Rear Disc Brake Conversion
Discussion in '3rd Gen. Tacomas (2016-2023)' started by kjp4575, Jan 13, 2022.
  1. Jan 17, 2022 at 9:42 AM
    I.eat.tacos
    I.eat.tacos Well-Known Member
    Steve Rogers
    '18 TRD 4x4 Sport
    Looks…
    Clearwater Bill likes this.
  2. Jan 17, 2022 at 9:56 AM
    eurowner
    eurowner Duke Sky
    Scoty
    Drums have no drag when properly setup. So drums are faster and get better mpgs.
  3. Jan 17, 2022 at 10:04 AM
    Gearheadesw
    Gearheadesw must modify
    Davenport Fl
    1 truck 1 car 1 motorcycle
    While disk brakes offer some advantages over the drum set up, the rear drums offer all the rear stopping power the truck needs. The main advantage is servicing the disk brakes is cake compared to drums.
  4. Jan 17, 2022 at 10:09 AM
    Pilsner
    Pilsner Well-Known Member
    18 TRDOR
    255/85r16 ST Maxx 6112/5160 w/ Dakar RCI armor, sliders, and rear bumper CBI hidden winch mount w/ Smity 20k
    I agree. Drums are on this because they are cheaper. They are not on the Tundra. They are not on f150, f250, f350 trucks. They are not on Jeeps or new Broncos. So if they are better for truck use like towing, or better off-road, then why do other manufacturers use more expensive brakes? It is worth the upgrade to me just to not have to mess with drum brakes. I have them on some of my older trucks, and they will be changed out eventually as well.
  5. Jan 17, 2022 at 10:13 AM
    OpeCity
    OpeCity Well-Known Member
    Long Beach, CA
    Like many features on modern cars, they’re there because you can’t compete if you don’t have them.
    drums work great in the rear, and you likely won’t ever have to “mess with them” at all.
    Junkhead, eurowner and daveeasa like this.
  6. Jan 17, 2022 at 1:10 PM
    InThePlains
    InThePlains Well-Known Member
    Seems like a solution for a problem you are looking for.
    Most of the military trucks and heaving haulers have drum brakes, even on the front axle.
    Brake shoes are not much harder to change than pads. Most of the time the front brakes carry 60-70% of the stopping force anyway.
    Gunshot-6A likes this.
  7. Jan 17, 2022 at 1:25 PM
    oconnor
    oconnor Where am I?
    Midwest
    '18 TRD Sport 4x4 AC 6MT/ '04 TJ Rubicon
    I'll swap if I ever have an issue with the drum performance in my application (DD). I'm not going to do it for no real return or just for looks.
    Junkhead likes this.
  8. Jan 17, 2022 at 6:11 PM
    Captqc
    Captqc Well-Known Member
    Tigard, OR
    2017 Tacoma 4x4 TRD AC Off Road
    Isn’t the conversion kit around $3k?
  9. Jan 18, 2022 at 5:36 AM
    StellaHolland
    StellaHolland New Holland Overland (Holland, MI)
    Jeremy
    Holland, MI
    2017 Tacoma TRD OFF-ROAD
    King 2.5 custom valved Milestar A/T Pro 285/70/17 on Method 702's New Holland Overland custom front bumper, roof rack, sliders & skids Mix of Diode Dynamics & Baja Lights 5.29's w/ KDMAX tune Skinny Guy Camper Bare Bones w/ Alu-Cab 180 Awning Freedom Retrofit custom headlights ... & So. Much. More
    These things feel sooo much better than the stock drums!
    (SOS Performance Kit)
    danojeno and KrnTaco08 like this.
  10. Jan 18, 2022 at 6:21 AM
    Sungod
    Sungod Well-Known Member
    St Augustine
    What have you been doing that your rear brakes are worn? I have put over 200K on several Toyota trucks and never been close to needing to replace the shoes. There is a reason Toyota hasn't changed to discs on the rear. Drums work and last forever.
    Vmax540, Sharky and Gunshot-6A like this.
  11. Jan 18, 2022 at 6:24 AM
    Sungod
    St Augustine
    In what way do they feel better? How much of that is in your head? Rear brakes typically only do about 25% of your stopping and even that isn't a lot because of weight transfer.
  12. Jan 18, 2022 at 8:21 AM
    StellaHolland
    Jeremy
    Holland, MI
    Braking feels smoother, it is noticeable even with my "butt dyno". Ive had issues ever since I bought the truck new with the OE rear drums.
  13. Jan 18, 2022 at 8:23 AM
    StellaHolland
    Jeremy
    Holland, MI
    If they lasted forever then why did I go through 3 blown wheel cylinders and 4 rear drum sets in 98K miles? If you off-road your truck all the drums do is capture mud/sand/crap and use it to grind down the internals (Yes I washed the drums frequently after trips). They dont last...
    Gearheadesw likes this.
  14. Jan 18, 2022 at 9:32 AM
    Taco_mike73
    Taco_mike73 Well-Known Member
    York, PA
    2020 Cement SR5 DCSB 4x4
    Lomax tonneau cover, oem bed lights, AJT Design chrome delete, black out badges & tailgate letters, AVS hood deflector & vent visors, Solkie tech hood supports, interior LED lights, Tufskinz mud guards, RedArc TowPro Liberty, bed mat, kicker speaker upgrade, Hikari ultra H11 low beams, Diode Dynamics SS3 fogs in yellow, Meso customs total taillight stage 1. Coming soon: Compact powered sub install Future mods planned: bigger tires (265/75/16) BILLSTIEN 5100 lift
    I don't see the point $1,300 to $1,600. The performance gain can't be worth that much over the drums. I will agree that working on drum brakes is a bit more of a pain than disk. still thats a lot of coin.
    soundman98 likes this.
  15. Jan 18, 2022 at 9:38 AM
    #35
    Wulf
    Wulf no brain just damage
    rock raisin
    I have rear disks on my first gen. Stopping power is not worth the hype nor losing the parking brake :burp:
  16. Jan 18, 2022 at 9:47 AM
    #36
    Clearwater Bill
    Billy
    Largo Florida
    Drums are so bad that they are standard on dump trucks and school buses.
    Of course I would 'prefer' disc, because they are easier to service. And they do 'look' better if you have sexy wheels that allows them to peek through.
    But for how the truck is used, drums work just fine for me. And while servicing is trickier, it's not hard. You just have to pay attention.
    Vmax540, Sungod and Taco_mike73 like this.
  17. Jan 18, 2022 at 9:48 AM
    #37
    Bishop84
    Bishop84 Well-Known Member
    Everyone wants rear discs until they see the parking shoes for the first time. Worse yet when they get covered in axle oil.
  18. Jan 18, 2022 at 9:55 AM
    #38
    MGMDesertTaco
    Front brakes do about 70% of the stopping. I'd spend my money there and not worry about the drums. :popcorn:
    Vmax540 likes this.
  19. Jan 18, 2022 at 9:56 AM
    #39
    Clearwater Bill
    Billy
    Largo Florida
    Had a couple of Z cars with hat-in-rotor setups. Fortunately no axle seal leaks. :thumbsup:
  20. Jan 18, 2022 at 10:11 AM
    #40
    Speedfreak
    Speedfreak Member in poor standing
    Dave
    Canada Eh!
    2017 Tacoma TRD Sport DCSB 6MT, Blazing Blue Pearl
    Manual Mall Crawler
    Has anyone done a before and after comparison of stopping distances with a rear disk set up? The thread about the basic big brake 4Runner swap had a comparison and showed an improvement with braking.... maybe not completely scientific results but results enough to show a difference. If someone here is doing a swap, will you please try to post some numbers... stopping distances from say 60 to zero over 3 to 5 stops. Before and after...
    musicisevil likes this.
