Rear disc brake swap
Discussion in '2nd Gen. Tacomas (2005-2015)' started by RenegadeEmmers, Jul 6, 2017.
  1. Jul 27, 2017 at 2:04 PM
    #81
    stevotivo12
    stevotivo12 Well-Known Member
    Stephen
    2016 Silver Tacoma TRD Sport MT
    Front hellwig sway bar,All pro sway bar end links, Fox 2.5 Resi Coilovers and Shocks, Fox 2.5 Hydraulic Bumpstops, Budbuilt Traction bar, Total Chaos UCAs w/ heim joints, Icon AAL, AFE Power Intake with dynamic scoop, URD spec U, URD short shifter, Flossy weighted shift knob, michelin tires, black badges, black tailgate letters, black grill with custom Diaz Fab Devil horn yota logo, retrofit/morimoto HID conversion, red interior LED lights, Pioneer head unit, kenwood excelon door speakers, 2 10" pioneer subs,
    Alright dude you should probably chill a little. Just because somebody doesnt chose to buy the same part as you doesnt make them cheap or broke. I plan on doing a disc swap, so Im not really sure what you are getting ALL different kinds of bent out of shape about in the first place.
    For the record, plenty of performance offroad vehicles have drum brakes because discs are a lot more breakable than drums are, especially when there might be loose gravel to drive over that might fling rocks into the discs.
  2. Jul 27, 2017 at 2:32 PM
    #82
    skullver
    skullver Well-Known Member
    Ventura, CA-Carpinteria, CA, La Conchita, CA.
    2006 Tacoma 4wd double cab, short bed, black. 2007 Sequoia SR5 Silver.
    Drum brakes have two advantages over disc brakes. They are cheaper to make, and the consumables last longer. They will heat up and fade more quickly, they apply less brake torque, they are a pain to work on. All dezert race trucks, trophy trucks, Ultra4 etc, all run disc brakes on all 4 corners, they are not any less durable under any condition.
    That being said, for my truck I am not going to go through the hassle or expense of swapping to disc brakes, It stops fine and I don't tow anything, nor have I added any considerable weight over stock. To each their own.
  3. Aug 3, 2017 at 2:36 PM
    #83
    Tex-Tac
    Tex-Tac Well-Known Member
    TEXAS
    2008 Tacoma V6 PreRunner SR5 Extended Double Cab Desert Sand Mica
    Installed Overhead Compass and Temperature Display along with outside temperature sensor and wiring; LED lights reverse backup; LED license plate lights; Added GTA Bluetooth Audio kit to stock radio for iphone audio; Spare tire steel braided air hose extension connection to rear bumper; Installed new headlights along with new bulbs PIAA H4 XTreme and for fog lights PIAA H10 XTreme bulbs. Installed new hood with "hood-scoop". Installed Predator Side Steps. Replaced front chrome grill with customized color matched (Desert Sand Mica) grill with added TOYOTA lettering (also in matched color), installed and secured tailgate anti-theft devices. Also installed a new external TPMS monitor for all 4 tires.
    stevotivo12 and Nickel like this.
  4. Dec 12, 2017 at 11:32 AM
    #84
    njfantastico
    njfantastico Well-Known Member
    NJ
    2015 Prerunner TRD Access cab full size bed in Silver
    While we are talking DRUM brakes - My first set of rear pads lasted 110K miles. Without needing them to be done, decided to get them done for piece of mind. They squeaked after 500 miles of new replacement and the Dealer fixed the squeak 4 times, claiming dust issues. I call BS! They claimed to have resurfaced a few times, then claimed they replaced everything.
    Any idea what caused this?
    Any suggestions on the best replacement pads i can get in the future for my 2015?
    AND, why don't some people take the Disc Brakes from a 2010+ 4Runner and use them on our 6cy Tacoma's?
  5. Dec 12, 2017 at 11:42 AM
    #85
    knottyrope
    knottyrope Well-Known Member
    Knotty
    Bahstun
    09 Taco CCLB 4x4 SR5 4.0
    Pads, rotors, ujoints, 5900K Super White Xenon HID Halogen Bulb Fog Light
    Seems like a bunch of BS, most tractor trailers have drum brakes that I see parked at work
    my 9000 lb full size truck has drums and can tow a 11k load
  6. Dec 12, 2017 at 12:02 PM
    #86
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Imagine if they all had disk breaks though....:drevil:
  7. Dec 12, 2017 at 12:05 PM
    #87
    FirstTruck969
    FirstTruck969 Member
    White 2009 Tacoma TRD with Sport Package
    All my experience with brakes has been on disc systems. I am mechanically inclined and do 90% of the work on my vehicle myself. However, I am not confident working on drum brakes even with the shop manual in hand. Can I check drum brakes without taking the drum off?
  8. Dec 12, 2017 at 12:33 PM
    #88
    knottyrope
    Knotty
    Bahstun
    if you have a lighted scope maybe
  9. Dec 12, 2017 at 12:35 PM
    #89
    Bebop
    Bebop Old fashion cowboy
    Nick
    Castle rock Colorado
    2012 Toyota Tacoma baja
    6inch lift sitting on bilstein coilovers. Lexus is300 studs in front to keep stock wheels, general grabber red letters, nfab front bumper.
    Get those super man X-ray spectacles
