Rear Differential needs replaced....60,231 miles
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Turbo-Taco, Jul 8, 2016.
  1. Jul 8, 2016 at 12:26 PM
    TallTallPines
    TallTallPines '10 Barcelona RC
    Opelika, Alabama
    Hit the road, Jack. Ain't no one got time for your bullshit whining.
  2. Jul 8, 2016 at 1:50 PM
    Turbo-Taco
    Turbo-Taco [OP] Well-Known Member
    Randy
    Portland, Oregon
    2024 Toyota Tacoma SR5
    Update: just spoke to the assistant service manger and he apologized that I was not explained what exactly had happened. Evedentally my differential falls under the TSB 0057-13, rear differsntial whine noise at 50-60 mph, although mine was most noisy at 30-45 mph. I was assured that the new differential carrier assembly is a bit different, more heavy duty, also different part #, than the original. Toyota has known about this for some time but will not issue a recall due to not all will have an issue. Personally I still feel someone screwed up and I told him that it was a huge coincidence that the day after it was serviced it needs replaced and he agreed it would be hard for him to accept it if the shoes were on different feet, however did assure me I am not the ony one out there that this has happened to. I guess I am just glad its getting done at no cost to me.
  3. Jul 8, 2016 at 3:08 PM
    Kyitty
    Kyitty Mr. Beard
    Bozeman, MT
    2015 Tacoma DCLB Better Than TRD
    See Build Page
    You forgot the "/rant" tag.
    For a web grammar nazi you sure did miss that one! You can't just begin ranting without the tag.
    <!-------- This space left empty intentionally.
    As for diffs. I put ECGS diffs front and rear on my truck with ARB Lockers & 4.56 gears. I've noticed that, presumably the front diff, makes a winding noise that is speed based. I took it to the local custom shop and called ECGS. Both think it's just simply because of the re-gear and the new thicker gears making more noise than the original ones. So far as I can tell you can't hear it from outside of the truck. You just hear it in the cab.
    I've put a couple thousand miles on it and it still does it. The truck runs just fine too!
  4. Jul 8, 2016 at 10:57 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    My thoughts exactly. Too much of a coincidence that it just happened to take a crap right after a service.
    But good luck getting them to admit it. The best part is you don't have to pay. :)
    shakerhood likes this.
  5. Jul 9, 2016 at 3:22 AM
    bigfoote13
    bigfoote13 Well-Known Member
    Joe
    South Florida
    15 TRD SPORT
    2016 Sport suspension 1/2 spacer up front and aal in rear SCS Stealth 6 17 inch wheels Wildpeak AT3 265 70 17
    Or maybe the wrong fluid all together.
  6. Jul 9, 2016 at 4:37 AM
    Jimmyh
    SC
    2012 Prerunner SR5
    He peed in it! :eek:
  7. Jul 9, 2016 at 6:33 AM
    Marshall R
    Marshall R Well-Known Member
    Marshall
    07 White TRD double cab
    none
    2800 lbs isn't much weight, but 7000 miles a year is a lot of towing. I've read of rear axles going bad on these from guys who tow a lot. But usually after more than 60,000 miles. The version with the locking rear axle seems to fail sooner. Supposedly not as heavy duty.
  8. Jul 9, 2016 at 6:35 AM
    moe2o4
    moe2o4 Well-Known Member
    Corey
    Pittsburgh PA
    2016 SR Silver 2.7L 5 Speed
    OME 3" Lift, 32" Tires, Lots of Mods!
    Time for a air locker!!!!! :goingcrazy:
  9. Jul 9, 2016 at 8:12 AM
    Shelf Life
    Shelf Life Well-Known Member
    Rob
    Central Oregon
    '06 ACC CAB 4x4 TRD OFF ROAD
    I'd have to agree with this. The fact that the dealer is so quick to change the diff sounds like they know they're the ones that screwed it up.
  10. Jul 9, 2016 at 8:16 AM
    Iamraiderpower
    Iamraiderpower Well-Known Member
    My 15' rear diff took a shit @8k miles :D
  11. Jul 9, 2016 at 8:17 AM
    Pigpen
    Dan
    Northwest Montana
    :eek:
  12. Jul 9, 2016 at 8:18 AM
    Iamraiderpower
    Yup I've got a thread on here about it, also my front wheel bearings took a shit at 10k miles
    Pigpen[QUOTED] likes this.
  13. Jul 9, 2016 at 12:17 PM
    timothom
    timothom Well-Known Member
    2014 Tacoma Access cab sr5
    Kenwood DMX7705S PrecisionPower Phantom 900.4 Alpine type-r 8" Image Dyanmics CXS64.2
    Driver's side wheel hub on my 2006 Silverado went out at about 20k. Had 3 other guys at work with the same year pickup/Avalanche do the same thing, driver's side.
  14. Jul 9, 2016 at 12:22 PM
    bigfoote13
    Joe
    South Florida
    15 TRD SPORT
    You were probably just looking to upgrade to a 4 runner and ungreased the bearing and unlube the diff. o_Oo_O
  15. Jul 9, 2016 at 2:39 PM
    #35
    Iamraiderpower
    Lmfao! :D
  16. Jul 12, 2016 at 9:28 AM
    #36
    tgear.shead
    tgear.shead Well-Known Member
    Wow, that's a weird service bulletin. It applies to open differential, but is restricted to when paired with **5 speed automatic**. Yet the same part also applies to vehicles equipped with 4-speed automatic, 5-speed manual, and 6-speed manual.
  17. Jul 13, 2016 at 9:41 AM
    #37
    Turbo-Taco
    Randy
    Portland, Oregon
    Update: Just got my truck back this morning, noise is gone at least for now, feels like the first day I drove it off the lot again. I was informed no towing for the first 500 miles and must retrun in 1000 miles to have the fluid changed and everything checked.
  18. Jul 13, 2016 at 11:56 AM
    #38
    timothom
    Well lets hope you get 400k miles out of it with towing :)
