Rear disc brake conversion
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Eastsidegeorgiaboy, Sep 14, 2022.
  1. Sep 14, 2022 at 5:17 PM
    #41
    CountryDan
    CountryDan Well-Known Member
    Daniel
    Calhoun GA
    15 TRD PRO DCSB 6 spd
    a lot of bad ass stuff
    I have a second gen that I converted to discs. If I could go back I wouldn’t have done it. If you value having an emergency break strong enough to hold on an average hill, then I highly recommend you to stay with your drums.
  2. Sep 14, 2022 at 5:20 PM
    #42
    Vlady
    Vlady Well-Known Member
    Issy, WA
    2017 White SR5 DCSB V6 4x4
    I had a few cars with drums in the rear and only thing I did is blowing dust every other year.
  3. Sep 14, 2022 at 5:52 PM
    #43
    pauldotcom
    pauldotcom Well-Known Member
    Paul
    MA
    2012 Toyota Tacoma 4x4 TRD Sport Quad Cab
    OEM Roof Rack, Bilstein 5100's @ 1.75", Rear 1" block, TRD 17' Wheels
    Folks they are brakes not breaks lol. Also, especially in cold climates, the huge advantage is that the components are insulated from the salt/sand. Rear disc brakes rust before the pads go bogus most of the time.
    gvfs likes this.
  4. Sep 14, 2022 at 6:02 PM
    #44
    Wire4Money
    Wire4Money Well-Known Member
    Tim
    2024 SR5 4x4 long bed
    My 2005 Wrangler Rubicon had factory rear disks while most others had drums. I don’t buy the idea drums are better off road.
  5. Sep 14, 2022 at 6:35 PM
    #45
    Lava-road
    Lava-road Well-Known Member
    2019 trd-off road
    Hard top camper...many more to add+
    A while back a Toyota engineer mentions “why” Tacoma has drum brakes. My 2001 Toyota Camry has 4-wheel disc brakes which I still have.
    He mentions it has been proven to be good for there Tacoma trucks. I believe because it was cheaper for Toyota Tacomas to save money . Now Toyota mentions the newer Tacomas will all have rear “disc brakes”.
    Toyota loves to go cheap! Today they need to catch-up, because everyone else today is building a better 4x4. And offering. More.
    I hate my drum brakes, drums brakes collects water , mud, sand, dust, etc. The faulty rear lock-ups…that I had, Toyota could not find the problem. I replace my E- cables and it solve 90% of the faulty rear brakes lock ups. Just that heavy rains still causes this problem. All at my expense too. 4 times to Toyota shops.
    To get this aftermarket Disc brakes (Hawaii) I already estimated, I will need to spend almost $3,000 +
    And I am still making monthly payments. Not going to do this.
    Toyota going backwards…just a gut feeling….
  6. Sep 16, 2022 at 5:58 PM
    #46
    Eastsidegeorgiaboy
    Eastsidegeorgiaboy [OP] Well-Known Member
    Jon
    2022 Tacoma TRD Off-Road
    Stock.
    Thats what I thought, as well.
  7. Sep 16, 2022 at 6:20 PM
    #47
    Eastsidegeorgiaboy
    Jon
    Stock.
    Now thats what im talking about!
  8. Sep 16, 2022 at 6:24 PM
    #48
    Eastsidegeorgiaboy
    Jon
    Stock.
    I thought the trd pro suspension was good. Am I wrong?
  9. Sep 16, 2022 at 6:28 PM
    #49
    Eastsidegeorgiaboy
    Jon
    Stock.
    I cant pretend it doesn't exist. I drive a manual 22 OR. It's too ingrained into me.
  10. Sep 16, 2022 at 6:30 PM
    #50
    saint277
    saint277 Vigilo Confido
    who needs a parking brake when you can just leave it in first?
  11. Sep 16, 2022 at 6:34 PM
    #51
    Eastsidegeorgiaboy
    Jon
    Stock.
    I've parked on hills so steep that the truck would slowly roll backwards, even in gear. These qere some steep driveways. Luckily, I don't have to go to thise houses anymore, but still. It was crazy to experience the first time.
  12. Sep 16, 2022 at 6:37 PM
    #52
    Eastsidegeorgiaboy
    Jon
    Stock.
    Im talking 30⁰ incline steep. Asphalt driveway. Had to use 4x4 to go up the driveway. This was in my gen 3 explorer. Driveway was extremely hard to walk up.
  13. Sep 16, 2022 at 7:33 PM
    #53
    Lava-road
    2019 trd-off road
    Hand brakes … I am surprised how many people do not use this feature. It became a habit over 40+ years .
    Sad to see how many people injury or kill because they thought they were in park. The amount of children that die too, by not setting the hand brakes.
  14. Sep 17, 2022 at 1:02 AM
    #54
    Desert Dog
    Desert Dog Well-Known Member
    Los Gatos
    2007 DCSB
    Work in progress
    Drums have reputation of trapping water and not working once wet. If you never ford a stream then you may never have that as a problem, if do ford a stream then assume your drums will be at reduced capacity for a few miles. Disc brakes squeegee the water off and are a better choice if this is the only consideration.
  15. Sep 17, 2022 at 3:55 AM
    #55
    Lava-road
    2019 trd-off road
    Best to do your own research on drums vs disc brakes in the rear wheels.
    DRUM brakes are usually cheaper , holds better as a parking brake. In emergency braking - drums do a better job in locking the wheels. Drums are usually smaller & lighter. Also drums are refer to as “old technology”.
    Disc brakes is consider a more high performance brakes. Has great stopping abilities & better in heat dissipation. Collect less dust. Better in slowing the car/ truck. Disc brakes sometimes need a additional braking to be use for “parking”.
    True front brakes do most of the work.
    My experience on the dirt & muddy , water foraging roads, the drum brakes is a failure ,because of the lock-ups I still get once and awhile. Replacing the E- cables reduce the problem 90+%.
    Drums will always be use because it is cheaper for manufacturers cost. Disc brake cost more.
    The new 2024 Tacoma trucks will start having 4-wheel disc brakes ( future up-grades)
  16. Sep 17, 2022 at 4:23 AM
    #56
    Plain Jane Taco
    Plain Jane Taco Well-Known Member
    USA
    It does what it's supposed to do. But it's mostly 2nd gen warmed over.....a design pinned in 2003
  17. Sep 17, 2022 at 11:48 AM
    #57
    2020TacomaGuy
    2020TacomaGuy Well-Known Member
    2020 4x4 DCSB SR5
    https://www.youtube.com/watch?v=tEEgINoP2-o
  18. Sep 17, 2022 at 9:16 PM
    #58
    fishhead90
    fishhead90 Well-Known Member
    JR
    2017 Cement TRD pro
    KD Max tune, Injen intake, RIPP Superchargers coils, Blackhole sound deadening, focal sound system, pioneer DMH 7600 head unit, ICON Rebound pro wheels, nitro 33 ridge grapplers, stop tech bbk & rear disc conversion, Retrax motorized tonneau cover, Meso total tail stage 1, Meso progressive side markers, pop n lock tailgate.
    I converted my truck to rear discs but I went for the StopTech bbk. The difference is as drastic as is imaginable. I decided to upgrade after I had a scare with a blind hill cress to stopped traffic. I personally always felt Toyota in general has sub par brake performance, the Tacoma (b/c it’s a pickup) has always been on the bad end of the spectrum also. Brake power, braking distance, feel, confidence… all drastically improved. What I notice most is that as oppose to having the truck massively nose dive when I brake aggressively, I feel the truck hunker down and scrub off speed in a much more composed way. The 4 piston rear brakes handle a lot more braking duty. I obviously can’t speak for everyone’s circumstances, but for me, the stoptech kit was worth every penny. It’s already saved me from a near collision. If you can stomach the price, I’d say don’t even think twice.
    gvfs likes this.
  19. Sep 17, 2022 at 9:24 PM
    #59
    Lava-road
    2019 trd-off road
    One thing is rarely mention is the ABS system. Disc or drums, nice to have this ABS system especially when you need to brake hard.
    I also like the automatic braking is engage after going 25 miles per hour. My daughter was following another car, she has a 2019 TRD OR, when the car in front had brake all of a sudden , her Tacoma automatically put on the brakes preventing a rear end collision . The Tacoma reacted faster then her. She call me to tell me how this safety feature is a blessing.
    Also I found it easy for DIY to replace disc brakes vs drums. I still have all my brakes tools ( drums brakes) from the 70’s , including honing out the brake cylinders.
    My Dad had me take apart the motor in my 1966 Barrcuda. Thought me how to grind each valve by hand. I didn’t realize I could have taken the heads to a machine shop. I was still in high school. LOL…
  20. Sep 17, 2022 at 9:32 PM
    #60
    Lava-road
    2019 trd-off road
    Does the Stop Tech BBK work with the factory hand brakes?
    The specs and everything in this kit looks awesome.
