Member
    '17 ACLB 4x4 MT
    I am not passing any judgment about abuse, manufacturing defects, or proper techniques, etc. Nor have I witnessed any differential grenading that wasn't due to high stress put upon it. But I want to present a separate scenario and let y'all debate if it could produce these same results we see in the photo.
    Most of the comments state that the hole could only have been caused by a high speed projectile. But the tolerance between the ring gear and the case is very, very tight, almost nil! In fact, most rear case covers are shaped to just clear the ring gear.
    So with that thought, could the hole have resulted from a loose bolt (or gear chunk) which got pinched between the gear & case - and thus forced through the case wall? (The fact that a bolt (or other part) was loose / free inside is another discussion and, granted, it may have been set free by too high of speed or abuse.) I just can't discount (w/ my limited knowledge of diffs) that there may be a reason for the hole other than the wife slamming the xmsn between gears.
    What do you think?
    See post #159.
