rear differential oil
Discussion in '2nd Gen. Tacomas (2005-2015)' started by bigrog74, Jun 29, 2010.
  1. Aug 24, 2016 at 2:34 PM
    #61
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    Read through the thread linked in post #2, but IIRC you'll be fine. As far a Mobil 1, you'll be fine with that too.
  2. Jan 29, 2017 at 9:27 PM
    #62
    Beheler3
    Beheler3 Active Member
    Scott
    The Comma
    09 DBL cab Pre Runner
    3" Rough Country Lift Ballistic Off Road Wheels
    Changing u joints in rear drive shaft. Going to change diff fluid as well while I'm at it. I see all this info on TRD and Sport but what about a pre-runner???
    75/90 still good?? Any additive needed??
    NAAC3TACO likes this.
  3. May 4, 2018 at 12:46 PM
    #63
    azzwethinkweiz
    azzwethinkweiz Well-Known Member
    Tucson, AZ
    2013 4x4 DCSB V6 6-Spd, TRD OR, Tow Package
    I'm not sure what the prerunner has in the rear but if its like any other vehicle I've seen it will have a tag or sticker that says "LSD" or "LSD FLUID ONLY", ETC... near by or on the pumkin. If it doesn't have any of these indicators you should be fine without LSD additive.
    I think you can also check by jacking up the rear and turning one of the rear tires, if the other tires spins in the same direction it should have a limited slip diff... if it spins the opposite way its a regular open diff as far as I know. Maybe others with more experience can chime in here.
  4. Aug 8, 2018 at 10:09 AM
    #64
    Seneca
    Seneca Active Member
    Blue Ridge Mtn. Foothills - Central VA
    2018 TRD SPORT M/T ACLB. 2019 T4R SR5 Prem.
    For the Redline brand users. I have read all 4 pages and am still a touch confused. I have a 2010 SR5, 4x4, M/T. I want to change both Diff's, Trfr case and Transmission. Correct me where I am mistaken please. Thank you kindly.
    Both Diff's - Redline 75W-90 Gear oil/lube GL5
    Trfr Case - Redline 75W-90 Gear oil/lube GL5
    T-mission - Redline MT-90 GL4
    O'DubhGhaill and NAAC3TACO like this.
  5. Aug 8, 2018 at 10:11 AM
    #65
    NAAC3TACO
    NAAC3TACO Middle aged member
    Just east of crazy, NV
    2014 SR5 DCLB 4x4
    Color matched door handles, Weathertech floor liners, bed mat, Durafit seat covers, tailgate clamp, 2016 TRD Sport 17" wheels with Yokohama Geolander AT tires , Toyota exhaust tip, Toyota/Yakima bike rail mount, Toyota wheel locks, Toyota hitch cover, Redline hood struts, unifilter on air pump.
    Perfect.
  6. May 22, 2024 at 12:39 PM
    #66
    Hugheaton420
    Hugheaton420 New Member
    Hugh
    2010 toyota tacoma trd pro
    Will gl5 75-90 work with my fron an rear dif an tranny for my trd off road 2010?
  7. May 23, 2024 at 5:17 PM
    #67
    ZColorado
    ZColorado Well-Known Member
    Near Boulder Colorado
    13 DCSB OR 6MT
    35's,Kings, NWF, 488, Harrop, SPC, Archive, Method, RCI, C4
    ZOMBIE THREAD
    Yes, yes it will.
  8. May 25, 2024 at 6:47 PM
    #68
    O'DubhGhaill
    O'DubhGhaill Well-Known Member
    2008 Tacoma TRD Sport Access Cab 4.0L V6 VVT-i6spd manual
    I use the MT-90 in the transfer and transmission , Redline 75-90 in the diffs.
    Marc70 likes this.
  9. May 25, 2024 at 9:08 PM
    #69
    secher
    secher Well-Known Member
    2015 OR v6 6MT
