Rear door lock won't unlock with fob
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Jarod888, Apr 17, 2020.
  1. Apr 17, 2020 at 10:41 PM
    Jarod888
    Jarod888 [OP] Well-Known Member
    Colorado
    2024 GMC 2500 AT4 Duramax Longbed
    I have a 2014 4dr Tacoma sport long bed. Recently, the drivers side rear door stopped unlocking with the fob. All other doors are fine. I have not made any recent modifications to the truck. If I stand near the door, it sounds like the locking mechanism isn't actuating, I can clearly hear the others unlock.
    The reverse is also true, it won't lock if unlocked.
    Please advise. Thanks.
    If possible, please post any helpful diagrams or video links to troubleshoot.
  2. Apr 18, 2020 at 1:54 AM
    Ricardowelch
    Ricardowelch Member
    You can take actuator out and try to take a part for cleaning and grease. It maybe help. good luck
  3. Apr 18, 2020 at 4:04 AM
    sskarr151
    sskarr151 Well-Known Member
    Scott
    Scottsville Va
    12 dcsb sport
    I have the same problem with my front driver door. 2012. I’ve called all the junk yards within a hour of me and they all told me they had no 05-15 Tacoma’s.
  4. Apr 18, 2020 at 6:27 AM
    DG92071
    DG92071 Well-Known Member
    What does that door do when the door lock switch on the door panel is pressed?
    Kolter45 likes this.
  5. Apr 18, 2020 at 6:38 AM
    Kolter45
    Kolter45 Well-Known Member
    Denver, CO
    2013 TRD Sport, 2015 Inferno 4Runner
    Toytec Boss Leer/Rhino Rack TRD Wheels/Falkens
    OP I’d take the door panel off & look/listen then. Do you have 2 fobs? Do they both not work with that door? Does locking the door using the truck button give you the same result?
    here’s the Amazon fob link. I have a factory & aftermarket fob both have never gave me trouble. I programmed it myself - super easy. I do have the 2 factory keys though.
    https://www.amazon.com/dp/B06XRGT7W1/ref=cm_sw_r_cp_api_i_6AWMEbNHT9TX2
  6. Apr 18, 2020 at 6:43 AM
    Jarod888
    Colorado
    Thanks for the ideas. I will check to see what it does with the door panel button. I have another fob, so I'll also see if the same happens. It used to be more intermittent, but now it's pretty consistently every time. Thanks again.
    DG92071 and Kolter45 like this.
  7. Apr 18, 2020 at 6:46 AM
    Muddinfun
    Muddinfun Well-Known Member
    There’s a slot car motor looking motor in the door latch. They eventually wear out. They’re available on ebay for cheap. If you don’t assemble the latch correctly, the door won’t open. Try the latch 20 times with a screwdriver before you close the door.
    TnShooter, Jimmyh, DG92071 and 2 others like this.
  8. Apr 18, 2020 at 7:19 AM
    pdaddy
    pdaddy WeLl-KnOwN mEmBeR
    Preston
    Central AL
    ‘13 DCSB Converted Prerunner 4wd
    Yea my driver door’s actuator motor went out too. I actually fixed it by removing the actuator, disassembling it and replacing the small motor inside. But then I messed up and didn’t connect the door wires to it properly and locked me out of my truck lol so I had to cut it up to enter my truck and ended up just buying a whole new actuator unit. I would recommend doing that
  9. Apr 18, 2020 at 9:56 AM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    Excellent advice. I don't want to see another " I can't get my door open thread ".
  10. Apr 18, 2020 at 1:38 PM
    Jarod888
    Colorado
    So, with the other fob, same thing happens. When I press the unlock button on the drivers door panel, it wont unlock. Interesting thing, both fobs and the drivers door panel button will lock the door if it is unlocked.
    I'm going to take apart the door when I get home to see if maybe the unlock wire is loose or something.,its weird to me that it would lock, but not unlock. I will also make sure someone is in the vehicle before I mess with any connections, or at least that the window is down.
    Jimmyh likes this.
