rear drive shaft vibration
Discussion in 'Suspension' started by BP348, Nov 19, 2010.
  1. Nov 19, 2010 at 2:22 AM
    BP348
    BP348 [OP] Well-Known Member
    The Woods, CA
    2017 SR5 4x4
    I put a 3" tough country lift on my 2011 reg cab 4x4
    after i noticed that it made my rear drive shaft vibrate
    the drive shaft on the reg. cab is very short and unlike the 4 doors and ex. cabs, it has no carrier barring. I had a new drive shaft fabricated w/ a cv. it helped but didnt eliminate the problem. anyone else have this problem? any suggestions?:confused:
    also considering a steeper shim- already have a 2.5 degree
  2. Dec 5, 2010 at 9:35 PM
    nrspence
    nrspence Well-Known Member
    Nate
    Monroe, Utah
    02 Tacoma
    OME 881/bilstein 5100's JBA upper control arms. All pro expo leafs rough country 2.0 rear shocks.
    I seem to be having the same problem. I have a regular cab with a 3 inch tough country lift. I have a 3 degree shims in the rear. I get my vibration when im driving over 55 mph and i push in the clutch or let off the gas pedal. Is this the same problem your having?
  3. Dec 6, 2010 at 5:03 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    Try a slighter larger shim.
    A CV style driveshaft will have a different 'angle' than a non-CV. Read this information and it might help you out.
    http://www.4xshaft.com/index.html
