Rear Differential Squeaking
Discussion in '2nd Gen. Tacomas (2005-2015)' started by budzinsk, May 15, 2022.
  1. May 15, 2022 at 4:04 PM
    budzinsk
    budzinsk [OP] Member
    Rob
    2019 Tacoma TRD Off Road - White
    Hi Everyone. My son has a 2010 Tacoma Sport 4x4 and he is having a strange squeaking sound from the rear end. It is not the leaf springs or suspension, it is coming from the differential. We jacked up the rear end, put in gear and let is go slowly. It chirps or squeaks. I used a Stethoscope and determined it is not the carrier bearing but is something in the differential. No grinding or excessive play, just a chirping. Not out at the wheel side (so not brakes). Anyone have any ideas? It almost sounds like hard rubber against metal - maybe the seal is bad? Thanks in advance!
  2. May 15, 2022 at 4:33 PM
    gotoman1969
    gotoman1969 Well-Known Member
    San Antonio, TX United States
    2015 Silver Tacoma PreRunner
    Is there any play in the pinion gear?
  3. May 15, 2022 at 4:35 PM
    budzinsk
    Rob
    Nothing outside of normal.
  4. May 15, 2022 at 4:45 PM
    gotoman1969
    Hmmm. My first thought is to disconnect the drive shaft and spin the rear wheels by hand and try to duplicate. That would confirm it’s definitely not anywhere in the drive shaft and carrying down the driveshaft sounding like it’s somewhere else.
  5. May 15, 2022 at 5:42 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    It’s possible a bearing is failing in the rear end.
    That’s really uncommon on these trucks, but I guess it possible.
    2010 has an open diff, so it can’t be clutch pack chatter.
  6. May 15, 2022 at 6:55 PM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    I would pull the driveshaft and check for a stiff U-Joint.
  7. May 15, 2022 at 8:43 PM
    08TacoTrD
    08TacoTrD Well-Known Member
    08 TRD Offroad
    The rear u-joint?
  8. May 16, 2022 at 4:56 AM
    budzinsk
    Rob
    Thanks Everyone. Good ideas. I will do some more research this week and see if I can isolate the issue. Glad it does not seem to be a common issue.
