Rear Differential Plugs
Discussion in '1st Gen. Tacomas (1995-2004)' started by DecaturTide, Mar 1, 2014.
  1. Mar 1, 2014 at 1:36 PM
    DecaturTide
    DecaturTide [OP] Well-Known Member
    River City
    2016 SR AC BARCELONA RED
    Anyone had trouble braking loose their differential plugs? I'm trying to change the oil and can't get the fill plug to budge. Just hit it with some PB Blaster.
    We will see. Using 24mm 1/2" socket 6 point. Feels like a knuckle buster waiting to happen.
  2. Mar 1, 2014 at 1:43 PM
    maxboi
    maxboi MAXBOI
    Brian
    SODA CITY
    2011 White D'Cab OR 4wd
    76 FJ horns, Weathertechs, Backup Camera anytime switch, Fogs anytime, Clamp & Washer tailgate, Diff Breather,
  3. Mar 1, 2014 at 1:45 PM
    carcharias
    carcharias Giggiddy what what
    Los Angeles, CA
    SOLD: '11 AC MGM OR
    Kings all-around w/ 700lb coils, Dakar leaf pack, TC uca's, DO single hoop bumper, BAMF bolt-on sliders w/ kickouts, Rigid 20" e-series spot/flood, aFe pro-dry, BFG KM2 255/85/16, silver TRD FJ wheels, WARN M8000-s, Access LE, Grillcraft, BAMF lightbar, BAMF rear dif skid, BAMF LCA skids, window tint, Wet Okoles, WeatherTech floorliners, Silverstar lights, led dome lights, Redline Tuning hood struts, center console lock mod, mag-lite mod, extra d-rings, re-routed exhaust, ATO skids, ATO Hi-Lift mounts, pipe tailgate lock, seatbelt alarm delete, wheel/spare locks, Viper 5901, LoJack... WISHLIST: a golden canary that poops platinum
    My new torque wrench has helped on every stuck bolt on my truck. Then again, you have a 2000, so it may be a bit more glued on.
  4. Mar 1, 2014 at 1:51 PM
    storktaylor
    storktaylor Well-Known Member
    California, MD
    09 Pre-Runner TRD Off-Road
    Bak FLip G2 ScanGauge2 Black Labrador Retriever
    Had the exact same issue with mine. I was worried about rounding off the nut with the socket I was using. Not a while lot of need for a 24mm socket AND box end wrench, but that is where I thought I was headed (lucky for me there is a sears a mile up the road). I shot some PB break free on it and let that soak in which finally got it done.
  5. Mar 1, 2014 at 1:52 PM
    Spoonman
    Spoonman Granite Guru
    Jamie
    Alberta
    Get a socket that fits really well. Use muscle and a longer ratchet.
    Oh yeah, never use a torque wrench to remove bolts, or on the removal setting(even if it has it).
  6. Mar 1, 2014 at 2:08 PM
    carcharias
    Los Angeles, CA
    SOLD: '11 AC MGM OR
    ^^Why not? Worked like a charm for me.
  7. Mar 1, 2014 at 2:13 PM
    Spoonman
    Jamie
    Alberta
    Yes it works, however it can damage the torque wrench, and send it out of calibration.
  8. Mar 1, 2014 at 5:16 PM
    carcharias
    Los Angeles, CA
    SOLD: '11 AC MGM OR
    Good to know!
  9. Mar 1, 2014 at 5:42 PM
    takern
    takern Well-Known Member
    Tanner
    Virginia
    03 TRD Offroad stepside
    Deckplate mod, sliders, uniden cb, toolbox, dakar leaf pack, in search of coilovers, 255/85 16 bfg m/t waiting to go on
    you have floor jack? take off the handle and put it on the ratchet handle. 3 ft breaker bar. might need an extra hand to hold the socket snug on the bolt but an extra 3 ft really busts some tight bolts. you could also hit it with a propane torch, just be sure to only warm it up and avoid brake lines and the such
  10. Mar 3, 2014 at 5:54 AM
    DecaturTide
    River City
    Finally got those suckers. It's all good.
  11. Mar 3, 2014 at 6:03 AM
    40950 Well-Known Member
    CR, WA
    1999 8 port 3RZ 4WD SR5
    stock
    First time I broke the plugs free, they were all very tight. 1/2" 2 foot breaker bar and hard 6 point's got it done on the rear plug. Rattled the face of the plugs with a custom built air hammer bit,,to shake the white lock dust loose.
  12. Mar 3, 2014 at 7:37 AM
    tacomataco2
    tacomataco2 A dude
    Mass
    15’ ACLB
    Some of this Some of that
    A few years back i smashed the hell outta my pinky doing just that :(
