rear differential oil
Discussion in '2nd Gen. Tacomas (2005-2015)' started by bigrog74, Jun 29, 2010.
  1. Sep 14, 2012 at 11:35 AM
    #41
    TRD6Speed
    TRD6Speed senior member
    Bill
    East Hartford, CT
    08 TRD Sport Access Cab
    885x with 5100s and top plate spacer for full 3", RCD extended 5100s in rear, dakars, flip kit, LR UCAs, tint, shorty antenna, in channel rain guards,BHLM, blacked out emblem, OEM side steps, weathertechs, debadged, rear diff breather
    x2.............if you have a LSD pre 09 go get the friction modifier from autozone. I bought a 4oz bottle from the dealer and used regular gear oil. Doing fine.
  2. Sep 14, 2012 at 1:33 PM
    #42
    hetkind
    hetkind Well-Known Member
    Howard
    Johnson City
    2011 SR5 Access Cab, white with Leer Cap
    bilstein set at 1.75, Racho 5000 rear with 4 leaf kit, floor mats, high lift jack, pull hook in hitch, bed rail corner braces, severe duty brake pads and devil horns on the grill....
    A five gallon bucket of 80w-90 GL5 was $72 dollars at NAPA and at 3qts/change that would be a little more than 8 changes at around $9 a change....
    Howard
  3. Sep 17, 2012 at 9:10 PM
    #43
    gtman54
    gtman54 New Member
    frank
    albuquerque
    2006 taco sport 4x4
    Just did my rear diff. with lsd and used 75/90 synthetic valvoline with 4 oz additive,however the next morning it chattered so I added another 4oz of additive and the last couple of days it stopped.It only did it in the am when it was cold and turned out of the garage.Should I leave it as it is or should I get the 80/90 gl5 with additive?
  4. Sep 17, 2012 at 10:17 PM
    #44
    Crom
    Crom Super-Deluxe Member
    Nick
    San Diego, CA
    2009 4x4 DCSB Camp Supreme
    Millions
    Mmmm diff oil.
  5. Sep 17, 2012 at 10:33 PM
    #45
    Taco me elmo
    Taco me elmo Here, Eat some paint. Drink some Bleach.
    Tophat bobcat
    North of South, East of West
    Slow polished TuRD
    Anti theft 5-Speed
    I replaced mine with standard non synthetic and its going to be just fine.
    Seems almost all types are LSD compatible.
  6. Sep 18, 2012 at 12:11 AM
    #46
    Mach375
    Mach375 Habitual Violator of Wheeling Rule #2
    Sathington "Alowicious Devadander Abercrombie" Willoughby (but you can call me Mud)
    '11 DCLB 4x4 TRD Sport
    Too much to list, but enough to get me in trouble. Repeatedly.
    30,000?? Someone's not getting full enjoyment out of his Taco. I just turned over 15,000 on my 7-month-old truck, and had to do all the gearboxes.
    Filled them with Redline 75-90.
    Even with extreme abuse, I can now double my service interval AND have 200,000 mile gears that look factory fresh.
    Why? Well, if you know synthetics, you know Redline is the ONLY oil out there that uses 100% synthetic base stock. And that includes SnakeOil...er, Amsoil.
  7. Sep 18, 2012 at 12:18 AM
    #47
    Taco me elmo
    Tophat bobcat
    Slow polished TuRD
    Anti theft 5-Speed
    Grammar.
  8. Sep 18, 2012 at 12:30 AM
    #48
    David K
    David K Well-Known Member
    Pala Mesa, California
    2010 4WD Off Road DC
    Heavy Duty Truck Mobil One 75-140 in the rear diff.
    Mobil One 75-90 in the front and transfer case.
    That was Speed Freek's Recommendation and had a great 2,600 mile Baja trip soon after!
  9. Sep 18, 2012 at 5:38 AM
    #49
    05Moose
    05Moose Middle-Aged Member
    Jim
    In the snow (NorCal)
    '05 4x4 DC LB SR5 #8 (LSD, Tow Pkg)
    '05 4x4 DC LB SR5 (LSD & Tow Pkg), Timbrens, AAL, 5100s (1.75), Owned: 12/3/04 Mods: Fog, Map/Dome Light, Illuminated 4wd Switch, Washable Cabin Air Filter
    It's not necessarily a problem with the oil. Not all additives are up to the task. I used to use equa-torque but the local parts stores quit carrying it. I tried something from O'Reilly and it chattered immediately. So I bought some additive at Napa and it worked...for about 10k miles. It got worse and worse with mileage and chattered when the oil was cold. The truck would shake violently pulling out of the garage just like you're describing! So I searched until finding the Equa-Torque and changed the oil. All is good again. So my advice is to only use this LSD additive and change the oil. If you don't, it's only going to get worse.
  10. Sep 18, 2012 at 5:30 PM
    #50
    gtman54
    gtman54 New Member
    frank
    albuquerque
    2006 taco sport 4x4
    thanks for the info!!
  11. Sep 23, 2012 at 8:49 AM
    #51
    Brandon H
    Brandon H Well-Known Member
    Newhall, CA
    07 DC Offroad
    2017 4Runner TRD Offroad Premium. Icon stage 7, RCI skids, SCS SR8 wheels, budbuilt sliders, 285/70/17 BFG Ko2s (Old rig) 07 Taco TRD Offroad FUlly Locked, Icon Extended Travel CO's w/ remote resis., Alcan AAL's,Icon Remote Resi Rear Shocks, All Pro Front bumper w/ warn 9.5xp,winchline synthetic winch cable,All Pro IFS Skid plate, OME Shims, OME Carrier Bearing drop, Trail Gear Sliders, Yakima Load Warrior Basket, OEM Roof Rack, Hi Lift Extreme, Cobra model 19, Wilson Lil Wil Antenna, Yaesu ft-7800
    75/90 in the rear. Since you dont have the sport, dont worry about friction modifier additive. I have always run mobil 1 Synthetic in the front & rear diffs and transfer case. My best friend, who is also a Master Toyota Mechanic, recommends it.
  12. Sep 23, 2012 at 11:17 AM
    #52
    crainholio
    crainholio Well-Known Member
    I guess spelling remains optional? ;)
  13. Sep 23, 2012 at 12:20 PM
    #53
    iroh
    iroh Well-Known Member
    michigander
    07 AC SR5 2.7 5MT 4x4
    tonneau
    Toyota never said use 75w85 until the 2009s came out and the LSD disappeared. I wouldn't use that in an LSD rear. 75w85 so far is always synthetic which isn't guaranteed to play nice with the clutches.
    $71/qt... retail of the toyota diff oil LT isn't half that. Besides, Redline synth 75w85 is $15 so why pay so much if you have an '09+ and want to use it.
  14. Oct 1, 2012 at 10:49 AM
    #54
    BBBsti LTD
    BBBsti LTD Well-Known Member
    Irvine, CA
    2010 TRD Off Road 4WD
    I just saw 75W90 at local auto parts and all the Valvoline and Mobil 1 both sais LSD in the label. Is that specific to the TRD Sport (LSD) model?
  15. Oct 1, 2012 at 12:15 PM
    #55
    David K
    The Mobil 1 75/90 or 75/140 is in my 2010... front,transfer case and the 140 in the rear. Working perfect since SpeedFreeek did it!
  16. Oct 1, 2012 at 12:35 PM
    #56
    benbacher
    benbacher Purveyor of Fun Vendor
    Anchorage, AK
    '10 Tacoma 4x4 LBDC SR5 TRD Sport
    Too many to list now.
    I'm due for this this weekend, would a lower weight gear oil be better for me since I live in AK? I want to go full synthetic and have been reading up on royal purple. I don't mind spending a bit extra to lengthen the life of my truck. 2010 sport so I DO need the additive correct?
  17. Oct 1, 2012 at 1:01 PM
    #57
    benbacher
    Anchorage, AK
    Oh good. I'm curious about the viscosity still so of anyone knows feel free to chime in. My truck almost invariably gets started up when it's 15-30 degrees Fahrenheit out. At least 7 months out of the year.
  18. Oct 1, 2012 at 1:12 PM
    #58
    blakes09
    blakes09 Toyota Tech..when im not Fishing
    Blake
    Deep South
    4x4
    just changed mine saturday.has 42k and it still looked brand new.went with lucas 80w 90
  19. Aug 24, 2016 at 2:16 PM
    #59
    MNPhildo
    MNPhildo Active Member
    Phil
    Minnesota
    07 TRD SR5 4dr Longbed
    Leer Topper
    I bought 3 qts of mobile1 synthetic for my 2007 sport and the bottles say there's already LS additive included in the gear oil. Do I still need to add the 4oz. Bottle of additive???
  20. Aug 24, 2016 at 2:17 PM
    #60
    MNPhildo
    Phil
    Minnesota
    Leer Topper
    This was like 3 months ago that I bought the bottles and I'm seeing a bunch of negative reviews on the mobil1 synthetic. Did I just waste $30?
