Rear Differential not engaging?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by MedlinAround, Oct 26, 2015.
  1. Oct 26, 2015 at 2:12 AM
    MedlinAround
    MedlinAround [OP] Failure is the result of letting setbacks stop you
    Cody
    Kentucky
    2008 TRD off-road edition Tacoma
    Bilstein 5100's, OME 885X Coils, Dakar HD Springs, Fox 2.0 Rear Shocks, Magnaflow exhaust, Volant Intake, OKledlight pods, Front Skid Plate, Weathertec Floor Liners, Custom Bed Rack, TRD Nation interior LED dome kit, 4X innovations sliders, DIY Roof Rack, Smittybilt RTT.
    Tried to engage my rear diff lock and couldn't get it to go in. Tried turning the wheels and everything, just beeped and showed the blinking light. Think it went out or what could be wrong with it now?
  2. Oct 26, 2015 at 6:34 AM
    127.0.0.1 AKA ::1
    /etc/hosts
    2013 NBM AC 4.0 4x4 Auto OR
    when was the last time it did work ?
    if you are in low range
    keep trying, might take 15 minutes and 50 feet of driving forward and backward slow a few times to make it pop if it is 'sticky' from lack of use
    do this on a dirt road for best results
  3. Oct 26, 2015 at 6:38 AM
    Large
    Large Red
    Shouldn't be beeping. I think you are still in 4H
  4. Oct 26, 2015 at 8:38 AM
    skiergd011013
    skiergd011013 Well-Known Member
    2010 TRD Offroad 4x4 AC SSM
    if it was beeping, i suspect he wasn't even in 4lo. The only time i've been beeped at is trying to switch into or out of 4lo wrong. I suspect he may have turned his switch right to 4lo, without first being in 4hi. That'll trigger the beeping
    DoorDing likes this.
  5. Oct 26, 2015 at 8:41 AM
    skiergd011013
    Mine will lock if i 1)engage 4hi 2)shift to N 3)engage 4lo 4)press diff lock button 5) roll forward or back
  6. Oct 26, 2015 at 8:46 AM
    Large
    Large Red
    yes correct .. I just worded my statement a little wrong
  7. Oct 26, 2015 at 9:00 AM
    skiergd011013
    and once he finally gets it, he should use it monthly to keep it moving. At least i do anyways..
  8. Oct 26, 2015 at 11:06 AM
    MedlinAround
    Cody
    Kentucky
    How I usually get it to kick in. Maybe I had the button engaged too early and rolling forward and back from a dead stop and it wasn't kicking it in? Its been awhile since I've used it (6months), so I figured it just figured something went wrong with it. When I get off blacktop, I'll give it another shot.
  9. Oct 26, 2015 at 2:22 PM
    Holeshot
    Holeshot Well-Known Member
    Gary
    Alabama
    15 Doublecab TRD Off Road 4 X 4
    This works for me. I have noticed monthly use makes the engagement easier. Also disengagement.
  10. Oct 27, 2015 at 1:33 AM
    Backt
    Backt Well-Known Member
    Oregon
    2012 Tacoma DCSB Off Road Pryrite Mica
    For the last month I've tried to use mine as much as possible just to get it to engage and disengage easier. It still will not do it without some movement. Is this common and what's the use if you really need it to get unstuck?
  11. Oct 27, 2015 at 1:48 AM
    David K
    David K Well-Known Member
    Pala Mesa, California
    2010 4WD Off Road DC
    It is so sweet that A-TRAC has 0 issues working, gives more traction than the locker, and life is all good!
    But seriously, a monthly engaging of LOW RANGE and the locker should keep it nimble for that "emergency only" application it is labeled for.
    In case it wasn't covered, the beeping is the L4 not being engaged, not the locker. The locker light blinks when it isn't locked if you press its button and goes solid when it is locked. Only works in L4, once you are in L4.
  12. Oct 27, 2015 at 5:36 AM
    127.0.0.1 AKA ::1
    /etc/hosts
    it will engage when you need it. spin the wheels slowly a bit when you are stuck, forward and reverse.
    don't overthink it, gears have to mesh and rarely are they lined up perfect when you
    hit the switch
  13. Oct 27, 2015 at 6:32 AM
    scottfarm
    scottfarm Well-Known Member
    Florida
    tacoma 4X4
    aires 3D mats, scan gauge II, rear differential breather relocation, and bakflip G2 bed cover.
    Make sure it is in neutral when you push the diff. switch. If it does not go in shift to reverse, then to drive, then back to neutral then turn diff switch off and then back on. Repeat until it engages.
  14. Oct 27, 2015 at 6:36 AM
    Josh828
    Josh828 Well-Known Member
    Josh
    Avery NC
    14 White TRD Off road, Mid travel mountain truck
    FOX 2.5 extended travel, Fox 2.0 rears, LR UCA, XSPX rims, some light bars, and switches
    Why is it that turning your steering wheel will help the REAR diff lock?
    If mine doesn't want to lock up turning the steering wheel a little aways works
  15. Oct 27, 2015 at 7:41 AM
    127.0.0.1 AKA ::1
    /etc/hosts
    it this a serious question ? try driving and steering on pavement with rear end locked, do you feel the tires fighting
    angular velocities ?
  16. Oct 27, 2015 at 8:43 AM
    127.0.0.1
    127.0.0.1 AKA ::1
    /etc/hosts
    I disagree with this 'be in neutral' thing
    I hit locker while moving forward... 20-30 feet before I need it, it always goes into lock by the time I get to known nslippery spot
  17. Oct 27, 2015 at 9:16 AM
    127.0.0.1
    127.0.0.1 AKA ::1
    /etc/hosts
  18. Oct 27, 2015 at 9:17 AM
    David K
    What always works (for my truck): Push Button creep ahead slow. If light is not solid, turn steering wheel to one direction (left or right) and then creep ahead in that direction. Light goes solid in a few feet!
  19. Oct 27, 2015 at 7:40 PM
    Josh828
    Josh
    Avery NC
    For instance, I'm in 4low.. Im completely stopped, I hit the Rear diff, nothing happens, I turn my wheel left and right a little, it engages, No moving of the truck, just the front wheels going left and right..
    I understand binding ect but just turning the wheel while the back wheels aren't moving at all shouldn't help it slide in gear...
  20. Oct 27, 2015 at 7:51 PM
    Backt
    Oregon
    That is exactly what I do as well and it always works. My concern is if I'm ever stuck and can't creep any direction. I haven't thought that spinning the tires would essentially be the same as moving forward which would line the gears up and it would engage right?
