Rear Differential Oil change
Discussion in '2nd Gen. Tacomas (2005-2015)' started by rkilgore76, Oct 21, 2017.
  1. Oct 21, 2017 at 6:30 PM
    rkilgore76
    rkilgore76 [OP] Well-Known Member
    Richard Kilgore
    beaufort,sc
    2011 toyota tacoma
    Focal 165a component,Focal 165 coax,Avic930bt,Fosgate amp 75x4.Box by Mr.Marv,10 inch Pioneer shallow mount,Rockford amp.
    Hello!
    Thank you for any help,I have a 2011 Toyota Tacoma double cab pre runner 4.0 v6 2w drive,I wanted to change my rear differential gear oil,I was wanting to know what kind to use or what do you guys use,I seen in my book it said 75-85 gear oil,The last think is does anyone have a part number for the crush gaskets i would need to replace the old ones from the drain plugs?Thank you so much!!I did see this oil,was not sure if this would be the one.
    Mobil 1 Synthetic Gear Lube, LS 75W-90?
    Rambo54 likes this.
  2. Oct 21, 2017 at 6:32 PM
    Hartford
    Hartford Well-Known Member
    Maine
    2011 Acc Cab 5spd
    you can use that Mobil 1 and it works just fine. you also don't need new crush washers. only get them if you want to. they usually work fine for a couple of changes be fore they start to leak.
    rkilgore76[OP] and 07 sport 4x4 like this.
  3. Oct 21, 2017 at 6:46 PM
    757yotas
    757yotas Well-Known Member
    Virginia
    2007 TRD Sport
    ICI Magnum front bumer Rigid LED lighting OME lift 285/70 Nitto Exos 17" Fuel Hostage TRD Exhaust TonnauPro Cover Oil Catch Can Tint Pioneer Nav system Sound System LED lighting Euro headlights Paint
    Get any 80w-90 gear oil and call it a day
  4. Oct 21, 2017 at 6:49 PM
    rkilgore76
    Richard Kilgore
    beaufort,sc
    2011 toyota tacoma
    Thank you both!!
  5. Oct 21, 2017 at 6:50 PM
    eon_blue
    eon_blue Okayest Member
    Azusa, CA
    Don't skimp on crush washers, they're cheap and you can get them at your dealership parts dept. or even on Amazon. Reusing old ones can cause a leak/ improper seal.
    Biscuits, QChawks, Rambo54 and 3 others like this.
  6. Oct 21, 2017 at 6:57 PM
    ttran076
    ttran076 Well-Known Member
    Orange County, CA
    2014 Tacoma Sport 4x4
    Kings, TC UCA, Dakars, Prinsu rack, ARB Snorkel, Method NV, Wildpeak AT3
  7. Oct 21, 2017 at 6:57 PM
    Green Jeans
    Green Jeans 6MT AC TRD OR 1GR-FE FTMFW
    Oregone
    '13 TRD Off-Road
  8. Oct 21, 2017 at 7:04 PM
    aficianado
    aficianado Well-Known Member
    bay area, california
    2006 access cab. 4x4, TRD-OR + 2023 TRD off-road.
    back to bone stock.
    I have only used Redline. Honestly I don’t feel any difference from the drivers seat.
    rkilgore76[OP] likes this.
  9. Oct 21, 2017 at 7:06 PM
    TireFire
    TireFire Superunknown Member
    Olympic Peninsula
    Lol what did you expect. It's just gear oil
    rkilgore76[OP] and Blockhead like this.
  10. Oct 21, 2017 at 7:09 PM
    dustin19d
    dustin19d Well-Known Member
    Dustin
    Washington
    06 Sport, 4X4, 6-Speed
    Welds and Cuts and stuff
    Torque it right and you’ll be fine. Never had an issue using the washer over multiple changes. Your preference.
    Hoff and rkilgore76[OP] like this.
  11. Oct 21, 2017 at 7:11 PM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    I second this. Absolutely no reason NOT to, since they cost less than $1.
  12. Oct 21, 2017 at 7:11 PM
    doorsidedown
    doorsidedown Well-Known Member
  13. Oct 21, 2017 at 8:39 PM
    Green Jeans
    Oregone
    '13 TRD Off-Road
    What interval are you running between changes? I roll 30k for both boxes, the MT & transfer case.
  14. Oct 22, 2017 at 4:45 AM
    PackCon
    PackCon Well-Known Member
    Connor
    2017 Subaru Forester Limited
    I used mobil 1 here recently when I did the oil change. I had about 65K miles on the truck and I did not replace the gaskets. I may replace them next change. They were still in very good condition.
    By the way, where are people getting these gaskets and washers for less than $1??
    A new set is like $15. (for front, rear, and transfer case). Not that, that breaks the bank by any means but these things are not $1.
  15. Oct 22, 2017 at 7:46 AM
    badger
    badger Well-Known Member
    07 SR5
    I only use Redline gear oils. In some boxes it makes more difference than others. In the diff, most likely any good quality synthetic would do fine. Redline does make a mid weight that I really like. It helps keeps temps down when towing or climbing hills.
    https://www.redlineoil.com/product.aspx?pid=147&pcid=4
  16. Oct 22, 2017 at 8:02 AM
    Blockhead
    Blockhead Well-Known Member
    Pittsburgh, Pa.
    2024 Silver SR5 DCLB
    OP....my two cents, I was changing all three diffs every 30,000 and oil came out pretty clean so now I'm doing it every 50,000 or so. I don't tow or off-road often, mostly highway use and light hauling so I don't get too caught up in what brand of oil I use, but I do use synthetic. I've used Mobil 1 and a couple others, no difference. As others have said, using new washers is cheap and a good idea but probably not necessary.
    Oh and by the way, hold your nose when doing this maintenance, the fluid stinks!
  17. Oct 22, 2017 at 8:41 AM
    TexasWhiteIce
    TexasWhiteIce Well-Known Member
    Texas
    2022 White DCLB SR5 - Blackout
    Agreed, I did mine at 35k and it was very clean. Looked newer than the fluid I was putting in. I don’t tow either beside one time years ago. I would say change it every 60k miles unless you tow frequently. I’m pretty sure the 30k recommendation is so dealers can get business with maintenance items
  18. Oct 22, 2017 at 9:49 AM
    aficianado
    back to bone stock.
    Thanks for reiterating my point exactly....
  19. Oct 22, 2017 at 9:56 AM
    Jarod888
    Jarod888 Well-Known Member
    Colorado
    2024 GMC 2500 AT4 Duramax Longbed
  20. Oct 22, 2017 at 10:37 AM
    JeffreyB
    JeffreyB Well-Known Member
    Jeff
    2015 Access Cab 2.7 5 Speed 4X4
    A little food for thought, some people recommend against synthetic in the diffs. Not sure why, but it might be worth looking into.
