Rear doors won't open after speaker install
Discussion in '3rd Gen. Tacomas (2016-2023)' started by DonM77, May 1, 2017.
  1. May 1, 2017 at 10:45 AM
    DonM77
    DonM77 [OP] Well-Known Member
    Don
    Im an idiot! I realized I screwed up, just not sure exactly what went wrong. I'm assuming the cables popped back off after installing the panels.
    No excuses but I'm recovering from foot surgery and decided I've been laying around long enough so I installed the speakers. Took my time and made sure everything went smoothly, not sure how I made the mistake twice but I did. How do I fix this mess and what exactly went wrong so the same thing doesn't happen when I do the front?
    Thanks and go easy on me LOL
    FHC and scottalot like this.
  2. May 1, 2017 at 10:47 AM
    breader3
    breader3 2016 TRD Off-Road 4x4
    Brad
    Las Vegas
    Seems odd, as the cables shouldn't affect the exterior handles. Silly question, have you tried locking and unlocking it and then opening it from both sides?
  3. May 1, 2017 at 10:49 AM
    Taco1999
    Taco1999 Well-Known Member
    Jeremy
    Slidell, Louisiana
    2014 Tacoma Double cab 4x4 trd
    Sounds like one of the rods that the handle pulls to open the lock came off.
    ratcityrain and Silverspool like this.
  4. May 1, 2017 at 10:50 AM
    Rob Daman
    Rob Daman The Taco Formerly Known as Hard Shell Taco
    Rob
    So Cal
    17 OR 6MT
    a lot
    if you can't open from inside or out then you'll have to get a locksmith or you can see if you can find a slimjim or hanger to pop it loose.
  5. May 1, 2017 at 10:51 AM
    fajitas21
    fajitas21 XMF - Extreme Mexican Food fo Life!
    Lee
    Collierville, TN
    4Runnerzzz
    Originally not Expo AF! Kinda Expo AF now...lame.
    The exterior handle is usually a metal rod, the cable system is typically just the interior, as breader3 said. Does it not work from both inside and out? Or just one? If both don't work, perhaps the latch is disconnected somehow.
    Taco1999 likes this.
  6. May 1, 2017 at 10:52 AM
    ian408
    ian408 Well-Known Member
    Ian
    Santa Clara, CA
    09 Tacoma
    Child proof lock.
    Siblue, Ch78, nudavinci64 and 8 others like this.
  7. May 1, 2017 at 10:55 AM
    DonM77
    Don
    Correct, ive tried all combinations inside and out nothing is working. Nothing is working and the strange part about it is both doors.
    breader3 likes this.
  8. May 1, 2017 at 10:58 AM
    fajitas21
    Lee
    Collierville, TN
    4Runnerzzz
    Dang. I don't have any good info for that. I hope someone on here offers some thoughts.
  9. May 1, 2017 at 10:59 AM
    breader3
    Brad
    Las Vegas
    So odd.
    I'd either go with the slim Jim option, or attempt to pull a corner of the door panel off from the inside to see if you could grab that cable with a pair of needle nose pliers.
  10. May 1, 2017 at 12:11 PM
    DonM77
    Don
    I actually called toyotacare to have them come out and Jimmy the doors. They told me it can't be done with new vehicles lol
  11. May 1, 2017 at 12:16 PM
    Ihatetacomas
    Ihatetacomas Because tacomas hate me
    Dylan
    Elko NV
    '12 White LB TRD Sport
    Used @ 23,283 Volant Intake (w/ scoop)(removed August 2016), BAKFlip G2 Tonneau Cover, (drain tube mod), Pop & Lock Tailgate Lock, Stampede Vigilante Premium VP Series Hood Protector, 5lb Extinguisher, Shovel & Axe mounted in bed, Shok Industries Sound Deadener, Mercury: (K62, MGR-1200, MGR-495) Triton 8" Subs, Custom-Made: Sub Box, Speaker Templates, Vapor Barrier, All-Pro Bumper w/Kickouts, hidden trailer hitch, wooden cup-holder Misc: Knukonceptz RCA, speaker, and power wires, Big 3 Upgrade, a very full Husky technician tool box
    If you have AAA they should be able to get your door unlocked at least. Did you take any pictures of your door after you put down your sound deadening/speakers/whatever you did?
    kgarrett11 likes this.
  12. May 1, 2017 at 12:25 PM
    DonM77
    Don
    Unfortunetley I don't have AAA and No pictures were taken.
    Toyota sent a roadside person which is similar to AAA I believe. He was the one who said a Jimmy wouldnt not work. If that's true should I even bother with a locksmith?
  13. May 1, 2017 at 12:32 PM
    beergeek
    beergeek Well-Known Member
    RI
    2017 Black Tacoma Limited
    Put the window all the way down and see if you can get access through the slot.
    jjew18 likes this.
  14. May 1, 2017 at 12:34 PM
    T4RFTMFW
    T4RFTMFW Well-Known Member
    Double cab or what?
  15. May 1, 2017 at 12:38 PM
    DonM77
    Don
    Yes 4 door
  16. May 1, 2017 at 12:39 PM
    T4RFTMFW
    And they don't unlatch from inside or outside?
  17. May 1, 2017 at 12:49 PM
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    X2
    RogueTRD and EagleUSMCRet like this.
  18. May 1, 2017 at 12:53 PM
    DonM77
    Don
    Nope
  19. May 1, 2017 at 12:55 PM
    T4RFTMFW
    Should still be able to be opened from the outside of the car, no?
    Ch78 and shakerhood[QUOTED] like this.
  20. May 1, 2017 at 12:55 PM
    Ihatetacomas
    Dylan
    Elko NV
    Did you reconnect the window controls on the inside of the door? I left one unconnected one time and none of the window would roll up until I reconnected it. Maybe it's the same way with the locks? :notsure: If you really had to you could at least shine a light through the door if you take out the cup looking holder (if it's anything like my 2nd gen).
    Also, does the handle feel like it's locked when you pull on it from either side or as if it's stuck on something?
