Rear Differential Oil change
Discussion in '2nd Gen. Tacomas (2005-2015)' started by rkilgore76, Oct 21, 2017.
  1. Oct 23, 2017 at 11:42 AM
    #41
    cliffyk
    cliffyk Well-Known Member
    Cliff
    Saint Augustine, FL
    2009 DCSB SR5 TRD Sport 145k miles
    The friction modifier is needed with dino oils in the Mustang traction-lock clutched limited slip differential--it makes the oil "slipperier" to prevent the LSD clutch plates from binding. FM is usually not needed, or recommended, with synthetic gear oils (even with clutched LSDs) as they are inherently more "slippery" than dino juice.
    In a non-clutched differential it is never needed.
    A trick we used to pull was to use only a couple ounces of FM, instead of the 4 oz recommended, to make the traction-lock "lock" more firmly--guys running strip only cars used none...
    Yurizx6r[QUOTED] likes this.
  2. Oct 23, 2017 at 12:07 PM
    #42
    Yurizx6r
    Yurizx6r Well-Known Member
    2015 Pre Runner, TRD Sport
    Wow. Didn't know that. Thanks! I was wondering why I never needed friction modifier in the stang. So most of you guys probably just use Mobil 1 or Redline in the diff. Just a drain and fill every 30k?
  3. Oct 23, 2017 at 1:00 PM
    #43
    Green Jeans
    Green Jeans 6MT AC TRD OR 1GR-FE FTMFW
    Oregone
    '13 TRD Off-Road
    Yah no need to add a friction modifier on your 2015. 30k intervals are a good benchmark to meet. I tow and haul quite a bit and haven’t felt the need to do it any earlier.
  4. Oct 23, 2017 at 1:25 PM
    #44
    asuchemist
    asuchemist My Hamstrings Hurt!
    South South Dirty Gilbert
    11' TRD Sport V6, 23' TRD Pro 4Runner, 23' Tacoma TRD Pro
    NONE
    Toyota keeps putting gear modifier in mine but TW says my truck doesn't need it.
  5. Oct 23, 2017 at 7:16 PM
    #45
    Lester Lugnut
    Lester Lugnut Well-Known Member
    N of Mex-S of Canada-E of LA-W of NC
    '15 Tacoma PreRunner V6 SR5 Auto
    I bought a 10 pack from ebay seller -> autopartsworlds about a yr. ago - free shipping - $10.95 - about $1.10 per gasket.
    #45
    rkilgore76[OP] likes this.
  6. Jul 15, 2020 at 7:16 PM
    #46
    Lil'Taco
    Lil'Taco Well-Known Member
    Scotty
    Wilsonville
    2010 PreRunner Sport DCSB
    Total Chaos +2" Long Travel, Coil Bucket Gussets, Spindle Gussets, LCA Cam Gussets, Glassworks 4" fenders, B.A.M.F. rock sliders with fill plates, Decked Drawer system, aFe CAI, Borla Cat-back exhaust, Blitzpro 21S LED light bar w/ B.A.M.F. behind the grill light bar mount, Red Label Off-road tube bumper, Redline hood struts, Grillcraft grill, Weather Tech floor mats, HID headlights and fog lights... It has more stuff done to it now.
    I am coming up on 90k miles and figured I had to do something other than an oil change, I just realized I don't think I have ever done a rear diff oil change... Is there something I should do extra or just change it ASAP?
  7. Jul 15, 2020 at 7:32 PM
    #47
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    Just change the fluid.
    And see if you have zerks on the u-joints. If so, grease them.
    Hartford likes this.
