Rear differential Oil ?
Discussion in '1st Gen. Tacomas (1995-2004)' started by jacksj1, Sep 1, 2017.
  1. Sep 1, 2017 at 1:59 PM
    jacksj1
    jacksj1 [OP] Well-Known Member
    Jon
    01 Tacoma xtra cab 4x4 5spd
    3 inch lift
    Couldn't find a relevant thread but I know my 01 4x4 with the locking rear diff calls for SAE 90 hypoid gear oil but I can't seem to find it. What should I put in it? Any help would be much appreciated!
  2. Sep 1, 2017 at 2:41 PM
    onakat
    onakat Well-Known Member
    Canada
    2000 indestructaco!
  3. Sep 1, 2017 at 2:46 PM
    jacksj1
    Jon
    3 inch lift
    No, my manual calls for sae 90 hypoid gear oil for the rear diff and 75-90 for the manual trans and transfer
    NM Lance likes this.
  4. Sep 1, 2017 at 4:43 PM
    onakat
    Canada
    2000 indestructaco!
    ah, yeah, the "SAE 90" oil.... They usually have some at walmart, canadian tire and auto part stores.
    SAE 90 would be 90w-90, but it does not exist...you can replace it with 80w-90, as it is what would be the closest
    jacksj1[OP] likes this.
  5. Sep 1, 2017 at 4:52 PM
    Clearwater Bill
    Billy
    Largo Florida
    What is the GL spec called for? Thats important to get right.
  6. Sep 1, 2017 at 4:58 PM
    The Driver
    The Driver Trail Runner/Barefoot Beach Runner/Snow Skier
    Raph
    Lakewood (Green Mountain), CO.
    '02 Extra cab 4X4 TRD SR5 3.4
    Aftermarket tranny cooler, 5100 Series Bilsteins, ToyTec Bilstein front coilovers, SPC UCA's, Alcan leafs, Class 3 Hitch, Tundra Front Brakes,
    I just did both diffs. Mobil 1 75W90, is what used on both diffs and the transfer case. Oh, and I have the E-locker!
    Clearwater Bill and jacksj1[OP] like this.
  7. Sep 1, 2017 at 5:06 PM
    eon_blue
    Azusa, CA
    04 e-locker here, I use Valvoline 75w90 in mine.
    opteron likes this.
  8. Sep 1, 2017 at 5:09 PM
    12taco12
    12taco12 Well-Known Member
    rochester NY
    2012 TX Pro
    Billy 5100s OME 886 Billy remote resi 5125 rear General hd packs TImbren superbumps/flipkit Pelfrey steel full hoop front SOS bolt on sliders Baja squadron amber fogs Baja 20" bar Aux fuse panel and switches custom 10 sub box double din
    jammer likes this.
  9. Sep 1, 2017 at 5:13 PM
    Bsheriff11
    Bsheriff11 Remember Your ABC's. Always. Be. Casual.
    Brandon
    Virginia livin', South Carolina raised
    2000 Limited T4R
    Click My Sig Homie
    Most standard oils give the additives in them to reduce the slip that hypoid bevel gears produce, lucas oil is a great lubricant that i personally use, but mobil, valvoline, Pennzoil, etc will be fine as well.
  10. Sep 1, 2017 at 5:40 PM
    RVA_TRD
    RVA_TRD Well-Known Member
    Richmond Virginia
    2000 TRD Offroad, Bilstien 5100s front and rear with 881s and OME Dakars
    Bilstien 5100s on 881s front Bilstien 5100s rear with OME Dakars, together total about 3" of lift 31' Toyo Open Country All terrain Grey Wire mod
    Just did my rear diff on my 2000 TRD with Mobil 1 75W90 synthetic gear oil. Truck has about 190,000 miles on it and I looked like it hadn't ever been changed. Super easy process to do, just remember to get a new crush washer for the fill and drain plugs.
  11. Sep 1, 2017 at 7:26 PM
    Sicyota04
    Sicyota04 Slowly but surely.
    Morgan
    California
    04 DC 4x4
    I used RP 75w90 in front diff, transfer case and rear E locker diff. And no I never tow anything.
  12. Sep 1, 2017 at 7:28 PM
    NM Lance
    NM Lance Well-Known Member
    This has always concerned me too. You can use 80W-90, but it is only intended for temperatures less than 0 deg F. I went to the dealership to see if I could get some SAE 90 and the parts guy told me all they use is 80W-90. I have always used 80W-90 and haven't had any issues, at least not yet. 260,000 miles and counting... no issues.
    I don't know if it makes a big difference, but this is always at the back of my mind when I change the rear diff oil.
    ThunderOne and jacksj1[OP] like this.
  13. Sep 1, 2017 at 7:29 PM
    NM Lance
    I checked a tractor supply store and they carried straight SAE 90, but it was not for hypoid service. I wonder if there is an additive that can make it useable?
  14. Sep 1, 2017 at 7:43 PM
    Bsheriff11
    Brandon
    2000 Limited T4R
    Click My Sig Homie
    Why? Just go grab some Pennzoil from advance and change it every 30K or sooner depending on driving style. I promise, that rear diff will live for longer than the truck with shitty ass oil if you ain't driving it hard offroad and bouncing it.
    NM Lance[QUOTED] likes this.
  15. Sep 1, 2017 at 7:45 PM
    NM Lance
    My only real concern is, it gets over 100 F just about every day in the summer where I live. Otherwise, I probably wouldn't blink an eye. I also use cheap oil, usually SuperTech, or whatever is on sale at Walmart.
    Bsheriff11[QUOTED] likes this.
  16. Sep 1, 2017 at 7:54 PM
    TRVLR500
    TRVLR500 Well-Known Member
    Wyoming
    Tacoma SR5 4X4 2.7 4CYL
    I use all Amsoil in my 2004 2.7 RC 4X4. 75-110 severe gear in front and rear diffs and Amsoil GL 4 in the trannny. MMMMM. I forget what I put in the transfer case but it was what Amsoil recommends. Probably 75-90.
    1997tacomav6 and jammer like this.
  17. Sep 1, 2017 at 9:20 PM
    Bsheriff11
    Brandon
    2000 Limited T4R
    Click My Sig Homie
    Diff's get warm regardless. If you use shitty oil change it sooner. If you offroad a lot and use shitty oil then change it even sooner. Theres a balance and money can be saved by using cheaper oil, just be weary of your driving style, running through water, hard on the gas, etc. If you put your hand on the rear diff and it burns the hell out of you, probably would be best to use better oil! I just try for the cheapest most common sense stuff for me and my terrain. Everyone will be different.
  18. Sep 2, 2017 at 8:02 AM
    opteron
    opteron Well-Known Member
    whittier, CA.
    2003 DB 4x4 SR5
    Leer camper, bug-rug, fox suspension 2.0 rear, fox 2.5 front, BAMF sliders and LCA, TRD fake 3 piece rims
    I use Valvoline for all fluids....
  19. Sep 2, 2017 at 9:43 PM
    ThunderOne
    ThunderOne Well-Known Member
    Mitchell
    Nashville
    1ST GEN OR GTFO
    Toyota NERD
    Use a 100+ weight then, like 85-140. Hell, ECGS insists to use 85-140 dyno in their diffs: http://eastcoastgearsupply.com/ft-2536-ecgs-gear-oil-recommendation.html
    Also: useful video.. explains oil weights and the XXw-XX oils.
    https://youtu.be/tYkg0oDUXs8
  20. Sep 2, 2017 at 11:08 PM
    mechanicjon
    mechanicjon They call me "Jonny Stubs"
    Jon
    Scottsdale Arizona
    04 Taco SC 4dr SR5 TRD Prerunner
    Supercharged, AEM FIC/6, Meth Inj, ION Alloy's, Radio & Phone steering Wheel controls,Fabtech AAL, Billie's wrapped with 880's , Tundra big brake conversion, bully bars and Pioneer DDin Stereo/dvd with exterrnal usb ports. 290K and going strong.
    Hypoid beveled gears don't slip. The additive is for positrack type differentials with clutch packs. Our e-lockers are mechanically engaged by a sliding splined collar. Additive is not required.
    I run Mobil1 75-90 synthetic in my elocker.
    jacksj1[OP] and opteron like this.
