Rear drive shaft spacers
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Treywaytacoma, May 24, 2020.
  1. May 24, 2020 at 11:42 PM
    Treywaytacoma
    Treywaytacoma [OP] Member
    2020 trd off road taco
    Leveling kit
    I have a 2020 off-road trim. Im debating if I should place rear drive shaft spacers on my 3” front and 1” rear Lifted tacoma. I was wondering if anyone experienced positive, negative or neutral results when they decided to go ahead and do the install on their 2020truck?
  2. May 24, 2020 at 11:57 PM
    tcjacado
    tcjacado Well-Known Member
    Are you getting vibrations?
    If you are then, install it or axle shims may be needed. Or if you are 4wd, it could be the needle bearing. Put it in 4wd hi and see if vibe goes away. If it does, then plan on the ecgs swap.
  3. May 25, 2020 at 12:46 AM
    Treywaytacoma
    Leveling kit
    Tbh i cant really tell if there are vibrations bc of the tires I got 285/55R20 E-load and its a Q. I cant tell on 4WD either. All i know is after the lift the ride is not smooth anymore.
  4. May 25, 2020 at 6:30 AM
    71tattooguy
    71tattooguy Well-Known Member
    Dino
    Petaluma , Ca (707)
    2019 DCLB TRD OFF- ROAD
    Kings 2.5” front and rears from Accutune / ICON RXT LEAF PACK black badges doors and tailgate / method 315 / 255/85/16 Yokohama G003 / magnaflow exhaust , axle dump / meso int delete kit / meso led map lights / dome lights / wheelers front super bumps / accutune Flip kit with spacer and new bumps / Cali raised fog light pods / Cali raised ditch lights / RCI FULL SKIDS / SLIDERS / RCI rear bumper / rigid backup lights / tuned on 4.88’s
    It’s a truck not a caddy. A few things e rated tires and that lift will do it.
  5. May 25, 2020 at 6:56 AM
    Treywaytacoma
    Leveling kit
    Thats what I thought. Thanks guys, ill hold off on the install.
  6. May 25, 2020 at 6:59 AM
    fiftyxp
    fiftyxp Well-Known Member
    2017 trd offroad 4x4
    tacomas are kinda shaky as is.
    when I put my k02s E rated it became shakier
    If you feel like youre losing your mind with the vibe and cant tell if it was there before or not, probably just how it is
  7. May 25, 2020 at 7:50 AM
    71tattooguy
    Dino
    Petaluma , Ca (707)
    Also bro not much side Wall on those rims you are running with those 20’s . I run 32” tire on stock off-road wheels and I’m at 30psi to have a little softer. IMO it’s still stiffer with lift etc. I don’t mind stiffer , it’s in a good way. Just my 2 cents.
  8. May 25, 2020 at 10:07 AM
    Treywaytacoma
    Leveling kit
    - thats what i thought, its just the way it is
  9. May 25, 2020 at 10:09 AM
    Treywaytacoma
    Leveling kit
    -with 30 psi, its comfortable? I run on 35 myself. The more sidewall a tire has the more quieter it is you think??
  10. May 25, 2020 at 11:34 AM
    71tattooguy
    Dino
    Petaluma , Ca (707)
    It’s a lot better but I don’t mind at all. Love the ride 5100’s all around lifted with AAL.
