Rear differential question
Discussion in '2nd Gen. Tacomas (2005-2015)' started by cgutierr, Sep 19, 2010.
  1. Sep 19, 2010 at 8:09 AM
    cgutierr
    cgutierr [OP] Active Member
    I have a 2006 Prerunner with limited slip. I am going to change the rear differential fluid and am not sure whether or not it requires the LSD additive. What is the best fluid and does my truck require the additive or not. It is not the TRD sport.
  2. Sep 19, 2010 at 8:16 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Yes, It needs the addative. There is a DIY on here to help. Best bet is to use your favorite dino gear lube, and a GM, or MOPAR addative. Start with 4 ozs. of the addative, and if it chatters, add a little more.
  3. Sep 19, 2010 at 8:20 AM
    cgutierr
    Thanks Chris I really appreciate it.
  4. Sep 19, 2010 at 8:20 AM
    brutalguyracing
    brutalguyracing BIG DADDY
    F.U> GUYZ
    broken mods
