Rear Differential Temp sensor
Discussion in '3rd Gen. Tacomas (2016-2023)' started by You did what?, Oct 19, 2019.
  1. Oct 19, 2019 at 2:42 AM
    You did what?
    You did what? [OP] Well-Known Member
    James
    Ar.
    ‘16 TRD Off-Road
    Has anyone installed a temp sensor on rear differential? If so, where did you install sensor. Toyota put a temp sensor on front diff, but not rear. ScanGauge II can read all relevant temps through obd port. I’m wanting one for rear differential.
    soggyBottom likes this.
  2. Oct 19, 2019 at 4:37 AM
    Chew
    Chew Not so well known user
    Chewy
    Midwest
    19 TRD OR
    Amazon dog poo bed mat mod
    Gear oil change, is cheap and easy, just change more often.
    To answer your question: I can't see it realistically.
    zoo truck and (deleted member) like this.
  3. Jul 6, 2020 at 3:22 AM
    soggyBottom
    soggyBottom Well-Known Member
    Perhaps you could add a sensor to the can bus. I haven't looked at it before but I would be very very surprised if there weren't unused address spaces. Checkout "Carduino". Here is a parts list. If you look around, you can find all the parts for around $20.
    https://www.amazon.com/dp/B076DSQFXH/ref=cm_sw_r_cp_apa_i_tQVaFbPTY7FXP
    https://www.amazon.com/dp/B01ETRINYO/ref=cm_sw_r_cp_apa_i_MSVaFbPCZ1Y2J
    https://www.amazon.com/dp/B008GRTSV6/ref=cm_sw_r_cp_apa_i_5SVaFbTCAFRX2
    Maybe the front has the potential of getting hotter because slow hard driving in 4wd with less air flow. Also heat from the engine.
  4. Jul 6, 2020 at 4:24 AM
    2dogs_and_a_taco
    2dogs_and_a_taco Well-Known Member
    Nick
    2020 Army Green Taco
    Have you had problems with the oil cooking?
    It’s not the cleanest solution, but I’ve had good luck with using non-contact thermometers for checking rear end temps in cars. Usually after installing new gears I keep an eye on the temp during break in.
  5. Jul 6, 2020 at 5:51 AM
    zoo truck
    zoo truck Well-Known Member
    2020 quicksand sr5 tacoma
    None
    My 2001 tundra rear differential held a lot less gear oil than these tacos. I just changed it every 30k miles. Never had an issue the entire 292k miles on the truck.
    Chew, Junkhead and shakerhood like this.
  6. Jul 6, 2020 at 6:03 AM
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    You guys know this is an old thread right? He never reported back so I assume it was never an issue.
    Chew, Skydvrr, Junkhead and 1 other person like this.
  7. Jul 6, 2020 at 6:05 AM
    2dogs_and_a_taco
    Nick
    Toyota recommends every 15k on these trucks for diff fluid change. That seems more often than necessary.. Almost like a way to get Tacoma owners in for service more often... (wearing my tinfoil hat)
  8. Jul 6, 2020 at 6:08 PM
    soggyBottom
    I found this thread because I was wondering about diff temperatures. No problems here, just curious.
    hiPSI[QUOTED] likes this.
  9. Jul 6, 2020 at 6:09 PM
    soggyBottom
    I suspect that OP is just curious and likes seeing the numbers.
  10. Jul 6, 2020 at 6:39 PM
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    Are you sure it's that frequent, I could swear the book in the glovebox didn't recommend changing until 30K? I believe it does said to inspect the levels in there at some point too.
    Chew likes this.
  11. Jul 6, 2020 at 7:34 PM
    soggyBottom
    I just hit 15k. Dealer had me wait for 3 hours while they rotated my tires. I think it is 30k
    shakerhood[QUOTED] likes this.
  12. Jul 7, 2020 at 5:13 AM
    2dogs_and_a_taco
    Nick
  13. Jul 7, 2020 at 5:29 AM
    2dogs_and_a_taco
    Nick
