Rear Drive Line Vibration
Discussion in '1st Gen. Tacomas (1995-2004)' started by Auto, Mar 3, 2010.
  1. Mar 3, 2010 at 7:23 AM
    Auto
    Auto [OP] Well-Known Member
    Delaware
    01 TRD SR5
    None Yet Some Coming Soon
    I am having a rear drive line vibration around 75 mph. I have checked the u joints they all seem to be good. I just had all the tires balanced as well but the problem still persists. Any suggestions. Thanks
  2. Mar 3, 2010 at 7:45 AM
    pairodice
    pairodice Well-Known Member
    Jay
    SF NM
    02 DCSB prerunner 4x4 manual
    what model is it ? if it has a lift in the rear it may need to have the carrier bearing shimed down or carrier bearing may be bad but usually it viberates more when going from a dead stop
  3. Mar 3, 2010 at 8:18 AM
    Auto
    Delaware
    01 TRD SR5
    It is a extended cab. I do not have a lift on her.
  4. Mar 3, 2010 at 2:03 PM
    da0023
    da0023 The One, The Only
    Drew
    Alabama
    99 PreRunner SR5
    none
    might have to rebalanced your driveshaft.
  5. Mar 3, 2010 at 2:16 PM
    shitroc
    shitroc Master of War
    Ant
    New Brunswick, Canada
    2002 Tacoma TRD 4X4
    Listed in sig.......
    you may have a broken belt or something in one of your tires. how old are the tires are they a good name brand tire?
    also what kind of condition are the leaf springs in, weakened or flat springs will change pinion angles causing rear vibes.
    check your carrier bearing to, if thats in shit condition that will definitly cause vibes
    just throwin out ideas
  6. Mar 3, 2010 at 7:53 PM
    4421.frank
    4421.frank Well-Known Member
    Southside chicago
    02 double cab prerunner supercharged
    nasty dent on driver's side bed panel, shabby seats, cigarette burned interior roof, missing berf bar pad, cracked rain visor, removed hood scoop, unmentionable stain on back bench?
    i had similar problem
    1800 clams later there is a new rebuilt rear end, balanced drive shaft, new u-joint, and new carrier bearing:D
    if there is any vibration now, then she'll be driven off a cliff:mad:
  7. Mar 4, 2010 at 12:32 PM
    Auto
    Delaware
    01 TRD SR5
    the tires are BFG all terrains. I don't think any of the belts are broken because i rotated the tires and had the same vibration but the tires only have about 20% life left. I will check the carrier and the drive shaft.
  8. Mar 6, 2010 at 10:28 PM
    RideFast
    RideFast on the flats.
    Jesse
    Albuquerque New Mexico
    Tacoma
    Wow I fought that problem for months and come to find out...
    I put bigger tires on my truck and the retards at discount tire put 36 PSI in all my tires so I lowered it down to factory 26 front and 29 rear and it went away for the most part. But not all of the way. So then I experimented a little more and found that 28 PSI all around worked out way better.
    Then
    I also replaced my shocks and struts, after I did that my truck rides like new. No dirveline vibs!!!
  9. Mar 9, 2010 at 9:55 AM
    Auto
    Delaware
    01 TRD SR5
    I will check my tires psi Thanks
