Rear differential was making a whining noise...
Discussion in '3rd Gen. Tacomas (2016-2023)' started by knuckles67, Mar 31, 2021.
  1. Apr 27, 2021 at 7:08 AM
    #61
    knuckles67
    knuckles67 [OP] Well-Known Member
    Derek
    I completely understand what you’re saying and I don’t off-road like i use to your correct I am on flat ground 99% of the time now I have owned a lot of Tacoma’s all I was saying with this one was there was something going on with 3rd member people just can’t except that
  2. Apr 27, 2021 at 7:23 AM
    #62
    Junkhead
    Junkhead TRDude
    Serge
    Prince George, BC
    Black 4x4 Sport MT 2018
    Some Serious Tires
    Punctuation does wonders sir.
    Gamma11 and Montana_Actual like this.
  3. Apr 27, 2021 at 7:36 AM
    #63
    knuckles67
    Derek
    Lol move on
  4. Apr 27, 2021 at 7:43 AM
    #64
    Lt. Dangle
    Lt. Dangle RIP @stun gun 2016-2020
    Ohio
    2025 Tundra Platinum OR
    I can except that. I and a lot of others have had to deal with this exact same issue.
    Montana_Actual likes this.
  5. Apr 27, 2021 at 7:47 AM
    #65
    kite_325
    kite_325 A simple human, being
    North Carolina
    2017 TRDOR
    :locked: inb4 moved to The Dumbgeon
  6. Apr 27, 2021 at 7:07 PM
    #66
    Tbar71
    Tbar71 Active Member
    Troy
    Pace, FL
    2020 Cement Tacoma Limited
    I can definitely hear the whine on acceleration on my 2020 Limited 4x4
  7. Apr 27, 2021 at 7:21 PM
    #67
    knuckles67
    Derek
    Is it constant under acceleration or in a certain range
  8. Apr 28, 2021 at 12:17 AM
    #68
    AFMurse2014
    AFMurse2014 Death Can Wait
    Devin
    San Antonio
    2016 MGM Double Cab TRD OFF ROAD 6 Speed MANUAL
    Freedom, American flags and ISIS blood Morimoto 35w 5500k HID/ LED highs from TRS. RCI expo rack Core Short throw shifter, hypertech speedo recalibrator. Rear seat molle panel. OVT. PnP 2LM. C4 Hybrid Bumper w/ amber BD squadron pods. 33 pizza cutters. T9 radio
    You're*
    Junkhead likes this.
  9. Apr 28, 2021 at 12:18 AM
    #69
    AFMurse2014
    Devin
    San Antonio
    Accept*
  10. May 11, 2021 at 11:48 AM
    #70
    Tbar71
    Troy
    Pace, FL
    Under any acceleration.
  11. May 11, 2021 at 12:00 PM
    #71
    zoo truck
    zoo truck Well-Known Member
    2020 quicksand sr5 tacoma
    None
    10k miles on my 2020 sr5. I was suppose to hear the whine begin around then. So far very quiet. I'm really disappointed, and becoming depressed.
  12. May 11, 2021 at 3:36 PM
    #72
    knuckles67
    Derek
    Are you thinking of having the rear differential replaced
  13. Jan 29, 2022 at 6:42 PM
    #73
    In2Ndo
    In2Ndo Well-Known Member
    California
    MGM 2021 Tacoma TRD OR
    So, is there a TSB to the differential howling of a 2021? I’ve read a lot of the comments. But skipped a lot of them due to the unrelated stuff.
    I have TRD OR SB 2WD.
  14. Jan 29, 2022 at 6:51 PM
    #74
    Montana_Actual
    Montana_Actual ;)
    Yea, I hear it also on my '22, but very rarely. Most times the music is too loud ;)
    It's a thing though. These are whiney difs.
    Doesn't hurt to bring it in, mention it, and ask if they can recreate it to assess it. I had a '21 Subaru Crosstrek that everyone swore up and down on the forums was shifting normally for a CVT, turns out it wasn't and a plastic piece had broke inside the valve body. They serviced (replaced entirely) the valve body and life went on. If it's new and under warranty, use it. They should be willing to address the issue due to that fact alone. I actually just had the gas cap replaced on my taco because it wasn't locking. Most will turn and constantly click, but the tacoma doesn't. Well, I asked when I was there getting my audio done and they looked, told me it was weird and replaced it. Now it clicks once and stays there where before it backed off so much it was just waiting to slip loose and give me a CEL. We can ask questions all day on these forums, but for some noises and issues, it's best to just go with your gut and have someone look at it. If I would have mentioned the gas cap here I already know the answers would have been "it's fine, mine does that too". I know it does, mine was too loose. So your dif could be whining too loud and too frequently. Not a bad idea to have them check it and if they do check the fluid in the process hopefully there is not excess metal. They could always change the fluid and then tell you bring it back in 500 so they can look at it again to make sure. Tons of options here, and the worst advice is to just "drive on" with it. If it's bothering you, get it looked at.
    TacomaAddict23 likes this.
  15. Jan 30, 2022 at 1:18 AM
    #75
    Taconator_
    Taconator_ IG: ohv_tacotruck
    Eric
    SoCal
    18' DCSB TRD OR 4x4
    Flat earther comment got me. :rofl:
    Gamma11 likes this.
  16. Jan 30, 2022 at 2:07 AM
    #76
    Sep1911
    Sep1911 Well-Known Member
    2016 Taco
    I remember back in 2016 when I got my truck and joined this forum everyone was having this issue. Well not everyone but there were quite a few complaints. I’m surprised to see a 2021 doing it. Would have thought Toyota would have figured this one out by now
  17. Jan 30, 2022 at 4:05 AM
    #77
    ROAD DOG
    ROAD DOG Well-Known Member
    2019 I4 WHITE SR PRERUNNER
    FEW
    its very easy to underfill ANY rear differential
    the rear fill hole equals out to be 50% or less
    every component is ‘ Splash ‘ lubricated .............pinion / outer axle bearings ( ring gear is a given )
    if after a lift the diff is rotated to accomodate universal joint angle
    its easy/possible to starve the pinion bearing
    if the fluid level runs low ......it is very easy/possible to starve the outer axle bearings ( even normal road mileage )
    at trail angles its possible fluid will not be available to ALL components for periods o time
    to mitigate circumstances
    i back up ramps raising the rear resulting in added flid capacity
    fill to top level of fill hole.......cap & have added lubrication
    NO it wont result in Over Fill with fluid being blown out of vent
    No it wont blow out outer axle bearing wheel seals
    RED LINE makes has the largest assortment of rear differential fluids....................GOOD STUFF !!
  18. Jan 30, 2022 at 4:40 AM
    #78
    RSOTACO
    RSOTACO Well-Known Member
    Joe
    York County PA
    2016 SR5 Barcelona 285 75 16
    Yes
    My diff is quiet. Quite quiet infact
  19. Jan 30, 2022 at 11:28 AM
    #79
    ppat4
    ppat4 Well-Known Member
    Paul
    Kelowna, BC
    2016 Tacoma TRD Off-Road Access Cab
    Just added toolbox and roof-rack to haul my fishing boat 100's of miles into the backwoods every week. Goodrich K02s, Bilstein 5100 front and back, no lift.
    My 2016 TRD OR has 60K miles on it now, 12K of that very hardcore off road in central BC. Lots of rattles and squeaks and the driveshaft vibration, but no noises from the rear diff.
  20. Dec 8, 2022 at 11:07 AM
    #80
    mr2cam
    mr2cam New Member
    Cameron
    2022 Tacoma TRD
    I work at an independent shop, just got a 2018 in our shop with 38,000 miles, and the rear diff needs to come apart, serious noise from the pinion, it is also very loose feeling, will update with pictures if the customer ok's the work.
    TnShooter likes this.
