Rear Door Panel Scuffed
Discussion in '2nd Gen. Tacomas (2005-2015)' started by CRT78, May 29, 2015.
  1. May 29, 2015 at 5:18 PM
    CRT78
    CRT78 [OP] Member
    Hello, both of my rear door panels took a beating on a recent trip.
    Wondering what my options are to repair the damage, am I able to just get that top strip, would I have to replace the entire door panel? Any tips from the pros?
  2. May 29, 2015 at 5:20 PM
    T4RFTMFW
    T4RFTMFW Well-Known Member
    I would think you would replace the whole panel. Have you tried hitting it with a cleaner? Or are they really as bad as they look?
    I have some dog scratches on mine, but practically disappear with some Simple Green (diluted) and a microfiber buff.
  3. May 29, 2015 at 5:21 PM
    CRT78
    CRT78 [OP] Member
    Yeah, these are pretty deep scratches, so a cleaner is not going to cut it unfortunately.
  4. May 29, 2015 at 5:27 PM
    T4RFTMFW
    Might try and find a replacement from a salvaged Tacoma. I would imagine a new door panel is at least $400.
  5. May 29, 2015 at 5:40 PM
    CRT78
    CRT78 [OP] Member
    Thanks, yeah that was my next question, best options for finding a new door panel. I checked Ebay, options were slim to none.
  6. May 29, 2015 at 7:43 PM
    Sugar Silva
    Sugar Silva Well-Known Member
    Dave
    San Diego, CA
    16 Toyota Land Cruiser
    Kings Sliders TRD Rock Warrior Wheels Tint
    Have them covered in leather
  7. May 29, 2015 at 7:50 PM
    KSLawman
    KSLawman Active Member
    Eric
    Kansas
    TRD Access Cab
    K&N CAI, TRD Catback
  8. May 29, 2015 at 7:56 PM
    T4RFTMFW
    Ooooooooh.
  9. May 29, 2015 at 8:02 PM
    Harley2
    Harley2 Well-Known Member
    Rick
    Vermont
    15 Super White Double Cab 4x4
    Afraid its cover in leather or some other material which will require real talent because even the door handle surround is molded into the panel, replace the panel, or live with it....Those are pretty bad! Sorry Mate!
  10. May 29, 2015 at 8:25 PM
    CRT78
    CRT78 [OP] Member
    Would leather be my most durable option? Appreciate the help!
  11. May 29, 2015 at 8:34 PM
    CRT78
    CRT78 [OP] Member
    Also, any places you can recommend to buy a door panel online? Thank you.
  12. May 29, 2015 at 8:38 PM
    T4RFTMFW
    I would think leather would be nice, until it got damaged. Then it would look no better than the plastic does now. :notsure:
    What happened to the panel to cause this damage anyway? Might have a product to show you that would help in the future, it is meant for dogs. New door panel and the protectors below might be a good option for you. Assuming if you did one door in leather, you would do them all- that would be very pricey.
    These come in black, and I have had a pair myself for a few years. $22.50.
    http://www.amazon.com/Kurgo-Door-Guard-Hampton-Sand/dp/B005MYI1K0
    Sugar Silva likes this.
  13. May 29, 2015 at 8:57 PM
    NMTrailRider
    NMTrailRider Well-Known Member
    New Mexico
    If it were mine, I'd work on it very precisely with a variable speed Dremel. Get some super fine, broad faced or rounded bits. Or fine sanding disks. and smooth out the rough edges of the gouges with a low RPM. And consider them battle scars. Still gonna be some good marks left, but at least they'd be smooth and you'd get rid of the white. Maybe you'd even get it all back to the same shade of gray. Don't do any more than you have to. Worth a shot before purchasing an entire $400 panel.
  14. May 29, 2015 at 9:02 PM
    T4RFTMFW
    Is it not painted plastic to begin with? I'd be curious to see if any sanding would actually produce more white, rather than less.
  15. May 29, 2015 at 9:13 PM
    NMTrailRider
    New Mexico
    I assumed that was just a molded plastic, gray all the way through. I could be wrong- good observation PeeRunner. I'd still be tempted to smooth the edges, regardless, before I sprung for a new one. Dremel even has polishing bits. I couldn't handle rough scratches like that, especially in that location. Too bad- right where your arm wants to rub. I still think I'd be tempted to see if I could get it to a tolerable state before throwing down $400.
  16. May 29, 2015 at 9:34 PM
    T4RFTMFW
    For sure.
  17. May 29, 2015 at 9:36 PM
    Sugar Silva
    Dave
    San Diego, CA
    Thanks. Just ordered a couple. One for my 8 year old Lab and the other side for my 3 year old human
    T4RFTMFW[QUOTED] likes this.
  18. May 29, 2015 at 9:41 PM
    T4RFTMFW
    Be mindful of the plastic tabs that insert into the window channel. Once they become bent and creased it can occasionally be annoying.
  19. May 30, 2015 at 4:27 AM
    mooch91
    mooch91 Well-Known Member
    PA
    2012 Tacoma AC SR5 4x4
    I'm not at my truck right now but I would have thought that was a perforated vinyl covering on the panel based upon the way it looks. If itnis in fact solid, you might want to have an auto body guy look at it - they can do some amazing things with plastics nowadays - filling, sanding, and paint. Just a thought.
  20. Jun 1, 2015 at 8:04 PM
    StuckinOhio
    StuckinOhio Well-Known Member
    Mark
    Ohio
    12' v6 AC 4x4 SR5
    Butane torch will remove the white stress mark condition but doesn't fix the gouges. What about a high quality vinyl wrap? Not sure how tuck edges etc just a thought
