Rear differential rumble?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by jrlin718, Jan 13, 2021.
  1. Jan 13, 2021 at 4:44 AM
    jrlin718
    jrlin718 [OP] Well-Known Member
    Jonathon
    Louisville, KY
    2016 TRD Sport Barcelona Red 4X4 Double Cab
    Plastidip front grill and badges Bilstein 5100 shocks set at 0 OME 888 coils Lights Racing UCAs Headstrong AAL TRD Pro Wheels Matte Black BFG KO2 275/70/17 Rocky Mounts DriveShaft SD KB Voodoo Bed Rack ECGS 8 in clam shell bushing Custom Bedside Decals TRD MTB Edition CBI front bumper CBI rear high clearance bumper CaliRaisedLed 20 in single row bumper ARB CKMA12 Air compressor
    I purchased a set of front and rear 5.29 gears assembled in sept 2019 from ecgs for my 2016 trd sport automatic Tacoma. I installed the third member and front diff myself and went through the appropriate break in period and changed the fluids after 500 miles and used the recommended gear oil. I have roughly 20k miles on the new gears. I’ve been running 315/75-16 BFG km3. A few days ago I started having a new issue. When going roughly 20-60 MPH if I just feather the accelerator i hear a noise coming from the rear diff that’s a rumbling noise. It sounds like I’m driving over a highway rumble strip. I took it to my local Toyota dealership and the confirmed the noise is from the rear differential but they will not inspect further since it was regeared. I changed the diff fluid yesterday and found nothing more than a normal amount of the metallic sludge on the drain plug magnet. This didn’t fix my problem. Do you have any ideas of what this might be?
  2. Jan 13, 2021 at 5:25 AM
    ShimStack
    ShimStack Well-Known Member
    Ben
    NC
    '91 Truggy, '98 Project, '16 DC OR M/T Locked F/R
    I'd suspect pinion bearing issue first if it is actually the rear diff, but you won't know for sure until it's inspected. It very well may not be the rear diff so inspect everything.
  3. Jan 13, 2021 at 6:00 AM
    TacomaBeast67
    TacomaBeast67 Well-Known Member
    Calgary, Alberta
    2017 TRD Sport, Dbl Cab, Manual
    K&N Cold Air Intake, N-Fab Rock Rails, Removeable Steps, BAC Revolver X2 tonneau, 265/70/17, engine bay LED’s, Amber/clear strobes
    If you find after doing all the inspections as best you can and you’re about to start spending money on your list of “best guess repairs”, please take it to a drive line specialist and have them put the truck on rollers, sensors and computers, pay their 2-3 hour fee and let them tell you exactly what’s going on.
